Nsight Systems, no "Memory Usage" under CUDA HW
Hello, I am using Nsight systems (2023.3.3) to profile a workload on Ada 6000.
Report was collected with
sudo nsys profile --gpu-metrics-device=all --trace=cuda
However, compared to when I profiled RTX4080 with Nsight sytems 2024.1.1, the report doesn’t show Memory Usage under CUDA HW.
Is the Memory Usage metric an addition made on Nsys versions 2024 and after?
I believe so, @pkovalenko can confirm.
Apologies for the delay, I was a little confused by your question. Memory usage and gpu-metrics are not set the same. Since you are using a workstation card, I think your first best bet is to update to the latest Nsight Systems (2025.1). But yes, memory usage is a fairly recent addition.
