Nvfortran openacc compilation error related to fortran derived type
I used nvfortran-20.9 to compile the following code (nvfortran -acc *.f90 ) and it produces the error:
Module variables used in acc routine need to be in !$acc declare create() - ._dtInit0058
It seems the error is related to the initialization of FaceFluxTest%DiffBb. If I remove the initialization or remove a few variables from the derived type, then there will be no error message.
Did I misuse openacc features? Could you explain what is wrong? Thanks!
module ModAdvance
  implicit none
  public
  integer, parameter:: MinI = -1, MaxI = 4, MinJ = 1, MaxJ = 1, MinK = 1, MaxK = 1, MaxBlock = 2, nVar=2
  type, public :: FaceFluxTest
     integer :: ii
     integer :: iLeft,  jLeft, kLeft
     integer :: iRight, jRight, kRight
     integer :: iBlockFace
     real :: r1, r2, r3, r4, r5, r6, r7, r8       ! OK if remove this line
     real :: CmaxDt, c1, c2, c3, c4, c5, c6, c7
     real :: Area2, AreaX, AreaY, AreaZ, Area
     real :: DeltaBnL, DeltaBnR
     real :: DiffBb = 0.0         ! OK if no initialization.
  end type FaceFluxTest
end module ModAdvance
module ModFace
  use ModAdvance
  implicit none
  public
  contains
    subroutine  calc_face_value(iBlock)
      !$acc routine vector
      integer, intent(in):: iBlock
      type(FaceFluxTest) :: FFT
      integer:: i,j,k,iVar
      !$acc loop vector collapse(3) private(FFT)
      do k = MinK, MaxK; do j = MinJ, MaxJ; do i = MinI, MaxI
         FFT%ii = k
      end do; end do; end do
  end subroutine calc_face_value
end module ModFace
program main
  use ModAdvance
  use ModFace, ONLY: calc_face_value
  implicit none
  integer:: iBlock
  !$acc parallel loop gang
  do iBlock = 1, MaxBlock
     call calc_face_value(iBlock)
  end do
end program main
The problem here is that the data type is statically initialized. The initialization value is stored as a static data segment on the host which is not accessible on the device. You’ll need to remove the static initialization of DiffBb in order to get this to work.
-Mat
Hi Mat,
Thanks very much for your explanation!
Actually, this is also my first guess until I found it also compiles if I remove a few scalars (for example, the line ‘real :: r1, r2, r3, r4, r5, r6, r7, r8’) from the derived type. I think it will be useful if the compilation error message can be more consistent and informative.
It still fails in the same way for me even if I comment out one or all of “r” variables. Hence I’m unclear why this would this would allow it to compile for you nor does it make much sense.
We can try to determine why, but since the main problem is the static data initialization, I’m not sure it’s worth the effort.
Hi Mat,
Following your suggestions to remove the static data initialization, the code can compile now. But I still can not run the code.
To show the problem clearer, I further simplified the code. The following version can compile and produce correct results:
module ModTest
  implicit none
  type:: FaceFluxTest
  integer, parameter:: MinI = -1, MaxI = 4, MinJ = 1, MaxJ = 2, MinK = 1, MaxK = 2, MaxBlock = 2, nVar=2
  real:: State_VGB(nVar,MinI:MaxI,MinJ:MaxJ,MinK:MaxK,MaxBlock)
  !$acc declare create(State_VGB)
contains
  subroutine sub_main
  integer:: iBlock
  !$acc parallel loop gang present(state_vgb)
        FFT%iBlockFace = iBlock
        State_VGB(1,i,j,k,iBlock) = FFT%iBlockFace
        ! More calculation here
  end do
  !$acc update host(state_vgb)
  write(*,*)'state_vgb = ', State_VGB
  end subroutine sub_main
end module ModTest
program main
  use ModTest
  call sub_main
end program main
However, if I move the inner loop into a separate subroutine:
module ModTest
  implicit none
  type:: FaceFluxTest
contains
  subroutine sub_inner(iBlock)
    integer, intent(in)::iBlock
  end subroutine sub_inner
  subroutine sub_main
    integer:: iBlock
       call sub_inner(iBlock)
    end do
end module ModTest
program main
  use ModTest
  call sub_main
end program main
I compiled the code above with
nvfortran -acc -g -O0 -Mcuda=debug -Minfo=all file.f90
and run with cuda-gdb, it produce the following error:
CUDA Exception: Warp Illegal Address
The exception was triggered at PC 0x154c1d8 (bug_report_fail.f90:22)
Thread 1 "a.out" received signal CUDA_EXCEPTION_14, Warp Illegal Address.
[Switching focus to CUDA kernel 0, grid 1, block (0,0,0), thread (0,0,0), device 0, sm 0, warp 0, lane 0]
0x000000000154c5a8 in modtest_sub_inner_ () at bug_report_fail.f90:24
24	       State_VGB(1,i,j,k,iBlock) = FFT%iBlockFace
Why it does not work?
Looks like a code gen issue so I’ve added a problem report, TPR #29601, and sent it to engineering for further review.
Note that it does appear that the compiler is implicitly privatizing FFT so the work around is to remove the “private(FFT)” clause.
Hi Mat,
I did some experiments after removing ‘private(FFV)’. Here is the code I used:
module ModTest
  implicit none
  type:: FaceFluxTest
contains
       FFT%iBlockFace = i
  subroutine sub_main
    integer:: iBlock
    end do
end module ModTest
program main
  use ModTest
  call sub_main
end program main
The results are wrong. It seems FFT is not private by default.
What’s the results you’re seeing? When I compare the output with and without OpenACC, the results are the same:
% nvfortran test1.f90 -acc -V21.1 ; a.out
 state_vgb =    -1.000000        0.000000        0.000000        0.000000
    1.000000        0.000000        2.000000        0.000000
    3.000000        0.000000        4.000000        0.000000
 % nvfortran test1.f90 -V21.1 ; a.out
If it is compiled with ‘nvfortran -acc -g -O0 test.f90’, the output is:
 state_vgb =     4.000000        0.000000        4.000000        0.000000
If I remove ‘-g’, it produces correct results. The nvfortran version is 20.9.
This is just a sample code. In general, I guess there is no guarantee that the local derived type FFT will be private without the ‘private(FFT)’ clause, right? Is there a simple way to check whether the compiler implicitly privatizes a variable? Thanks!
Unfortunately, no. I inspected the generated code and from that concluded that each thread is getting it’s own private copy of FFT. Not sure what’s going wrong when “-g” is applied.
Adding the private clause is the correct way to go, but as noted, there does appear to be a compiler issue when adding UDTs to a private clause in a vector routine.
