• Hardware Platform Jetson • DeepStream Version 6.4 • JetPack Version 5.1.2 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I test with
python3 deepstream_test1_rtsp_in_rtsp_out.py -i “rtsp://admin:1qaz2wsx@192.168.211.108/cam/realmonitor?channel=1&subtype=1” -g nvinfer --rtsp-ts
And I also configure (after I refer to this link NTP timestamp value always 0 - #17 by dailiupup)
streammux.set_property(‘live-source’, 1)
streammux.set_property(‘attach-sys-ts’, 0)
streammux.set_property(‘frame-duration’, 0)
But I always get 0 for NTP timestamp
And I also capture a log file by below steps
set env variable.
export GST_DEBUG=6
export GST_DEBUG_FILE=/tmp/gst.log
after running in a while, execute /tmp/gst.log |grep nvstreammux >1.log.
zip and share 1.log.
Just from your log, the SR message was only received once and that it was invalid.
line 31021: 0:00:07.896942724 e[332m10459e[00m 0xfffee0017000 e[37mDEBUG e[00m e[00m rtpjitterbuffer gstrtpjitterbuffer.c:4290:do_handle_sync:<rtpjitterbuffer0>e[00m ext SR 588302799, base 18446744073709551615, clock-rate 0, clock-base 18446744073709551615, last-rtptime 18446744073709551615
line 31022: 0:00:07.897109636 e[332m10459e[00m 0xfffee0017000 e[37mDEBUG e[00m e[00m rtpjitterbuffer gstrtpjitterbuffer.c:4298:do_handle_sync:<rtpjitterbuffer0>e[00m keeping for later, no RTP values
line 31024: 0:00:07.897158629 e[332m10459e[00m 0xfffee0017000 e[37mDEBUG e[00m e[00m rtpjitterbuffer gstrtpjitterbuffer.c:4330:do_handle_sync:<rtpjitterbuffer0>e[00m keeping RTCP packet for later
You can see that Rtspsrc strictly follows RFC 2326 and therefore does not (yet) support RealMedia/Quicktime/Microsoft extensions. Maybe there’s something special about the rtsp source you’re using. You can file a topic to the Gstreamer Forum to ask why the SR message was only received once and that it was invalid in Gstreamer.
