Nvc 21.5 generates incorrect code on aarch64 at -O2
Let’s consider the quite trivial reproducer below, and compile it with -O2 on aarch64
#include <stdio.h>
#define N 10
double reduce(double * a, int n) {
    double res;
    for (int i=0; i< n; i++)
        res += a[i];
    return res;
int main(int argc, char *argv[]) {
   double a[N];
   int i;
   for (i=0; i<N; i++) {
       a[i] = i;
   printf("%f\n", reduce(a, N));
   return 0;
The generated code for the reduce() subroutine is incorrect
00000000004008d0 <reduce>:
  4008d0:       d2efff08        mov     x8, #0x7ff8000000000000         // #9221120237041090560
  4008d4:       9e670100        fmov    d0, x8
  4008d8:       d65f03c0        ret
  4008dc:       d503201f        nop
and the outcome is wrong
$ nvc -O2 -o test_reduce test_reduce.c
$ ./test_reduce
nan
fwiw, the generated code is ok when built with -O1
$ nvc -O1 -o test_reduce test_reduce.c
$ ./test_reduce
45.000000
“res” is uninitialized so may contain garbage values. To fix, set it to zero.
% cat reduce.c
#include <stdio.h>
#define N 10
    double res=0.0;
        res += a[i];
    return res;
   double a[N];
   int i;
       a[i] = i;
   return 0;
% nvc -O2 reduce.c ; a.out
45.000000
Thanks for the quick reply and my apology for this gross overlook!
