So, I tried typing cat filename.cu, which threw an error, stating that cat is not an internal or external command. Then I tried to type the code on txt file and saved it as helloworld.cu in the current folder location and tried nvcc command suggested by you. Still it threw the error: Link: Fatal error cannot open file ‘uuid.lib’. Kindly refer the attachment.
