GDS returns IOCTL failed for writes
Following my driver issue here, we worked with Dell to ensure all requirements are met.
We are running an Ubuntu 22.04, kernel 5.15.0-89, OFED 23.10-0.5.5.0, CUDA+GDS 12.3. GDS reports version 1.8.1.2 and nvidia_fs version 2.18, with libcufile version 2.12.
NVMe appears as supported and gdsio runs fine for read operations (we are using a modifiled cufile.json with compatibility support disabled to ensure GDS is being used), but the problem are the writes. Here’s the gdsio command we are using:
CUFILE_ENV_PATH_JSON=$PWD/cufile.debug.json /usr/local/cuda/gds/tools/gdsio -f /mnt/gpu5nvme1/test-fs-1G -d 5 -w 1 -s 1M -x 0 -i 4K:32K:1K -I 1
And the error that appears on the terminal:
write io failed of type 1 size: 4096 , ret: 0
failed to submit io of type 1 ret: -5
Error: IO failed stopping traffic, fd :199 ret:-5 errno :5
io failed :ret :-5 errno :5, file offset :0, block size  :4096
This error also appears on cufile.log:
 08-12-2023 19:20:36:178 [pid=112720 tid=112793] ERROR  0:1534 IOCTL failed io-type 1 ret -5 expected 4096 gpu_page_offset 0
And dmesg also shows signs that something is wrong:
[70192.609955] EXT4-fs (nvme1n1p1): mounted filesystem with ordered data mode. Opts: data=ordered. Quota mode: none.
[70192.628634] EXT4-fs (nvme2n1p1): mounted filesystem with ordered data mode. Opts: data=ordered. Quota mode: none.
[70331.701693] EXT4-fs (nvme1n1p1): mounted filesystem with ordered data mode. Opts: data=ordered. Quota mode: none.
[70331.720272] EXT4-fs (nvme2n1p1): mounted filesystem with ordered data mode. Opts: data=ordered. Quota mode: none.
[70699.408177] nvme_log_error: 24 callbacks suppressed
[70699.408181] nvme1n1: I/O Cmd(0x1) @ LBA 33295872, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70699.408928] print_req_error: 24 callbacks suppressed
[70699.408929] blk_update_request: I/O error, dev nvme1n1, sector 33295872 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70699.409844] nvidia-fs:write IO failed :-5
[70699.410182] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70699.410204] nvme1n1: I/O Cmd(0x1) @ LBA 33295360, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70699.410208] blk_update_request: I/O error, dev nvme1n1, sector 33295360 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70699.410215] nvidia-fs:write IO failed :-5
[70699.410217] nvme1n1: I/O Cmd(0x1) @ LBA 33294848, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70699.410221] blk_update_request: I/O error, dev nvme1n1, sector 33294848 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70699.410227] nvidia-fs:write IO failed :-5
[70699.415727] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70699.416577] nvidia-fs:write IO failed :-5
[70716.444523] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70716.444548] nvme1n1: I/O Cmd(0x1) @ LBA 33295872, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70716.444549] nvme1n1: I/O Cmd(0x1) @ LBA 33294848, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70716.444553] blk_update_request: I/O error, dev nvme1n1, sector 33294848 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70716.444562] nvidia-fs:write IO failed :-5
[70716.444561] nvme1n1: I/O Cmd(0x1) @ LBA 33295360, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70716.444565] blk_update_request: I/O error, dev nvme1n1, sector 33295360 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70716.444573] nvidia-fs:write IO failed :-5
[70716.445259] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70716.446094] blk_update_request: I/O error, dev nvme1n1, sector 33295872 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70716.446906] nvidia-fs:write IO failed :-5
[70716.447709] nvidia-fs:write IO failed :-5
[70737.739351] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[70737.739990] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[70737.740587] nvidia-fs:write IO failed :-5
[71251.762593] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[71251.763278] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[71251.763966] nvidia-fs:write IO failed :-5
[71419.209304] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[71419.210025] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[71419.210845] nvidia-fs:write IO failed :-5
[71495.212428] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[71495.213102] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[71495.213689] nvidia-fs:write IO failed :-5
[71538.805915] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[71538.806579] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[71538.807212] nvidia-fs:write IO failed :-5
[72601.734463] nvme1n1: I/O Cmd(0x1) @ LBA 33294336, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[72601.735263] blk_update_request: I/O error, dev nvme1n1, sector 33294336 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[72601.736064] nvidia-fs:write IO failed :-5
[74837.482947] nvme1n1: I/O Cmd(0x1) @ LBA 29100032, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[74837.483610] blk_update_request: I/O error, dev nvme1n1, sector 29100032 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[74837.484241] nvidia-fs:write IO failed :-5
[75578.523266] nvme1n1: I/O Cmd(0x1) @ LBA 2298759168, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[75578.523950] blk_update_request: I/O error, dev nvme1n1, sector 2298759168 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[75578.524617] nvidia-fs:write IO failed :-5
[75883.712121] nvme1n1: I/O Cmd(0x1) @ LBA 2298759168, 8 blocks, I/O Error (sct 0x0 / sc 0x4)
[75883.712828] blk_update_request: I/O error, dev nvme1n1, sector 2298759168 op 0x1:(WRITE) flags 0x8800 phys_seg 1 prio class 0
[75883.713580] nvidia-fs:write IO failed :-5
I double checked that the input/output file is not sparse.
Any suggestions on how to fix this issue?
How is the drive formatted ?
GDS does not support drives formatted with T10-PI protection.
Can you share the results of the command with -x 1 and -x 2 mode ?
Do they see the same errors
sudo nvme id-ns
sudo nvme smart-log /dev/nvme1n1
sudo nvme error-log /dev/nvme1n1
One tiny note, I realized that the gdsio command is using 4K:32K:1K, so I changed it to 4K:32K:4K, the errors persisted.
The gdsio command runs file with -x1 and -x2.
The drive has a single (EXT4) partition, formatted with a plain mkfs.ext4 command, and mounted with data=ordered. T10-PI protection doesn’t appear to be enabled:
sg_readcap -l /dev/nvme1n1
Read Capacity results:
   Protection: prot_en=0, p_type=0, p_i_exponent=0
   Logical block provisioning: lbpme=0, lbprz=0
   Last LBA=6251233967 (0x1749a42af), Number of logical blocks=6251233968
   Logical block length=512 bytes
   Logical blocks per physical block exponent=0
   Lowest aligned LBA=0
Hence:
   Device size: 3200631791616 bytes, 3052360.3 MiB, 3200.63 GB, 3.20 TB
The commands you asked showed nothing that caught my eye:
nvme id-ns /dev/nvme1n1
NVME Identify Namespace 1:
nsze    : 0x1749a42b0
ncap    : 0x1749a42b0
nuse    : 0x1749a42b0
nsfeat  : 0
nlbaf   : 4
flbas   : 0
mc      : 0x3
dpc     : 0x12
dps     : 0
nmic    : 0
rescap  : 0
fpi     : 0
dlfeat  : 25
nawun   : 0
nawupf  : 0
nacwu   : 0
nabsn   : 0
nabo    : 0
nabspf  : 0
noiob   : 256
nvmcap  : 3200631791616
mssrl   : 0
mcl     : 0
msrc    : 0
anagrpid: 0
nsattr	: 0
nvmsetid: 0
endgid  : 0
nguid   : 01000000000000005cd2e4d1b9215551
eui64   : 5cd2e4d1b9210500
lbaf  0 : ms:0   lbads:9  rp:0x2 (in use)
lbaf  1 : ms:8   lbads:9  rp:0x2
lbaf  2 : ms:0   lbads:12 rp:0x2
lbaf  3 : ms:8   lbads:12 rp:0x2
lbaf  4 : ms:64  lbads:12 rp:0x2
Smart Log for NVME device:nvme1n1 namespace-id:ffffffff
critical_warning			: 0
temperature				: 30 C (303 Kelvin)
available_spare				: 100%
available_spare_threshold		: 10%
percentage_used				: 0%
endurance group critical warning summary: 0
data_units_read				: 10567546
data_units_written			: 28947364
host_read_commands			: 54512053
host_write_commands			: 172658343
controller_busy_time			: 2
power_cycles				: 145
power_on_hours				: 6769
unsafe_shutdowns			: 67
media_errors				: 0
num_err_log_entries			: 0
Warning Temperature Time		: 0
Critical Composite Temperature Time	: 0
Thermal Management T1 Trans Count	: 0
Thermal Management T2 Trans Count	: 0
Thermal Management T1 Total Time	: 0
Thermal Management T2 Total Time	: 0
Error Log Entries for device:nvme1n1 entries:64
 Entry[ 0]
error_count	: 0
sqid		: 0
cmdid		: 0
status_field	: 0(SUCCESS: The command completed successfully)
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
trtype		: The transport type is not indicated or the error is not transport related.
cs		: 0
trtype_spec_info: 0
 Entry[ 1]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 2]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 3]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 4]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 5]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 6]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 7]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 8]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[ 9]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[10]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[11]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[12]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[13]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[14]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[15]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[16]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[17]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[18]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[19]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[20]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[21]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[22]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[23]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[24]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[25]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[26]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[27]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[28]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[29]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[30]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[31]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[32]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[33]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[34]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[35]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[36]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[37]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[38]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[39]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[40]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[41]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[42]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[43]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[44]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[45]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[46]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[47]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[48]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[49]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[50]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[51]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[52]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[53]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[54]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[55]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[56]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[57]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[58]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[59]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[60]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[61]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[62]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
 Entry[63]
error_count	: 0
sqid		: 0
cmdid		: 0
phase_tag	: 0
parm_err_loc	: 0
lba		: 0
nsid		: 0
vs		: 0
cs		: 0
trtype_spec_info: 0
