nvcc / ptxas 4.0 compiler segfault
When I compile this stripped-down code segment with nvcc 4.0, I get a segfault during the ptxas step.
struct s_trace
    int index;
    s_trace *next;
__global__ void kernel (s_trace *ptrace, int *pi)
    s_trace *tptr;
    int inode = 0;
for(int itarget = 1; itarget <= 2; itarget++)
        tptr = ptrace;
        ptrace = ptrace->next;
        tptr->index = inode;
for (inode = *pi ; inode != 0; inode--)
            tptr->next = tptr;
Here is my command line, and the compiler output:
$ nvcc -v -keep test3.cu -c -o test3.o
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=/scratch/tianwu3/bailey/cuda/bin
#$ _THERE_=/scratch/tianwu3/bailey/cuda/bin
#$ _TARGET_SIZE_=64
#$ TOP=/scratch/tianwu3/bailey/cuda/bin/..
#$ LD_LIBRARY_PATH=/scratch/tianwu3/bailey/cuda/bin/../lib:/scratch/tianwu3/bailey/cuda/bin/../extools/lib::/scratch/tianwu3/bailey/cuda/lib64
#$ PATH=/scratch/tianwu3/bailey/cuda/bin/../open64/bin:/scratch/tianwu3/bailey/cuda/bin:/usr/bin:/bin:/opt/gnu/bin:/opt/local/bin:/sbin:/usr/sbin:/scratch/tianwu3/bailey/cuda/bin
#$ INCLUDES="-I/scratch/tianwu3/bailey/cuda/bin/../include" "-I/scratch/tianwu3/bailey/cuda/bin/../include/cudart"
#$ LIBRARIES=  "-L/scratch/tianwu3/bailey/cuda/bin/../lib64" -lcudart
#$ CUDAFE_FLAGS=
#$ OPENCC_FLAGS=
#$ PTXAS_FLAGS=
#$ gcc -D__CUDA_ARCH__=100 -E -x c++ -DCUDA_NO_SM_13_DOUBLE_INTRINSICS  -DCUDA_FLOAT_MATH_FUNCTIONS -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_NO_SM_12_ATOMIC_INTRINSICS  -D__CUDACC__ -C  "-I/scratch/tianwu3/bailey/cuda/bin/../include" "-I/scratch/tianwu3/bailey/cuda/bin/../include/cudart"   -include "cuda_runtime.h" -m64 -o "test3.cpp1.ii" "test3.cu"
#$ cudafe --m64 --gnu_version=40403 -tused --no_remove_unneeded_entities  --gen_c_file_name "test3.cudafe1.c" --stub_file_name "test3.cudafe1.stub.c" --gen_device_file_name "test3.cudafe1.gpu" --include_file_name "test3.fatbin.c" "test3.cpp1.ii"
#$ gcc -D__CUDA_ARCH__=100 -E -x c -DCUDA_NO_SM_13_DOUBLE_INTRINSICS  -DCUDA_FLOAT_MATH_FUNCTIONS -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_NO_SM_12_ATOMIC_INTRINSICS  -D__CUDACC__ -C  -D__CUDA_FTZ "-I/scratch/tianwu3/bailey/cuda/bin/../include" "-I/scratch/tianwu3/bailey/cuda/bin/../include/cudart"   -m64 -o "test3.cpp2.i" "test3.cudafe1.gpu"
#$ cudafe --m64 --gnu_version=40403 --c  --gen_c_file_name "test3.cudafe2.c" --stub_file_name "test3.cudafe2.stub.c" --gen_device_file_name "test3.cudafe2.gpu" --include_file_name "test3.fatbin.c" "test3.cpp2.i"
#$ gcc -D__CUDA_ARCH__=100 -E -x c -DCUDA_NO_SM_13_DOUBLE_INTRINSICS  -DCUDA_FLOAT_MATH_FUNCTIONS -DCUDA_NO_SM_11_ATOMIC_INTRINSICS -DCUDA_NO_SM_12_ATOMIC_INTRINSICS  -D__CUDABE__  -D__CUDA_FTZ "-I/scratch/tianwu3/bailey/cuda/bin/../include" "-I/scratch/tianwu3/bailey/cuda/bin/../include/cudart"   -m64 -o "test3.cpp3.i" "test3.cudafe2.gpu"
#$ filehash -s " " "test3.cpp3.i" > "test3.hash"
#$ gcc -E -x c++ -D__CUDACC__ -C  "-I/scratch/tianwu3/bailey/cuda/bin/../include" "-I/scratch/tianwu3/bailey/cuda/bin/../include/cudart"   -include "cuda_runtime.h" -m64 -o "test3.cpp4.ii" "test3.cu"
#$ cudafe++ --m64 --gnu_version=40403 --parse_templates  --gen_c_file_name "test3.cudafe1.cpp" --stub_file_name "test3.cudafe1.stub.c" "test3.cpp4.ii"
#$ nvopencc  -TARG:compute_10 -m64 -OPT:ftz=1 -CG:ftz=1 -CG:prec_div=0 -CG:prec_sqrt=0  "test3" "test3.cpp3.i"  -o "test3.ptx"
#$ ptxas  -arch=sm_10 -m64  "test3.ptx"  -o "test3.sm_10.cubin"
Segmentation fault
# --error 0x8b --
I am running Ubuntu 10.04.3, 2.6.32-33-generic #72-Ubuntu SMP Fri Jul 29 21:07:13 UTC 2011 x86_64 GNU/Linux.
nvcc release 4.0, V0.2.1221
Segfaults in the toolchain are obviously not supposed to happen. Since you already have a small repro case in hand, it would be helpful if you could file a bug against the compiler attaching self-contained repro code. Thank you for your help, and sorry for the inconvenience.
For a temporary workaround, you could experiment with lowering the PTXAS optimization level via -Xptxas -O{0|1|2|3}. The default is -Xptxas -O3. Note that it is not recommended to use component-specific flags in production environments as these are generally unsupported.
Thanks. -O1 works as a temporary workaround, although -O0 and -O2 do not.
I filed a bug report at NVOnline.
