We’re running into an issue getting nvidia-container-toolkit RPMs to install on RHEL/Rocky hosts that are setup in FIPS mode. We see this:
Upgrading:
libnvidia-container-tools x86_64 1.17.8-1 cuda-rhel8-x86_64 40 k
libnvidia-container1 x86_64 1.17.8-1 cuda-rhel8-x86_64 1.0 M
nvidia-container-toolkit x86_64 1.17.8-1 cuda-rhel8-x86_64 1.2 M
nvidia-container-toolkit-base x86_64 1.17.8-1 cuda-rhel8-x86_64 5.8 M
Transaction Summary
Upgrade 4 Packages
Total download size: 8.0 M
Is this ok [y/N]: y
Downloading Packages:
(1/4): libnvidia-container-tools-1.17.8-1.x86_64.rp 40 kB/s | 40 kB 00:01
(2/4): libnvidia-container1-1.17.8-1.x86_64.rpm 904 kB/s | 1.0 MB 00:01
(3/4): nvidia-container-toolkit-1.17.8-1.x86_64.rpm 764 kB/s | 1.2 MB 00:01
(4/4): nvidia-container-toolkit-base-1.17.8-1.x86_6 4.3 MB/s | 5.8 MB 00:01
Total 3.4 MB/s | 8.0 MB 00:02
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: Transaction test error:
package nvidia-container-toolkit-base-1.17.8-1.x86_64 does not verify: no digest
package libnvidia-container1-1.17.8-1.x86_64 does not verify: no digest
package libnvidia-container-tools-1.17.8-1.x86_64 does not verify: no digest
package nvidia-container-toolkit-1.17.8-1.x86_64 does not verify: no digest
Digging into this, I see that the RPMs only contain SHA1 digests… which aren’t going to work on a FIPS-enabled system:
# rpm -Kvv libnvidia-container1-1.17.8-1.x86_64.rpm
ufdio: 1 reads, 17154 total bytes in 0.000004 secs
ufdio: 1 reads, 5442 total bytes in 0.000001 secs
ufdio: 1 reads, 17154 total bytes in 0.000005 secs
D: loading keyring from pubkeys in /var/lib/rpm/pubkeys/*.key
D: couldn't find any keys in /var/lib/rpm/pubkeys/*.key
D: loading keyring from rpmdb
D: opening db environment /var/lib/rpm cdb:0x401
D: opening db index /var/lib/rpm/Packages 0x400 mode=0x0
D: locked db index /var/lib/rpm/Packages
D: opening db index /var/lib/rpm/Name 0x400 mode=0x0
D: read h# 1513
Header SHA1 digest: OK
D: added key gpg-pubkey-6d745a60-60287f36 to keyring
D: read h# 1521
D: added key gpg-pubkey-d42d0685-62589a51 to keyring
D: read h# 1522
D: added key gpg-pubkey-2f86d6a1-5cf7cefb to keyring
D: read h# 1709
D: added key gpg-pubkey-158b3811-5c33874c to keyring
D: read h# 2444
D: added key gpg-pubkey-621e9f35-58adea78 to keyring
D: read h# 2612
D: added key gpg-pubkey-51312f3f-621fa7a9 to keyring
D: added subkey 0 of main key gpg-pubkey-51312f3f-621fa7a9 to keyring
D: read h# 2613
D: added key gpg-pubkey-35dfa027-60ba0235 to keyring
D: added subkey 0 of main key gpg-pubkey-35dfa027-60ba0235 to keyring
D: read h# 3460
D: added key gpg-pubkey-be1229cf-5631588c to keyring
D: read h# 4564
D: added key gpg-pubkey-6ba75a4e-64486ab3 to keyring
D: added subkey 0 of main key gpg-pubkey-6ba75a4e-64486ab3 to keyring
D: read h# 6382
D: added key gpg-pubkey-264a7796-62589a51 to keyring
D: read h# 8867
D: added key gpg-pubkey-16055553-5b11e9d8 to keyring
D: read h# 8879
D: added key gpg-pubkey-ff696172-62979e51 to keyring
D: added subkey 0 of main key gpg-pubkey-ff696172-62979e51 to keyring
D: Using legacy gpg-pubkey(s) from rpmdb
libnvidia-container1-1.17.8-1.x86_64.rpm:
Header V4 RSA/SHA512 Signature, key ID d42d0685: OK
Payload SHA256 digest: NOTFOUND
MD5 digest: NOTFOUND
ufdio: 38 reads, 1024228 total bytes in 0.000175 secs
D: closed db index /var/lib/rpm/Packages
D: closed db index /var/lib/rpm/Name
D: closed db environment /var/lib/rpm
I don’t know who’s responsible for packaging these RPMs… but this needs to be sorted… SHA1 and MD5 are not valid digests on a FIPS-compliant system.
