hello,
i got a question about CUDAs relationship to C++. the programming manual at page 22 says: only the C subset of C++ is supported. what does that exactly mean? first it seemed perfectly clear, but the following example made me think
class vec3f
public:
vec3f(float x=0.0f, float y=0.0f, float z=0.0f) :x_(x), y_(y), z_(z) {}
vec3f(const vec3f& v) : x_(v.x_), y_(v.y_), z_(v.z_) {}
vec3f operator+(vec3f& src)
{return vec3f(x_ + src.x_, y_ + src.y_, z_ + src.z_);}
__device__ float x() {return x_;}
__device__ float y() {return y_;}
__device__ float z() {return z_;}
protected:
float x_;
float y_;
float z_;
__global__ void test_kernel (float4* pDst, float r, float g, float b)
unsigned int x = threadIdx.x + blockIdx.x * blockDim.x;
unsigned int y = threadIdx.y + blockIdx.y * blockDim.y;
unsigned int width = blockDim.x * gridDim.x;
vec3f v1(r,g,b);
vec3f v2(v1+vec3f(-1.0f,0,0));
pDst[x + width* y] = make_float4(v2.x(),v2.y(),v2.z(),0);
it’s not following the C++ spec (i have to use device), but operator overloading and constructors are clearly not C. the generated device code seems reasonable and executes fine.
so are these features still somewhat experimental and is there a certain reason for not using them, or are these things just poorly documented? (contrary to what the manual says basic inheritance seems to work, too…)
tomschi
