Nvidia 520 + 4090 + Ubuntu 22.10
Hi Nvidia, so here is my first post about an issue I am having were games only last around 10 to 20 minutes, these are the only issues I found with dmesg:
i2c i2c-2: Failed to register i2c client ITE8853:00 at 0x4e (-16)
Dev loop0: unable to read RDB block 8
snd_hda_intel 0000:00:1f.3: no codecs found!
ACPI BIOS Error (bug): Failure creating named object [_SB.PC00.PEG1.PEGP._DSM.USRG], AE_ALREADY_EXISTS (20220331/dsfield-184)
ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20220331/dswload2-477)
ACPI Error: Aborting method _SB.PC00.PEG1.PEGP._DSM due to previous error (AE_ALREADY_EXISTS) (20220331/psparse-529)
Dev loop10: unable to read RDB block 8
Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[drm:nv_drm_master_set [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Or if I run “dmesg -t -l crit -l err | sort | uni” then I get the simplified version:
As you can see there are a couple of Nvidia related errors here.
My specs are:
MOBO: Asus Z790 Hero (Firmware 0703)
CPU: Intel i9 13900k
RAM: G.Skill Trident Z5 RGB 2x32 (2 Kits) DDR5 6000Mhz (Total 128GB) (Not in XMP Mode Because of 4 Ram Issues. Only works with 2)
VID: ZOTAC GAMING GeForce RTX 4090 AMP Extreme AIRO (Driver 520 Ubuntu / 526 Windows 11)
COOL: Corsair iCUE H150i Elite Capellix Liquid CPU Cooler, RGB Pump + Fans (360mm Model) + 3 Fan Kit
NVME: 2x WD_BLACK 2TB SN850X NVMe Internal Gaming SSD Solid State Drive with Heatsink - Works with Playstation 5, Gen4 PCIe, M.2 2280
PSU: Asus Thor 1200w
CASE: Lian Li 011 Dynamic Black
OS: Ubuntu 22.10
WM: Wayland
During the time it works, games play great with very high FPS (Both Windows and Ubuntu have very similar FPS) (Until the 10-20 minute mark). This happens when playing games, or simply in the desktop doing nothing. Thank you again, and sorry for so many links and stuff, just making sure I can give as much information as possible in helping figure this out together.
nvidia-bug-report.log.gz (312.7 KB)
Please run nvidia-bug-report.sh as root after the issue surfaces and attach the resulting nvidia-bug-report.log.gz file to your post.
Yes thank you I will.
Hi, here is the document. Thank you for the help.
Seems to be a bug in 520.56, drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Please check if this is a workaround:
https://forums.developer.nvidia.com/t/ubuntu-18-04-3-blank-screen-at-startup-with-430-drivers-and-gtx-960/107501/2?u=generix
If possible, please also try the 525.53 beta driver.
Yes, thank you I will test right away.
Okay I tried the workaround, the games lasted a bit longer, but crashed again. This was without the 525 driver. I am waiting for the Ubuntu 22.10 version of it here Proprietary GPU Drivers : “Graphics Drivers” team to start testing and I will update you as soon as I get it. Thank you.
Hi again, so I have tested 20+ games so far. The crashing and freezing either does not happen anymore or when it happens it is always the one on this bug report file. So things are getting better. Do not I am still using 520 instead of 523 since it is still not available on the PPA for Ubuntu
[18703.461900] ------------[ cut here ]------------
[18703.461904] Unhandled error in __nv_drm_gem_user_memory_handle_vma_fault: -22
[18703.461919] WARNING: CPU: 2 PID: 2125 at build/nvidia/520.56.06/build/nvidia-drm/nvidia-drm-gem-user-memory.c:131 __nv_drm_gem_user_memory_handle_vma_fault+0xbe/0xd0 [nvidia_drm]
[18703.461926] Modules linked in: mptcp_diag tcp_diag udp_diag raw_diag inet_diag unix_diag snd_seq_dummy rfcomm snd_hrtimer cmac algif_hash algif_skcipher af_alg vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) bnep binfmt_misc nls_iso8859_1 nvidia_uvm(PO) snd_sof_pci_intel_tgl snd_sof_intel_hda_common nvidia_drm(PO) soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp intel_rapl_msr snd_sof intel_rapl_common intel_tcc_cooling snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi x86_pkg_temp_thermal nvidia_modeset(PO) intel_powerclamp snd_hda_codec_hdmi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine btusb snd_hda_intel uvcvideo snd_intel_dspcfg btrtl snd_intel_sdw_acpi btbcm snd_hda_codec snd_usb_audio videobuf2_vmalloc videobuf2_memops kvm_intel videobuf2_v4l2 snd_hda_core videobuf2_common snd_usbmidi_lib btintel snd_seq_midi iwlmvm btmtk videodev snd_hwdep kvm snd_seq_midi_event
[18703.461960] mac80211 bluetooth snd_rawmidi crct10dif_pclmul ecdh_generic nvidia(PO) mc snd_pcm libarc4 input_leds joydev ghash_clmulni_intel ecc snd_seq aesni_intel iwlwifi mei_hdcp cmdlinepart mei_pxp drm_kms_helper crypto_simd spi_nor cryptd snd_seq_device intel_cstate eeepc_wmi wmi_bmof mtd asus_nb_wmi snd_timer fb_sys_fops cfg80211 syscopyarea snd mei_me sysfillrect ucsi_acpi soundcore sysimgblt typec_ucsi mei typec acpi_pad mac_hid acpi_tad nct6775 nct6775_core hwmon_vid coretemp msr parport_pc ppdev drm lp parport ramoops pstore_blk reed_solomon pstore_zone efi_pstore ip_tables x_tables autofs4 hid_logitech_hidpp hid_logitech_dj hid_generic usbhid hid nvme nvme_core mfd_aaeon asus_wmi sparse_keymap platform_profile i2c_i801 crc32_pclmul intel_lpss_pci spi_intel_pci xhci_pci thunderbolt ahci igc intel_lpss i2c_smbus spi_intel libahci xhci_pci_renesas idma64 vmd wmi video pinctrl_alderlake
[18703.462001] CPU: 2 PID: 2125 Comm: Xorg Tainted: P OE 5.19.0-23-generic #24-Ubuntu
[18703.462003] Hardware name: ASUS System Product Name/ROG MAXIMUS Z790 HERO, BIOS 0703 11/01/2022
[18703.462004] RIP: 0010:__nv_drm_gem_user_memory_handle_vma_fault+0xbe/0xd0 [nvidia_drm]
[18703.462007] Code: 31 f6 31 ff 45 31 c0 c3 cc cc cc cc 0f 0b 89 c2 48 c7 c6 80 97 9b c0 48 c7 c7 92 9a 9b c0 c6 05 ee 77 00 00 01 e8 b7 b9 a9 ea <0f> 0b eb a6 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 0f 1f 44 00
[18703.462009] RSP: 0018:ffffb9650a3439d0 EFLAGS: 00010246
[18703.462010] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[18703.462011] RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
[18703.462012] RBP: ffffb9650a3439e0 R08: 0000000000000000 R09: 0000000000000000
[18703.462012] R10: 0000000000000000 R11: 0000000000000000 R12: ffff9f0d9442ef70
[18703.462013] R13: ffff9f0d9442ef70 R14: 00000000000007c0 R15: ffff9f0b75ee9ac0
[18703.462014] FS: 00007fd61ff96a80(0000) GS:ffff9f2a5f080000(0000) knlGS:0000000000000000
[18703.462015] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[18703.462015] CR2: 00007fd6207ec000 CR3: 0000000129090006 CR4: 0000000000770ee0
[18703.462016] PKRU: 55555554
[18703.462017] Call Trace:
[18703.462018]
[18703.462020] nv_drm_vma_fault+0x28/0x50 [nvidia_drm]
[18703.462023] __do_fault+0x39/0x120
[18703.462027] do_fault+0x19d/0x300
[18703.462028] handle_pte_fault+0x117/0x240
[18703.462030] __handle_mm_fault+0x696/0x740
[18703.462032] handle_mm_fault+0xba/0x2a0
[18703.462034] ? check_vma_flags+0xa0/0x1a0
[18703.462035] __get_user_pages+0x20a/0x410
[18703.462037] __gup_longterm_locked+0x12d/0x150
[18703.462039] get_user_pages+0x3d/0x90
[18703.462040] os_lock_user_pages+0xc5/0x230 [nvidia]
[18703.462245] _nv000621rm+0x8a/0x170 [nvidia]
[18703.462435] WARNING: kernel stack frame pointer at 00000000d83ce8e2 in Xorg:2125 has bad value 0000000020852251
[18703.462437] unwind stack type:0 next_sp:0000000000000000 mask:0x2 graph_idx:0
[18703.462438] 00000000176f3ddf: ffffb9650a3439f0 (0xffffb9650a3439f0)
[18703.462440] 00000000bfc28b2f: ffffffffc09b4018 (nv_drm_vma_fault+0x28/0x50 [nvidia_drm])
[18703.462444] 00000000c233bf76: ffffb9650a343a18 (0xffffb9650a343a18)
[18703.462444] 00000000d700eb62: ffffffffaa9424d9 (__do_fault+0x39/0x120)
[18703.462447] 0000000060b60bf9: ffffb9650a343a98 (0xffffb9650a343a98)
[18703.462448] 00000000f196fde7: 0000000000000001 (0x1)
[18703.462448] 00000000644ce037: ffff9f0d9442ef70 (0xffff9f0d9442ef70)
[18703.462449] 00000000f2a47c5e: ffffb9650a343a48 (0xffffb9650a343a48)
[18703.462450] 00000000594bf005: ffffffffaa94390d (do_fault+0x19d/0x300)
[18703.462451] 00000000ae0ef95f: ffffb9650a343a98 (0xffffb9650a343a98)
[18703.462452] 0000000052dcc72c: 0000000000000948 (0x948)
[18703.462452] 000000007baba3a4: 0000000133ac0067 (0x133ac0067)
[18703.462453] 000000000539317b: 00000000000007c0 (0x7c0)
[18703.462454] 000000003537c8e1: ffffb9650a343a70 (0xffffb9650a343a70)
[18703.462454] 0000000043572d08: ffffffffaa9449d7 (handle_pte_fault+0x117/0x240)
[18703.462456] 0000000010c20a64: ffffb9650a343a98 (0xffffb9650a343a98)
[18703.462457] 0000000034636493: ffff9f0b4622c7c0 (0xffff9f0b4622c7c0)
[18703.462457] 000000005f1a7a75: 0400000000000080 (0x400000000000080)
[18703.462458] 00000000e529bf6f: ffffb9650a343b38 (0xffffb9650a343b38)
[18703.462459] 0000000080e7b872: ffffffffaa947b96 (__handle_mm_fault+0x696/0x740)
[18703.462460] 0000000051960e76: ffff9f0b5d892ec0 (0xffff9f0b5d892ec0)
[18703.462461] 00000000b4086708: 0000000100000001 (0x100000001)
[18703.462462] 00000000a452ba88: 00007fd61f129000 (0x7fd61f129000)
[18703.462462] 000000005d017005: ffff9f0d9442ef70 (0xffff9f0d9442ef70)
[18703.462463] 0000000017504f22: 0000000000100cca (0x100cca)
[18703.462464] 0000000033ba3c25: 0000000000100000 (0x100000)
[18703.462464] 00000000b27ff658: 00007fd61f129000 (0x7fd61f129000)
[18703.462465] 00000000e4675b5d: 00007fd61f129000 (0x7fd61f129000)
[18703.462466] 00000000e7c68b77: 0000000000000801 (0x801)
[18703.462466] 000000004f9456cb: ffff9f0b4622c7c0 (0xffff9f0b4622c7c0)
[18703.462467] 0000000096aa0462: ffff9f0b75ee9ac0 (0xffff9f0b75ee9ac0)
[18703.462468] 00000000db60efbd: 0000000000000000 …
[18703.462468] 00000000c3a64ec1: be74cb0d7bf40500 (0xbe74cb0d7bf40500)
[18703.462469] 00000000cb73759e: 0000000000000001 (0x1)
[18703.462469] 00000000427840ce: ffff9f0d9442ef70 (0xffff9f0d9442ef70)
[18703.462470] 00000000376ba113: 00007fd61f129000 (0x7fd61f129000)
[18703.462470] 00000000f0b31140: 0000000000000000 …
[18703.462471] 000000001692bc44: ffffb9650a343b78 (0xffffb9650a343b78)
[18703.462471] 0000000085e1c669: ffffffffaa947cfa (handle_mm_fault+0xba/0x2a0)
[18703.462473] 000000005f0480ee: ffffffffaa936f00 (check_vma_flags+0xa0/0x1a0)
[18703.462474] 000000008e5f25f3: 0000000000000207 (0x207)
[18703.462475] 000000009e9c1b47: 0000000000000000 …
[18703.462475] 00000000e2445e6f: ffff9f0b5d892ec0 (0xffff9f0b5d892ec0)
[18703.462476] 00000000604a7018: 0000000000000000 …
[18703.462476] 000000001b0927f5: 0000000000000001 (0x1)
[18703.462477] 000000001f52cff4: ffffb9650a343c00 (0xffffb9650a343c00)
[18703.462477] 00000000ebba7bbf: ffffffffaa9397fa (__get_user_pages+0x20a/0x410)
[18703.462479] 00000000967b5589: ffff9f0b66324d40 (0xffff9f0b66324d40)
[18703.462479] 000000002356e72d: ffff9f0d00000001 (0xffff9f0d00000001)
[18703.462480] 00000000d5cca09d: ffff9f0b4273b1f8 (0xffff9f0b4273b1f8)
[18703.462480] 000000005d1ea254: 0000000000000000 …
[18703.462481] 000000000aad71c6: 0000000000000001 (0x1)
[18703.462481] 000000009ed8a3d9: 00007fd61f129000 (0x7fd61f129000)
[18703.462482] 00000000e736a285: ffff9f0d9442ef70 (0xffff9f0d9442ef70)
[18703.462482] 0000000004bf60be: 0000000000000000 …
[18703.462483] 00000000770156d6: be74cb0d7bf40500 (0xbe74cb0d7bf40500)
[18703.462483] 000000003469c369: 00007fd61f129000 (0x7fd61f129000)
[18703.462484] 00000000da754732: 0000000000000000 …
[18703.462484] 000000008b584bed: ffff9f0b4273b1f8 (0xffff9f0b4273b1f8)
[18703.462485] 000000008af2f6a0: ffff9f0b5d892ec0 (0xffff9f0b5d892ec0)
[18703.462485] 00000000b79ac887: 0000000000000007 (0x7)
[18703.462486] 00000000c6165ced: ffffb9650a343c58 (0xffffb9650a343c58)
[18703.462487] 0000000015ac6f68: ffffffffaa939e8d (__gup_longterm_locked+0x12d/0x150)
[18703.462488] 00000000ea544cb3: 0000000000000000 …
[18703.462488] 000000003db5cfb4: be74cb0d7bf40500 (0xbe74cb0d7bf40500)
[18703.462489] 00000000045aba53: 0000000000000010 (0x10)
[18703.462489] 00000000bb6cec1b: ffffb9650a343c88 (0xffffb9650a343c88)
[18703.462490] 00000000953c0c20: 0000000000000001 (0x1)
[18703.462491] 00000000d9101249: 0000000000000001 (0x1)
[18703.462491] 000000000a5cae2f: 0000000000000000 …
[18703.462491] 00000000e3c70335: ffff9f0b73eeafb8 (0xffff9f0b73eeafb8)
[18703.462492] 0000000058e1c30e: ffff9f0b5d892ec0 (0xffff9f0b5d892ec0)
[18703.462492] 0000000048795803: ffffb9650a343c68 (0xffffb9650a343c68)
[18703.462492] 000000001c9bcd2f: ffffffffaa939eed (get_user_pages+0x3d/0x90)
[18703.462493] 00000000deafae7d: ffffb9650a343cc0 (0xffffb9650a343cc0)
[18703.462493] 0000000036c8d9e6: ffffffffc18f7ed5 (os_lock_user_pages+0xc5/0x230 [nvidia])
[18703.462578] 000000008af2b94f: ffff9f0b5d892f38 (0xffff9f0b5d892f38)
[18703.462578] 000000009974b8c0: 00007fd61f129000 (0x7fd61f129000)
[18703.462579] 00000000f9356197: ffff9f0b4273b1f8 (0xffff9f0b4273b1f8)
[18703.462579] 00000000ce4eb573: be74cb0d7bf40500 (0xbe74cb0d7bf40500)
[18703.462579] 000000002c51842f: ffff9f0c9b1146c0 (0xffff9f0c9b1146c0)
[18703.462580] 000000000b850b77: 00007fd61f129000 (0x7fd61f129000)
[18703.462580] 000000004c183f0b: 0000000000000001 (0x1)
[18703.462580] 00000000fc2d3e9f: ffff9f0b78047400 (0xffff9f0b78047400)
[18703.462581] 00000000cd03551b: 000000000000004a (0x4a)
[18703.462581] 00000000d83ce8e2: ffff9f0b73eeafb0 (0xffff9f0b73eeafb0)
[18703.462581] 00000000678b535a: ffffffffc22a505a (_nv000621rm+0x8a/0x170 [nvidia])
[18703.462717] 00000000cd9c756e: 0000000000000000 …
[18703.462717] 00000000762f8a56: ffff9f0c9b1146c0 (0xffff9f0c9b1146c0)
[18703.462718] 000000002f02de3f: 00000000000000b8 (0xb8)
[18703.462718] 0000000095496391: ffffffffc22a5a20 (_nv000676rm+0x8e0/0xab0 [nvidia])
[18703.462841] 0000000060467c53: 0000000000000001 (0x1)
[18703.462842] 00000000379fb493: 0000000000000000 …
[18703.462842] 00000000dfc7b1a2: ffff9f0b78047400 (0xffff9f0b78047400)
[18703.462842] 000000003338f0c6: ffffffffc22a5178 (_nv000676rm+0x38/0xab0 [nvidia])
[18703.462963] 000000001f01cc54: ffff9f0b73ee8000 (0xffff9f0b73ee8000)
[18703.462963] 000000009c18400c: ffffffffc4b5a7e0 (nv_kthread_q+0x40/0xfffffffffd855860 [nvidia])
[18703.463050] 00000000bb783b29: ffffb9650a343e80 (0xffffb9650a343e80)
[18703.463051] 00000000985c1a8b: ffff9f0b78047400 (0xffff9f0b78047400)
[18703.463051] 00000000706cb3da: 000000000000004a (0x4a)
[18703.463052] 0000000047f27ac0: ffffffffc22abd74 (rm_ioctl+0x54/0xb0 [nvidia])
[18703.463170] 00000000cb95948a: 000000b87bf40500 (0xb87bf40500)
[18703.463171] 000000006fc30b2c: ffff9f0c9b1146c0 (0xffff9f0c9b1146c0)
[18703.463171] 00000000bb45aa89: 000000000000084d (0x84d)
[18703.463172] 000000008e61f05f: 0000000101d30c4e (0x101d30c4e)
[18703.463172] 000000006106a882: 003d19bcdfe19900 (0x3d19bcdfe19900)
[18703.463173] 000000008688fb9a: 003d19bdce4cc100 (0x3d19bdce4cc100)
[18703.463173] 00000000f8efc12a: 003d19c3dc054500 (0x3d19c3dc054500)
[18703.463173] 00000000d4d8101a: 003d19bd57172d00 (0x3d19bd57172d00)
[18703.463174] 0000000040102eec: 0000000000000000 …
[18703.463174] 00000000c30edcc0: 0000012000000002 (0x12000000002)
[18703.463174] 00000000cd45eef5: 000000000000084d (0x84d)
[18703.463175] 00000000b44f2446: 0000000000000000 …
[18703.463175] 0000000038f7649e: fffffff000000000 (0xfffffff000000000)
[18703.463175] 000000003c05a8fc: ffffffffc4b91c50 (_nv037177rm+0x90/0xfffffffffd81e440 [nvidia])
[18703.463262] 000000002af5d7d8: 0000000000000010 (0x10)
[18703.463263] 00000000db4e9239: 0000000000000000 …
[18703.463263] 00000000d1747cda: ffff9f0c9b1146c0 (0xffff9f0c9b1146c0)
[18703.463263] 00000000121f2bed: 00000000000000b8 (0xb8)
[18703.463264] 00000000b38eb11f: ffff9f0b78047400 (0xffff9f0b78047400)
[18703.463264] 0000000029bc9eb4: ffffffffc4b5a7e0 (nv_kthread_q+0x40/0xfffffffffd855860 [nvidia])
[18703.463352] 00000000b89c4867: ffffffffc18e8cc6 (nvidia_ioctl+0x6e6/0x8e0 [nvidia])
[18703.463431] 00000000677b0849: ffff9f0b73ee8000 (0xffff9f0b73ee8000)
[18703.463431] 00000000ada157fa: 00007fff5e504dd0 (0x7fff5e504dd0)
[18703.463431] 0000000008db6ea6: ffff9f0b78047490 (0xffff9f0b78047490)
[18703.463432] 00000000146d4bbd: ffffffff0000004a (0xffffffff0000004a)
[18703.463432] 00000000c59f3d52: 0000000000000000 …
[18703.463432] 000000007c94c0e4: be74cb0d7bf40500 (0xbe74cb0d7bf40500)
[18703.463433] 00000000f82b3475: 00000000000000ff (0xff)
[18703.463433] 0000000064358860: ffff9f0b41521500 (0xffff9f0b41521500)
[18703.463433] 00000000c477148f: 00000000c0b8464a (0xc0b8464a)
[18703.463434] 00000000ea6b6df2: ffff9f0b58a927f0 (0xffff9f0b58a927f0)
[18703.463434] 00000000a848c0bb: ffff9f0b41521501 (0xffff9f0b41521501)
[18703.463434] 0000000055c73d6b: ffffb9650a343eb8 (0xffffb9650a343eb8)
[18703.463435] 00000000309bd3f7: ffffffffc18fb995 (nvidia_frontend_unlocked_ioctl+0x55/0xa0 [nvidia])
[18703.463515] 0000000026f8f7c2: 000000000000000e (0xe)
[18703.463515] 00000000e494c3fe: 000000000000000e (0xe)
[18703.463516] 000000001fbc0ca6: ffff9f0b41521500 (0xffff9f0b41521500)
[18703.463516] 00000000510514a8: 00000000c0b8464a (0xc0b8464a)
[18703.463516] 00000000b8a15aed: 00007fff5e504dd0 (0x7fff5e504dd0)
[18703.463517] 000000001653c3dd: ffffb9650a343ef0 (0xffffb9650a343ef0)
[18703.463517] 0000000055a2d333: ffffffffaaa0cbed (__x64_sys_ioctl+0x9d/0xe0)
[18703.463519] 0000000095884c1e: ffffb9650a343f58 (0xffffb9650a343f58)
[18703.463519] 00000000278e7818: 0000000000000000 …
[18703.463519] 000000007844e2aa: ffffb9650a343f48 (0xffffb9650a343f48)
[18703.463520] 0000000038040f86: ffffffffab513168 (do_syscall_64+0x58/0x90)
[18703.463521] 00000000632090ab: ffffffffab513177 (do_syscall_64+0x67/0x90)
[18703.463522] 000000003a495860: ffffffffab518806 (syscall_exit_to_user_mode+0x26/0x50)
[18703.463523] 00000000ab90fee7: 0000000000000000 …
[18703.463523] 00000000613b0a30: ffffb9650a343f48 (0xffffb9650a343f48)
[18703.463523] 00000000c8b1643a: ffffffffab513177 (do_syscall_64+0x67/0x90)
[18703.463524] 00000000ef4a4dc9: 0000000000000000 …
[18703.463524] 000000002e58476a: ffffffffab60009b (entry_SYSCALL_64_after_hwframe+0x63/0xcd)
[18703.463526] 0000000088646ab3: 000000000000004a (0x4a)
[18703.463526] 000000005e3d342d: 00000000c0b8464a (0xc0b8464a)
[18703.463526] 00000000d64e5dd3: 00007fff5e504c30 (0x7fff5e504c30)
[18703.463527] 00000000764df440: 000000000000000e (0xe)
[18703.463527] 00000000678ce5b7: 00007fff5e504dd0 (0x7fff5e504dd0)
[18703.463527] 0000000050a0dc5f: 00000000000000b8 (0xb8)
[18703.463528] 00000000b20ea265: 0000000000000246 (0x246)
[18703.463528] 00000000ae191bed: 0000000000000001 (0x1)
[18703.463528] 0000000081dd5539: 00007fff5e504de4 (0x7fff5e504de4)
[18703.463529] 000000007049097b: 00007fff5e504dd0 (0x7fff5e504dd0)
[18703.463529] 0000000094b1d25d: ffffffffffffffda (0xffffffffffffffda)
[18703.463530] 000000000499d860: 00007fd620312d8f (0x7fd620312d8f)
[18703.463531] 00000000bf296997: 00007fff5e504dd0 (0x7fff5e504dd0)
[18703.463531] 00000000c37e304b: 00000000c0b8464a (0xc0b8464a)
[18703.463531] 0000000070afa3c9: 000000000000000e (0xe)
[18703.463532] 00000000123eb9a8: 0000000000000010 (0x10)
[18703.463532] 00000000a8482577: 00007fd620312d8f (0x7fd620312d8f)
[18703.463532] 000000004d2ae8fb: 0000000000000033 (0x33)
[18703.463532] 000000008ad4f378: 0000000000000246 (0x246)
[18703.463533] 0000000019622a46: 00007fff5e504bd0 (0x7fff5e504bd0)
[18703.463533] 00000000bc255ecf: 000000000000002b (0x2b)
[18703.463534] ? _nv000676rm+0x8e0/0xab0 [nvidia]
[18703.463658] ? _nv000676rm+0x38/0xab0 [nvidia]
[18703.463777] ? rm_ioctl+0x54/0xb0 [nvidia]
[18703.463895] ? nvidia_ioctl+0x6e6/0x8e0 [nvidia]
[18703.463974] ? nvidia_frontend_unlocked_ioctl+0x55/0xa0 [nvidia]
[18703.464054] ? __x64_sys_ioctl+0x9d/0xe0
[18703.464055] ? do_syscall_64+0x58/0x90
[18703.464056] ? do_syscall_64+0x67/0x90
[18703.464057] ? syscall_exit_to_user_mode+0x26/0x50
[18703.464058] ? do_syscall_64+0x67/0x90
[18703.464058] ? entry_SYSCALL_64_after_hwframe+0x63/0xcd
[18703.464060]
[18703.464060] —[ end trace 0000000000000000 ]—
[18703.464063] Cannot map memory with base addr 0x7fd61f129000 and size of 0x1 pages
[18703.464214] Cannot map memory with base addr 0x7fd61f128000 and size of 0x1 pages
[18703.464671] Cannot map memory with base addr 0x7fd61f127000 and size of 0x1 pages
[18703.478574] Cannot map memory with base addr 0x7fd61f126000 and size of 0x1 pages
[18703.478918] Cannot map memory with base addr 0x7fd61f125000 and size of 0x1 pages
[18703.508137] Cannot map memory with base addr 0x7fd61f124000 and size of 0x1 pages
[18703.508530] Cannot map memory with base addr 0x7fd61f123000 and size of 0x1 pages
[18703.510033] Cannot map memory with base addr 0x7fd61f122000 and size of 0x1 pages
[18703.510308] Cannot map memory with base addr 0x7fd61f121000 and size of 0x1 pages
[18703.571691] Cannot map memory with base addr 0x7fd0187f9000 and size of 0x12a8 pages
[18703.580239] Cannot map memory with base addr 0x7fd012d58000 and size of 0x12a8 pages
Anything else you wish me to do?
nvidia-bug-report.log.gz (1.0 MB)
Just wanted to update that after updating to the 525.60 version ALL issues were resolved. The exception is the following which does not affect gaming experience and some of the tests I have done at https://youtube.com/@xtremelinux
If I update to kernel 6.0 or 6.1 almost all issues shown in dmesg go away, but do note that on 5.19 they do nothing nor create a problem when testing. So from the side of Nvidia, 525.60 just solved many issue in one go.
Just updating this here. On Driver 525.78 the following issue still exists:
I think it is related to this issue above:
ACPI Warning: _SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Here is another issue with Driver 525.78:
NVRM: Xid (PCI:0000:01:00): 69, pid=28696, name=GameThread, Class Error: ChId 001f, Class 0000c997, Offset 00001230, Data 80000001, ErrorCode 0000000c
This was when playing Cyberpunk.
Hi I have the Nvidia Driver version 535.161.07 on Ubuntu 22.04 with a 4090, i7 13700kf, and Asus Apex Encore with the z790 chipset and I am getting the same error.
Another user found out that Xid 69 on CP2077 is related to VKD3D:
https://github.com/HansKristian-Work/vkd3d-proton/issues/1869
Good to know. I personally don’t own CP2077.
I’m chiming in to ask for assistance with the i2c i2c-2: Failed to register i2c client ITE8853:00 at 0x4e (-16) error.
The ITE8853 is a specific Motherboard ACPI Issue last time I researched. This is solved (or will be solved depending when this message is read) on future Kernel versions, not related to Nvidia just in case. If you have one of the latest Asus motherboards for example (Z690 and up like in my case the Z790) and probably other models, you will find this issue. It is not critical or harmful, just need to wait for better compatibility for that specific Driver.
I have the Asus hero Z790 and I get that issue.
For the Xid errors I reported, I am on Nvidia 550.54.14 at the moment with cyberpunk 2077 version 2.12.
Before the game would play, on the best day, about 30 minutes. On a typical day 15 to 20 minutes before the Xid would crash it. I am not gonna say I tested for 30 minutes. The 2nd day I updated to the 550 driver I tested possibly for 4 hours. There was NO crash. The game was tested on 4K and I even did a video at https://www.youtube.com/@xtremelinux (Along with other Nvidia + Linux tests) and I even was able to test with the Corporate path which crashed super fast after arriving at the Bar.
No crash. I did also update the motherboard to Firmare 2002. I am however still getting warnings, but those are between Linux and the Asus motherboard (And the lack of many small details from Asus towards Linux. Not bad or critical, but just warning spam on dmesg).
But related to Nvidia directly, I am still searching for something that critically kills a game to report with the 550. At least with the Nvidia 4090.
Thanks for the reply. Good to know, I will update my driver to 550 if I can.
