I have been getting this message while compiling my code, and am rather confident that the referenced lines are indeed being executed, and results are as I expect them to be. I wonder if anyone else has been getting a ‘suspicious’ or flat-out ‘erroneous’ instance of this message from nvcc. Or is the likelihood of compiler message being a bug so small that I definitely need to re-examine my code for oversights? Thank you!
NVCC message - warning: expression has no effect Has anyone received a suspicious instance of this m
Related topics
| Warning: Expression has no effect What does it mean? | 6 | 14739 | June 25, 2009 | |
| nvcc redundant warnings | 1 | 6314 | March 21, 2010 | |
| Problem compiling simple example | 11 | 18092 | November 12, 2010 | |
| nvcc bug | 0 | 557 | April 30, 2013 | |
| Warning at compilation expression has no effect | 3 | 9081 | May 12, 2011 | |
| Nvcc misses the variable ? Problem report | 2 | 3815 | June 25, 2008 | |
| Some executions of the code give garbage | 2 | 756 | May 10, 2011 | |
| Inconsistancy between NVCC and MS-Compiler | 5 | 6408 | December 10, 2010 | |
| Compilation Error | 1 | 1952 | April 10, 2009 | |
| Warning: Controlling expression is constant | 0 | 2227 | February 24, 2011 |
