nvcc using shared memory without being asked to
Hi all,
I have a kernel that does not have any shared variables in the kernel. However, when I compile the following information is displayed for that kernel:
ptxas info : Used 12 registers, 2056+16 bytes smem, 28 bytes cmem[1]
The kernel uses 2056+16 bytes of shared memory.
I compile with the following flags: -arch sm_11 -use_fast_math --ptxas-options=-v -lcutil_i386 -lcufft
How would I get ride of this error.
Thank you,
Vinny P
I have never seen the any version of the compiler “automatically” use shared memory like that. Can you post the kernel code in question?
I figured it out!
Thank you,
Vinny P
For future reference, where did the shared memory come from?
Given that this was compiled for sm_11, I’d guess it’s the kernel arguments.
But 2056 bytes? Compute 1.x devices only have a 256 byte argument list size limit, I thought.
True (as I’ve found to my cost…). It could explain the 16 bytes, but not 2k.
