I encountered the same problem. Differently, I tried to ensure the VT-D is disabled in bios and IOMMU is disabled and the problem still exists. My MOFED version is MLNX_OFED_LINUX-5.8-7.0.6.1,nvidia-driver is 570.181,nvidia-gds-12-4,nvidia-fabricmanager-570/unknown,now 570.172.08-1 amd64 [installed],ubuntu 20.04, libnvidia-nscq-570/unknown,now 570.172.08-1 amd64 [installed].Here is my gdscheck result:
/usr/local/cuda-12.4/gds/tools/gdscheck.py -p
GDS release version: 1.14.1.1
nvidia_fs version: 2.25 libcufile version: 2.12
Platform: x86_64
ENVIRONMENT:
DRIVER CONFIGURATION:
NVMe P2PDMA : Unsupported
NVMe : Supported
NVMeOF : Unsupported
SCSI : Unsupported
ScaleFlux CSD : Unsupported
NVMesh : Unsupported
DDN EXAScaler : Unsupported
IBM Spectrum Scale : Unsupported
NFS : Unsupported
BeeGFS : Unsupported
ScaTeFS : Unsupported
WekaFS : Unsupported
Userspace RDMA : Unsupported
–Mellanox PeerDirect : Enabled
–rdma library : Not Loaded (libcufile_rdma.so)
–rdma devices : Not configured
–rdma_device_status : Up: 0 Down: 0
CUFILE CONFIGURATION:
properties.use_pci_p2pdma : true
properties.use_compat_mode : false
properties.force_compat_mode : false
properties.gds_rdma_write_support : true
properties.use_poll_mode : false
properties.poll_mode_max_size_kb : 4
properties.max_batch_io_size : 128
properties.max_batch_io_timeout_msecs : 5
properties.max_direct_io_size_kb : 16384
properties.max_device_cache_size_kb : 131072
properties.per_buffer_cache_size_kb : 1024
properties.max_device_pinned_mem_size_kb : 33554432
properties.posix_pool_slab_size_kb : 4 1024 16384
properties.posix_pool_slab_count : 128 64 64
properties.rdma_peer_affinity_policy : RoundRobin
properties.rdma_dynamic_routing : 0
fs.generic.posix_unaligned_writes : false
fs.lustre.posix_gds_min_kb: 0
fs.beegfs.posix_gds_min_kb: 0
fs.scatefs.posix_gds_min_kb: 0
fs.weka.rdma_write_support: false
fs.gpfs.gds_write_support: true
fs.gpfs.gds_async_support: true
profile.nvtx : true
profile.cufile_stats : 0
miscellaneous.api_check_aggressive : false
execution.max_io_threads : 4
execution.max_io_queue_depth : 128
execution.parallel_io : true
execution.min_io_threshold_size_kb : 8192
execution.max_request_parallelism : 4
properties.force_odirect_mode : false
properties.prefer_iouring : false
GPU INFO:
GPU index 0 NVIDIA RTX A4000 bar:1 bar size (MiB):256 supports GDS, IOMMU State: Disabled
PLATFORM INFO:
IOMMU: disabled
Nvidia Driver Info Status: Supported(Nvidia Open Driver Installed)
Cuda Driver Version Installed: 12080
Platform: 30FNSBYL00, Arch: x86_64(Linux 5.15.0-139-generic)
Platform verification succeeded
