Please, Nvidia and its devs, help us fix the bug in ffmpeg, since 4 core CPU already gives by default 5 threads and fails. We have a file that requires at least 30 surfaces for 1 thread. But for 5 threads it is 34 surfaces and it fails. There are other files that fail with 10 threads and this on newer CPUs will cause big problems.
The proposed patch is [FFmpeg-devel] libavcodec/nvdec: Do not exceed 32 surfaces when initializing hw_frames_ctx - Patchwork
but that has some problems:
So far, the 32 surface limit has only ever been enforced as a soft
limit, and a warning printed when exceeded. Since it being a limit is
not strictly documented and it might be risen in the future.
Old cuviddec (ffmpeg.exe -c:v h264_cuvid -i example.mp4 -f null -) is not affected.
https://trac.ffmpeg.org/ticket/8948#comment:8
sample only https://trac.ffmpeg.org/raw-attachment/ticket/8948/example.mp4
Command
ffmpeg.exe -hwaccel cuda -i example.mp4" -f null -
leads to
[h264 @ 000001c962e62040] decoder->cvdl->cuvidCreateDecoder(&decoder->decoder, params) failed → CUDA_ERROR_INVALID_VALU
E: invalid argument
[h264 @ 000001c962e62040] Using more than 32 (34) decode surfaces might cause nvdec to fail.
[h264 @ 000001c962e62040] Try lowering the amount of threads. Using 5 right now.
[h264 @ 000001c962e62040] Failed setup for format cuda: hwaccel initialisation returned error.
