NVENC nvEncInitializeEncoder returns NV_ENC_ERR_OUT_OF_MEMORY (10) on RTX PRO 6000 Blackwell Server Edition in SPT CC; NVDEC works;
Environment
  • GPU: 1× NVIDIA RTX PRO 6000 Blackwell Server Edition (96 GB), passthrough to one CVM
  • GPU CC: SPT (CC State = ON). Not Hopper PPCIe. Not Workstation / Max-Q SKU.
  • CPU TEE: Intel TDX guest
  • OS: Ubuntu 24.04 (kernel: 6.8.0-90-generic)
  • nvidia-smi: 595.84
  • Driver Version: 595.84
  • CUDA Version (nvidia-smi): 13.2
  • Video Codec SDK: 13.0.37 (official AppDec / AppEncCuda)
  • FFmpeg: libavcodec 60.31.102 (Ubuntu package; h264_nvenc present)
What works
  • AppDec (NVDEC) H.264 → NV12 succeeds (example: 300 frames, coded 1920×1088). Session init ~2.1 s.
  • nvEncOpenEncodeSessionEx succeeds. The sample prints the GPU as RTX PRO 6000 Blackwell Server Edition.
What fails (first encode session; card mostly idle)
  1. Official sample AppEncCuda, after a successful OpenEncodeSessionEx:
    nvEncInitializeEncoder → NV_ENC_ERR_OUT_OF_MEMORY (10)
    Retry with -preset p1 -tuninginfo lowlatency -bf 0 -if nv12 -s 1920x1088: still error 10.
    Failure is before reading YUV / encoding any frame.
  2. Independent client (no SDK sample, no YUV file):
    ffmpeg -hide_banner -y -f lavfi -i testsrc=size=1920x1080:rate=30 -t 2
    -c:v h264_nvenc -preset p1 -tune ll /tmp/nvenc.mp4
    [h264_nvenc] InitializeEncoder failed: out of memory (10)
    Follow-on messages (“maybe incorrect parameters”, “Cannot allocate memory”,
    “Conversion failed!”) are cascading; the root is error 10 at InitializeEncoder.
root@tdx-guest:~/Video_Codec_SDK_13.0.37/Samples/build/AppEncode/AppEncCuda#ec SDK 13.0.37/Samples/build/AppDecode/AppDec/dec.yuv-Snfo lowlatency -bf 0-o /tmp/out.h264 -gpu 0GPU in use: NVIDIA RTX PRO 6000 Blackwell Server Edition[INF0 ][08:53:10] Encoding Parameters:
1920x1088 -if nv12
codec
h264
preset
p1
tuningInfo
lowlatency(default)
profilechroma
yuv420
bitdepth
8
/AppEncCuda
-i /root/Video_Cod
-codec h264
-preset p1 -tuningu
rc
fps
gop
bf
multipass
sizebttrate
maxbitratevbvbufsizevbvinit
cbr
30/1
INF
0
0
1920x1088
0
0
0
0
disableddisableddisabled
temporalag
lookahead
cq
0
P,B,I=0,0,0P,B,I=0,0,0P,B,I=0,0,0CreateEncoder : m nvenc.nvEncInitializeEncoder(m hEncoder, &m_ initializeParamsideo_ Codec SDK_ 13.0.37/Samples/NvCodec/NvEncoder/NvEncoder.cpp:330
qmin
qmaxinitqp
) returned error 10 at /root/V
Questions (product statements, please)
  1. Is NVENC supported on RTX PRO 6000 Blackwell Server Edition in SPT CC + Intel TDX
    with driver 595.84 / CUDA 13.2?
  2. If supported: is error 10 at nvEncInitializeEncoder a known bug? Fixed in which
    driver / VBIOS?
  3. If not supported: which official document states that? Should playback encode
    be done outside the TEE (CPU encode or non-CC GPU)?
  4. On this SKU, is a CC-off (plaintext) control expected to succeed?
Already ruled out
  • No NVENC silicon. That is H200: OpenEncodeSessionEx error 2 = UNSUPPORTED_DEVICE.
    Here OpenEncodeSessionEx succeeds; only InitializeEncoder fails.
  • AppEncCuda-only CUDA buffer registration (ffmpeg fails at the same API).
  • Input YUV / resolution (lavfi testsrc 1920×1080; also retried 1920×1088 NV12).
  • Typical GeForce session-cap or 1–2 GB vGPU OOM: this is the first session on 96 GB.
This is more than an encoder-error question if NVIDIA’s official answer is that encoding must occur outside the TEE. That would require protected data to cross from the confidential-computing domain into a plaintext or less-trusted execution domain.
I have developed a patent-pending hardware-enforced control boundary for that exact class of transfer. It uses mutually exclusive connectivity with physical break-before-make switching: the trusted side is disconnected from the transfer path first, a guaranteed interval exists in which neither domain is connected through that path, and only validated or sanitized data is released to the destination. If validation fails, the transfer is blocked and the destination remains isolated, while the trusted system continues operating locally.
This would not fix an unsupported NVENC configuration or driver bug. But if external encoding is NVIDIA’s prescribed workaround, what hardware-enforced mechanism prevents an unintended live path between the TDX-protected workload and the non-CC encoder? Is there an NVIDIA reference architecture for that transfer boundary?
