Greets Everyone,
I am a newbie to CUDA programming!!
For programming CUDA i’m using CUDA 2.2 and MinGW pack installations on Vista 64-bit. When i try to compile *.cu programs using NVCC the compiler throws an erroe saying that it cant find th cl.exe and that it is compatible only with VS 8 and 9.
It cannot find my GCC’s ld.exe even when i specify the ld.exe’s path using -ccbin switch to NVCC.
Need help in the compilation of CUDA programs.
Thanx and Regards
Abhishek Dey
