i am using the Video SDK (nvEncodeAPI.h … ) to encode and decode multiple streams.
With a Quadro M2000M it is possible to encode 6 Streams 1080p59.94 simultaneously to h.264.
I assumed that switching to a faster hardware would increase the possibility to encode mor streams.
I tried with a Quadro P2000 and a Quadro P5000. The performance was nearly identical.
Width 7 streams the framrate drops to ~55fps and so on if stremas are increased.
Is there any setup trick to encrease the performance???
Any parameters to set for the encoder?
