While running a program that uses GPU (RTX 3060) in the Debian, the GPU is suddenly not connected.
So when I did reboot at that machine, the GPU has to be connected again.
Do you know the cause of this problem? Is it maybe the GPU’s hardware issue or crashed?
This is error logs.
Kernel: [2336314.019190] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x23:0xffff:1204)
Kernel: [2336314.019293] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Kernel: [2336314.067783] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x23:0xffff:1204)
Kernel: [2336314.067830] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
