I am using nvidia-docker, with the nvidia/cuda:7.5-cudnn5-devel image.
I hit a compilation error when trying to compile caffe:
E0727 14:59:57.959830 674 common.cpp:113] Cannot create Cublas handle. Cublas won't be available.
E0727 14:59:57.960569 674 common.cpp:120] Cannot create Curand generator. Curand won't be available.
F0727 14:59:57.961776 674 syncedmem.hpp:18] Check failed: error == cudaSuccess (35 vs. 0) CUDA driver version is insufficient for CUDA runtime version
some of the compile output -
-- Added CUDA NVCC flags for: sm_20 sm_21 sm_30 sm_35 sm_50
-- OpenCV found (/usr/share/OpenCV)
-- Found Atlas (include: /usr/include, library: /usr/lib/libatlas.so)
-- NumPy ver. 1.11.1 found (include: /usr/local/lib/python2.7/dist-packages/numpy/core/include)
-- Boost version: 1.54.0
-- Found the following Boost libraries:
-- python
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- ******************* Caffe Configuration Summary *******************
-- General:
-- Version : 1.0.0-rc3
-- Git : 42cd785
-- System : Linux
-- C++ compiler : /usr/bin/c++
-- Release CXX flags : -O3 -DNDEBUG -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Debug CXX flags : -g -fPIC -Wall -Wno-sign-compare -Wno-uninitialized
-- Build type : Release
-- BUILD_SHARED_LIBS : ON
-- BUILD_python : ON
-- BUILD_matlab : OFF
-- BUILD_docs : ON
-- CPU_ONLY : OFF
-- USE_OPENCV : ON
-- USE_LEVELDB : ON
-- USE_LMDB : ON
-- ALLOW_LMDB_NOLOCK : OFF
-- Dependencies:
-- BLAS : Yes (Atlas)
-- Boost : Yes (ver. 1.54)
-- glog : Yes
-- gflags : Yes
-- protobuf : Yes (ver. 2.5.0)
-- lmdb : Yes (ver. 0.9.10)
-- LevelDB : Yes (ver. 1.15)
-- Snappy : Yes (ver. 1.1.0)
-- OpenCV : Yes (ver. 2.4.8)
-- CUDA : Yes (ver. 7.5)
did you solve the problem ?
I am tying to compile caffe:
https://github.com/CMU-Perceptual-Computing-Lab/caffe_train
I run successfully :
make all
make test
But when I run
make runtest
I get the following error, please note line 9-10, 90-:
Cuda number of devices: 1
Setting to use device 1
Current device id: 0
Current device name: GeForce GTX 950M
Note: Randomizing tests' orders with a seed of 48454 .
[==========] Running 2081 tests from 277 test cases.
[----------] Global test environment set-up.
[----------] 10 tests from PowerLayerTest/0, where TypeParam = caffe::CPUDevice<float>
[b][ RUN ] PowerLayerTest/0.TestPowerTwo
E0504 19:57:11.898780 14435 common.cpp:113] Cannot create Cublas handle. Cublas won't be available.[/b]
[ OK ] PowerLayerTest/0.TestPowerTwo (550 ms)
[ RUN ] PowerLayerTest/0.TestPowerOne
[ OK ] PowerLayerTest/0.TestPowerOne (0 ms)
[ RUN ] PowerLayerTest/0.TestPowerOneGradient
[ OK ] PowerLayerTest/0.TestPowerOneGradient (1 ms)
[ OK ] PowerLayerTest/0.TestPower (0 ms)
[ RUN ] PowerLayerTest/0.TestPowerGradient
[ OK ] PowerLayerTest/0.TestPowerGradient (3 ms)
[ RUN ] PowerLayerTest/0.TestPowerGradientShiftZero
[ OK ] PowerLayerTest/0.TestPowerGradientShiftZero (5 ms)
[ RUN ] PowerLayerTest/0.TestPowerTwoGradient
[ OK ] PowerLayerTest/0.TestPowerTwoGradient (1 ms)
[ RUN ] PowerLayerTest/0.TestPowerTwoScaleHalfGradient
[ OK ] PowerLayerTest/0.TestPowerTwoScaleHalfGradient (2 ms)
[ RUN ] PowerLayerTest/0.TestPowerZero
[ OK ] PowerLayerTest/0.TestPowerZero (0 ms)
[ RUN ] PowerLayerTest/0.TestPowerZeroGradient
[ OK ] PowerLayerTest/0.TestPowerZeroGradient (1 ms)
[----------] 10 tests from PowerLayerTest/0 (563 ms total)
[----------] 3 tests from SplitLayerTest/1, where TypeParam = caffe::CPUDevice<double>
[ RUN ] SplitLayerTest/1.Test
[ OK ] SplitLayerTest/1.Test (0 ms)
[ RUN ] SplitLayerTest/1.TestGradient
[ OK ] SplitLayerTest/1.TestGradient (3 ms)
[ RUN ] SplitLayerTest/1.TestSetup
[ OK ] SplitLayerTest/1.TestSetup (0 ms)
[----------] 3 tests from SplitLayerTest/1 (3 ms total)
[----------] 2 tests from EuclideanLossLayerTest/1, where TypeParam = caffe::CPUDevice<double>
[ RUN ] EuclideanLossLayerTest/1.TestGradient
[ OK ] EuclideanLossLayerTest/1.TestGradient (1 ms)
[ RUN ] EuclideanLossLayerTest/1.TestForward
[ OK ] EuclideanLossLayerTest/1.TestForward (0 ms)
[----------] 2 tests from EuclideanLossLayerTest/1 (1 ms total)
[----------] 8 tests from SliceLayerTest/3, where TypeParam = caffe::GPUDevice<double>
[ RUN ] SliceLayerTest/3.TestSetupChannels
[ OK ] SliceLayerTest/3.TestSetupChannels (9 ms)
[ RUN ] SliceLayerTest/3.TestSliceAcrossNum
[ OK ] SliceLayerTest/3.TestSliceAcrossNum (1 ms)
[ RUN ] SliceLayerTest/3.TestTrivialSlice
[ OK ] SliceLayerTest/3.TestTrivialSlice (3 ms)
[ RUN ] SliceLayerTest/3.TestSetupNum
[ OK ] SliceLayerTest/3.TestSetupNum (2 ms)
[ RUN ] SliceLayerTest/3.TestGradientAcrossNum
[ OK ] SliceLayerTest/3.TestGradientAcrossNum (411 ms)
[ RUN ] SliceLayerTest/3.TestGradientAcrossChannels
[ OK ] SliceLayerTest/3.TestGradientAcrossChannels (414 ms)
[ RUN ] SliceLayerTest/3.TestGradientTrivial
[ OK ] SliceLayerTest/3.TestGradientTrivial (18 ms)
[ RUN ] SliceLayerTest/3.TestSliceAcrossChannels
[ OK ] SliceLayerTest/3.TestSliceAcrossChannels (2 ms)
[----------] 8 tests from SliceLayerTest/3 (860 ms total)
[----------] 8 tests from LRNLayerTest/0, where TypeParam = caffe::CPUDevice<float>
[ RUN ] LRNLayerTest/0.TestForwardAcrossChannelsLargeRegion
[ OK ] LRNLayerTest/0.TestForwardAcrossChannelsLargeRegion (0 ms)
[ RUN ] LRNLayerTest/0.TestSetupWithinChannel
[ OK ] LRNLayerTest/0.TestSetupWithinChannel (0 ms)
[ RUN ] LRNLayerTest/0.TestSetupAcrossChannels
[ OK ] LRNLayerTest/0.TestSetupAcrossChannels (0 ms)
[ RUN ] LRNLayerTest/0.TestGradientAcrossChannelsLargeRegion
[ OK ] LRNLayerTest/0.TestGradientAcrossChannelsLargeRegion (533 ms)
[ RUN ] LRNLayerTest/0.TestForwardWithinChannel
[ OK ] LRNLayerTest/0.TestForwardWithinChannel (0 ms)
[ OK ] LRNLayerTest/0.TestForwardAcrossChannels (0 ms)
[ OK ] LRNLayerTest/0.TestGradientAcrossChannels (483 ms)
[ RUN ] LRNLayerTest/0.TestGradientWithinChannel
[ OK ] LRNLayerTest/0.TestGradientWithinChannel (438 ms)
[----------] 8 tests from LRNLayerTest/0 (1454 ms total)
[----------] 50 tests from NeuronLayerTest/2, where TypeParam = caffe::GPUDevice<float>
[ RUN ] NeuronLayerTest/2.TestLogGradient
[ OK ] NeuronLayerTest/2.TestLogGradient (15 ms)
[ RUN ] NeuronLayerTest/2.TestLogLayerBase2Shift1Scale3
F0504 19:57:14.253590 14435 math_functions.cu:85] Check failed: status == CUBLAS_STATUS_SUCCESS (1 vs. 0) CUBLAS_STATUS_NOT_INITIALIZED
*** Check failure stack trace: ***
@ 0x2b111fffadaa (unknown)
@ 0x2b111ffface4 (unknown)
@ 0x2b111fffa6e6 (unknown)
@ 0x2b111fffd687 (unknown)
@ 0x2b1122183d17 caffe::caffe_gpu_scal<>()
@ 0x2b1122176279 caffe::LogLayer<>::Forward_gpu()
@ 0x477e46 caffe::Layer<>::Forward()
@ 0x548d90 caffe::NeuronLayerTest<>::TestLogForward()
@ 0x8fca63 testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0x8f3747 testing::Test::Run()
@ 0x8f37ee testing::TestInfo::Run()
@ 0x8f38f5 testing::TestCase::Run()
@ 0x8f6c38 testing::internal::UnitTestImpl::RunAllTests()
@ 0x8f6ec7 testing::UnitTest::Run()
@ 0x46cbbf main
@ 0x2b1122ff1f45 (unknown)
@ 0x474819 (unknown)
@ (nil) (unknown)
make: *** [runtest] Aborted (core dumped)
A thread with my problem points to this this discussion to solve the problem:
opened 01:08PM - 25 Apr 17 UTC
closed 01:09PM - 23 Feb 18 UTC
I built a deep learning server. I used NVIDIA GPU 1080Ti ,ubuntu16.04 ,CUDA8.0 ,… caffe. I have succeeded in making runtest caffe. However, when I tested the mnist example,a problem appeared.
Check failed: status ==CUBLAS_STATUS_SUCCESS(1 VS.0)CUBLAS_NOT_INITALIZATION
@ 0x7f2913a0e5cd google::LogMessage::Fail( )
who can help me? Please tell me the reason why appear the issue and how to solve the problem.
Thanks very #much!
![Uploading IMG_1200.JPG…]()
_
when i run “make runtest -j8” get fail:
Cannot create Cublas handle. Cublas won’t be available.
but I run " sudo make runtest -j8" is ok.
