Nvarguscamerasrc with 8bit bayer sensor
The output of the sensor is RAW8 and I’m able to get the frames properly using v4l2src.
I want to use nvarguscamerasrc for capturing, but when i use nvarguscamerasrc i get only black frames.
nvarguscamerasrc work properly with RAW10/RAW12 , but with RAW8 i get only black frames.
1- Does nvarguscamerasrc or the ISP supports RAW8?
2- Am I missing some extra setting?
>     devicetree:
>         					dynamic_pixel_bit_depth = "8";
>         					csi_pixel_bit_depth = "8";
>         					mode_type = "bayer";
>         					pixel_phase = "bggr";
>     					active_h = "480";
Format
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
	if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
		*format = V4L2_PIX_FMT_SBGGR10;
	else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
		*format = V4L2_PIX_FMT_SRGGB10;
	else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
		*format = V4L2_PIX_FMT_SGRBG10;
	else if (strncmp(pixel_t, "bayer_gbrg10", size) == 0)
		*format = V4L2_PIX_FMT_SGBRG10;
	else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
		*format = V4L2_PIX_FMT_SBGGR12;
	else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
		*format = V4L2_PIX_FMT_SRGGB12;
	else if (strncmp(pixel_t, "bayer_bggr8", size) == 0)
		*format = V4L2_PIX_FMT_SBGGR8;
	else if (strncmp(pixel_t, "bayer_rggb8", size) == 0)
		*format = V4L2_PIX_FMT_SRGGB8;
	else if (strncmp(pixel_t, "bayer_grbg8", size) == 0)
		*format = V4L2_PIX_FMT_SGRBG8;
	else if (strncmp(pixel_t, "bayer_gbrg8", size) == 0)
		*format = V4L2_PIX_FMT_SGBRG8;
	else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
	else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
	else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
		*format = V4L2_PIX_FMT_XBGGR10P;
	else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
		*format = V4L2_PIX_FMT_XRGGB10P;
	else if (strncmp(pixel_t, "yuv_yuyv16", size) == 0)
		*format = V4L2_PIX_FMT_YUYV;
	else if (strncmp(pixel_t, "yuv_yvyu16", size) == 0)
		*format = V4L2_PIX_FMT_YVYU;
	else if (strncmp(pixel_t, "yuv_uyvy16", size) == 0)
		*format = V4L2_PIX_FMT_UYVY;
	else if (strncmp(pixel_t, "yuv_vyuy16", size) == 0)
		*format = V4L2_PIX_FMT_VYUY;
	else {
		pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
		return -EINVAL;
	return 0;
Best regards,
Bouz Al Asal
Sorry to tell current not support RAW8 for ISP pipeline.
