Godbolt link: click HERE
Summary
This was found with the Boost.Intrusive test suite: slist_test (an intrusive singly linked list with a fancy void_pointer) segfaults or produces wrong lists when Boost is built with nvc++ -fast (b2’s pgi toolset release build), while it passes with gcc, clang and MSVC and under all sanitizers.
Attached a reduced program that reproduces the bug: it builds a singly linked list of three nodes and then walks it. The link field is a class type that wraps a raw pointer (my_ptr<node>). At -O2, -O3 and -fast the list comes out empty: the store prev->next_ = n that links the first element to the header node is lost. EDG 6.x (GNU mode) compiles fine in Godbolt.
The trigger is a struct that holds a node (which contains a my_ptr<node>) followed by an unused member of the same type my_ptr<node>. Removing that member, moving it before the node, or giving it any other type (node*, void*, long, my_ptr<int>, a different wrapper struct) makes the program correct.
Reproducer (nvcpp_fancyptr_min.cpp)
#include <cstdio>
template <class T>
struct my_ptr
T *m_ptr;
my_ptr() : m_ptr(0) {}
T *operator->() const { return m_ptr; }
struct node { my_ptr<node> next_; int value_; };
struct slist
node root_; // header node: root_.next_ is the first element
my_ptr<node> last_; // never read or written - but required for the bug
my_ptr<node> root_ptr() { my_ptr<node> p; p.m_ptr = &root_; return p; }
void assign(node *f, node *l)
my_ptr<node> prev = root_ptr();
for (; f != l; ++f) {
my_ptr<node> n; n.m_ptr = f;
n->next_ = prev->next_; // link n after prev
prev->next_ = n;
prev = n;
int main()
node values[5];
for (int i = 0; i < 5; ++i) values[i].value_ = i + 1;
slist l;
l.assign(values + 2, values + 5); // expected list: 3 -> 4 -> 5
int got[16], n = 0;
for (my_ptr<node> it = l.root_.next_; it.m_ptr != 0 && n < 16; it = it->next_, ++n)
got[n] = it->value_;
const bool ok = n == 3 && got[0] == 3 && got[1] == 4 && got[2] == 5;
std::printf("got [");
for (int k = 0; k < n; ++k) std::printf("%s%d", k ? "," : "", got[k]);
std::printf("] expected [3,4,5] %s\n", ok ? "ok" : "<<< WRONG");
return !ok;
Results
nvc++ -std=c++17 -O0 got [3,4,5] ok
nvc++ -std=c++17 -O1 got [3,4,5] ok
nvc++ -std=c++17 -O2 got [] <<< WRONG
nvc++ -std=c++17 -O3 got [] <<< WRONG
nvc++ -std=c++17 -fast got [] <<< WRONG
nvc++ -std=c++17 -fast -fno-strict-aliasing got [3,4,5] ok
nvc++ -std=c++17 -fast -alias=traditional got [3,4,5] ok
nvc++ -std=c++17 -fast -Mnoautoinline got [] <<< WRONG
g++ 15.2 -O3 ok
clang++ 21.1 -O3 ok
clang++ 21.1 -O2 -fsanitize=type ok, no report
clang++ 21.1 -O2 -fsanitize=address,undefined ok, no report
