cuFileWrite return success,but the data write in file is not correct
I have configured GDS according to the official website of NVIDIA. But when I exec cuda_sample_003 is failed,the data which write in file through cuFileWrite is not correct.
Here is my environment info:
root@v100:~# nvidia-smi
Mon Apr 15 09:52:08 2024
| NVIDIA-SMI 530.30.02              Driver Version: 530.30.02    CUDA Version: 12.1     |
| GPU  Name                  Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf            Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Tesla V100-PCIE-16GB            On | 00000000:01:00.0 Off |                    0 |
| N/A   36C    P0               27W / 250W|     23MiB / 16384MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A      1728      G   /usr/lib/xorg/Xorg                           22MiB |
root@v100:~# /usr/local/cuda-12.1/gds/tools/gdscheck.py -p
 GDS release version: 1.6.1.9
 nvidia_fs version:  2.15 libcufile version: 2.12
 Platform: x86_64
 ENVIRONMENT:
 DRIVER CONFIGURATION:
 NVMe               : Supported
 NVMeOF             : Unsupported
 SCSI               : Unsupported
 ScaleFlux CSD      : Unsupported
 NVMesh             : Unsupported
 DDN EXAScaler      : Unsupported
 IBM Spectrum Scale : Unsupported
 NFS                : Unsupported
 BeeGFS             : Unsupported
 WekaFS             : Unsupported
 Userspace RDMA     : Unsupported
 --Mellanox PeerDirect : Disabled
 --rdma library        : Not Loaded (libcufile_rdma.so)
 --rdma devices        : Not configured
 --rdma_device_status  : Up: 0 Down: 0
 CUFILE CONFIGURATION:
 properties.use_compat_mode : false
 properties.force_compat_mode : false
 properties.gds_rdma_write_support : true
 properties.use_poll_mode : false
 properties.poll_mode_max_size_kb : 4
 properties.max_batch_io_size : 128
 properties.max_batch_io_timeout_msecs : 5
 properties.max_direct_io_size_kb : 16384
 properties.max_device_cache_size_kb : 131072
 properties.max_device_pinned_mem_size_kb : 33554432
 properties.posix_pool_slab_size_kb : 4 1024 16384
 properties.posix_pool_slab_count : 128 64 32
 properties.rdma_peer_affinity_policy : RoundRobin
 properties.rdma_dynamic_routing : 0
 fs.generic.posix_unaligned_writes : false
 fs.lustre.posix_gds_min_kb: 0
 fs.beegfs.posix_gds_min_kb: 0
 fs.weka.rdma_write_support: false
 fs.gpfs.gds_write_support: false
 profile.nvtx : false
 profile.cufile_stats : 3
 miscellaneous.api_check_aggressive : false
 execution.max_io_threads : 0
 execution.max_io_queue_depth : 128
 execution.parallel_io : false
 execution.min_io_threshold_size_kb : 8192
 execution.max_request_parallelism : 0
 GPU INFO:
 GPU index 0 Tesla V100-PCIE-16GB bar:1 bar size (MiB):16384 supports GDS, IOMMU State: Disabled
 PLATFORM INFO:
 IOMMU: disabled
 Platform verification succeeded
mount info:
/dev/nvme0n1 on /mnt/gds type xfs (rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota)
When I exec the cufile_sample_003 of cuda-12.1,is failed:
root@v100:~# /usr/local/cuda-12.1/gds/samples/cufile_sample_003 /mnt/gds/a /mnt/gds/b 0
reading file to device memory :/mnt/gds/a
writing device memory to file :/mnt/gds/b
dffccd4c9ca61136187b84586bb956705c136a4b3944dffce5366ac343e4d6
66c970fcdafe33412256e6fdd676ff7e836a9b92192f8c6c8248f22bab0842
SHA SUM Mismatch
root@v100:~# hexdump -C /mnt/gds/a
00000000  5d 5d 5d 5d 5d 5d 5d 5d  5d 5d 5d 5d 5d 5d 5d 5d  |]]]]]]]]]]]]]]]]|
01f00000
root@v100:~# hexdump -C /mnt/gds/b
00000000  ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff  |................|
01f00000
I check the data which read from /mnt/gds/a through cuFileRead is correct,but the data which write in /mnt/gds/b through cuFileWrite is not correct(all F).
When I change size param of cuFileWrite,I found if the size < 4096,the data write in file through cuFileWrite is correct.
The samething occur with gdsio tool:
root@v100:~# /usr/local/cuda-12.1/gds/tools/gdsio -D /mnt/gds -d 0 -w 8 -s 10M -i 4K -x 0 -I 1 -V
IoType: WRITE XferType: GPUD Threads: 8 DataSetSize: 72096/81920(KiB) IOSize: 4(KiB) Throughput: 0.136781 GiB/sec, Avg_Latency: 223.171285 usecs ops: 18024 total_time 0.502672 secs
Verifying data
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x110 tid: 1
Actual Data:ffffffffffffffffffffffffffffffff
Expected Data:47445343484b01778808000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0xb0 tid: 6
Expected Data:47445343484b06778805000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x30 tid: 3
Expected Data:47445343484b03778801000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x1d0 tid: 2
Expected Data:47445343484b0277880e000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x110 tid: 7
Expected Data:47445343484b07778808000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x170 tid: 4
Expected Data:47445343484b0477880b000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x1b0 tid: 0
Expected Data:47445343484b0077880d000000000000
Error : files not created with -V mode or data verification failed at offset : 0x0(0) bs :4096 failing index :0x170 tid: 5
Expected Data:47445343484b0577880b000000000000
root@v100:~# /usr/local/cuda-12.1/gds/tools/gdsio -D /mnt/gds -d 0 -w 8 -s 10M -i 2K -x 0 -I 1 -V
IoType: WRITE XferType: GPUD Threads: 8 DataSetSize: 81442/81920(KiB) IOSize: 2(KiB) Throughput: 0.002646 GiB/sec, Avg_Latency: 5766.894109 usecs ops: 40721 total_time 29.355586 secs
Verifying data
IoType: READ XferType: GPUD Threads: 8 DataSetSize: 81464/81920(KiB) IOSize: 2(KiB) Throughput: 0.029744 GiB/sec, Avg_Latency: 512.718048 usecs ops: 40732 total_time 2.611975 secs
Here is the dmesg:
[    0.000000] kernel: microcode: microcode updated early to revision 0xf4, date = 2023-02-23
[    0.000000] kernel: Linux version 5.15.0-67-generic (buildd@lcy02-amd64-029) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #74~20.04.1-Ubuntu SMP Wed Feb 22 14:52:34
UTC 2023 (Ubuntu 5.15.0-67.74~20.04.1-generic 5.15.85)
[    0.000000] kernel: Command line: BOOT_IMAGE=/vmlinuz-5.15.0-67-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro intel_iommu=off pci=realloc=off
[    0.000000] kernel: KERNEL supported cpus:
[    0.000000] kernel:   Intel GenuineIntel
[    0.000000] kernel:   AMD AuthenticAMD
[    0.000000] kernel:   Hygon HygonGenuine
[    0.000000] kernel:   Centaur CentaurHauls
[    0.000000] kernel:   zhaoxin   Shanghai
[    0.000000] kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] kernel: signal: max sigframe size: 2032
[    0.000000] kernel: BIOS-provided physical RAM map:
[    0.000000] kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000031d7ffff] usable
[    0.000000] kernel: BIOS-e820: [mem 0x0000000031d80000-0x0000000031d80fff] ACPI NVS
[    0.000000] kernel: BIOS-e820: [mem 0x0000000031d81000-0x0000000031d81fff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x0000000031d82000-0x0000000038f6dfff] usable
[    0.000000] kernel: BIOS-e820: [mem 0x0000000038f6e000-0x00000000393dafff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000393db000-0x0000000039457fff] ACPI data
[    0.000000] kernel: BIOS-e820: [mem 0x0000000039458000-0x000000003957afff] ACPI NVS
[    0.000000] kernel: BIOS-e820: [mem 0x000000003957b000-0x0000000039efefff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x0000000039eff000-0x0000000039efffff] usable
[    0.000000] kernel: BIOS-e820: [mem 0x0000000039f00000-0x000000003f7fffff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] kernel: BIOS-e820: [mem 0x0000000100000000-0x00000004be7fffff] usable
[    0.000000] kernel: NX (Execute Disable) protection: active
[    0.000000] kernel: e820: update [mem 0x22b1c018-0x22b2a057] usable ==> usable
[    0.000000] kernel: extended physical RAM map:
[    0.000000] kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000022b1c017] usable
[    0.000000] kernel: reserve setup_data: [mem 0x0000000022b1c018-0x0000000022b2a057] usable
[    0.000000] kernel: reserve setup_data: [mem 0x0000000022b2a058-0x0000000031d7ffff] usable
[    0.000000] kernel: reserve setup_data: [mem 0x0000000031d80000-0x0000000031d80fff] ACPI NVS
[    0.000000] kernel: reserve setup_data: [mem 0x0000000031d81000-0x0000000031d81fff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x0000000031d82000-0x0000000038f6dfff] usable
[    0.000000] kernel: reserve setup_data: [mem 0x0000000038f6e000-0x00000000393dafff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000393db000-0x0000000039457fff] ACPI data
[    0.000000] kernel: reserve setup_data: [mem 0x0000000039458000-0x000000003957afff] ACPI NVS
[    0.000000] kernel: reserve setup_data: [mem 0x000000003957b000-0x0000000039efefff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x0000000039eff000-0x0000000039efffff] usable
[    0.000000] kernel: reserve setup_data: [mem 0x0000000039f00000-0x000000003f7fffff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] kernel: reserve setup_data: [mem 0x0000000100000000-0x00000004be7fffff] usable
[    0.000000] kernel: efi: EFI v2.60 by American Megatrends
[    0.000000] kernel: efi: ACPI 2.0=0x394af000 ACPI=0x394af000 SMBIOS=0x39c40000 SMBIOS 3.0=0x39c3f000 ESRT=0x37829a98 MEMATTR=0x37820018 MOKvar=0x37821000 RNG=0x39457018
[    0.000000] kernel: efi: seeding entropy pool
[    0.000000] kernel: random: crng init done
[    0.000000] kernel: secureboot: Secure boot disabled
[    0.000000] kernel: SMBIOS 3.1.1 present.
[    0.000000] kernel: DMI: Gigabyte Technology Co., Ltd. B360 HD3/B360HD3, BIOS F2 02/23/2018
[    0.000000] kernel: tsc: Detected 3200.000 MHz processor
[    0.000000] kernel: tsc: Detected 3199.980 MHz TSC
[    0.000679] kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000682] kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000691] kernel: last_pfn = 0x4be800 max_arch_pfn = 0x400000000
[    0.000869] kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002139] kernel: last_pfn = 0x39f00 max_arch_pfn = 0x400000000
[    0.009140] kernel: esrt: Reserving ESRT space from 0x0000000037829a98 to 0x0000000037829ad0.
[    0.009145] kernel: e820: update [mem 0x37829000-0x37829fff] usable ==> reserved
[    0.009158] kernel: e820: update [mem 0x37821000-0x37821fff] usable ==> reserved
[    0.009174] kernel: Using GB pages for direct mapping
[    0.009450] kernel: secureboot: Secure boot disabled
[    0.009452] kernel: RAMDISK: [mem 0x0b0d8000-0x172d9fff]
[    0.009457] kernel: ACPI: Early table checksum verification disabled
[    0.009460] kernel: ACPI: RSDP 0x00000000394AF000 000024 (v02 ALASKA)
[    0.009464] kernel: ACPI: XSDT 0x00000000394AF0A8 0000D4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009470] kernel: ACPI: FACP 0x00000000394EF310 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.009476] kernel: ACPI: DSDT 0x00000000394AF218 0400F4 (v02 ALASKA A M I    01072009 INTL 20160527)
[    0.009479] kernel: ACPI: FACS 0x0000000039579080 000040
[    0.009482] kernel: ACPI: APIC 0x00000000394EF428 0000F4 (v04 ALASKA A M I    01072009 AMI  00010013)
[    0.009486] kernel: ACPI: FPDT 0x00000000394EF520 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009489] kernel: ACPI: FIDT 0x00000000394EF568 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009493] kernel: ACPI: MCFG 0x00000000394EF608 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.009496] kernel: ACPI: SSDT 0x00000000394EF648 000334 (v01 SataRe SataTabl 00001000 INTL 20160527)
[    0.009499] kernel: ACPI: SSDT 0x00000000394EF980 0017CB (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
[    0.009503] kernel: ACPI: SSDT 0x00000000394F1150 006CE5 (v01 GBT    GSWApp   00000001 INTL 20160527)
[    0.009506] kernel: ACPI: SSDT 0x00000000394F7E38 0031C7 (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
[    0.009510] kernel: ACPI: SSDT 0x00000000394FB000 001FA8 (v02 PegSsd PegSsdt  00001000 INTL 20160527)
[    0.009513] kernel: ACPI: HPET 0x00000000394FCFA8 000038 (v01 INTEL  A M I    00000002      01000013)
[    0.009517] kernel: ACPI: SSDT 0x00000000394FCFE0 000F9E (v02 INTEL  Ther_Rvp 00001000 INTL 20160527)
[    0.009521] kernel: ACPI: SSDT 0x00000000394FDF80 00299C (v02 INTEL  xh_cfsd4 00000000 INTL 20160527)
[    0.009525] kernel: ACPI: UEFI 0x0000000039500920 000042 (v01 ALASKA A M I    00000002      01000013)
[    0.009530] kernel: ACPI: LPIT 0x0000000039500968 00005C (v01 INTEL  A M I    00000002      01000013)
[    0.009533] kernel: ACPI: SSDT 0x00000000395009C8 0027DE (v02 INTEL  PtidDevc 00001000 INTL 20160527)
[    0.009536] kernel: ACPI: SSDT 0x00000000395031A8 000FFE (v02 INTEL  TbtTypeC 00000000 INTL 20160527)
[    0.009540] kernel: ACPI: DBGP 0x00000000395041A8 000034 (v01 ALASKA A M I    00000002      01000013)
[    0.009543] kernel: ACPI: DBG2 0x00000000395041E0 000054 (v00 ALASKA A M I    00000002      01000013)
[    0.009546] kernel: ACPI: DMAR 0x0000000039504238 0000A8 (v01 INTEL  EDK2     00000002      01000013)
[    0.009550] kernel: ACPI: BGRT 0x00000000395042E0 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009553] kernel: ACPI: WSMT 0x0000000039504318 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.009556] kernel: ACPI: Reserving FACP table memory at [mem 0x394ef310-0x394ef423]
[    0.009558] kernel: ACPI: Reserving DSDT table memory at [mem 0x394af218-0x394ef30b]
[    0.009559] kernel: ACPI: Reserving FACS table memory at [mem 0x39579080-0x395790bf]
[    0.009560] kernel: ACPI: Reserving APIC table memory at [mem 0x394ef428-0x394ef51b]
[    0.009562] kernel: ACPI: Reserving FPDT table memory at [mem 0x394ef520-0x394ef563]
[    0.009563] kernel: ACPI: Reserving FIDT table memory at [mem 0x394ef568-0x394ef603]
[    0.009564] kernel: ACPI: Reserving MCFG table memory at [mem 0x394ef608-0x394ef643]
[    0.009565] kernel: ACPI: Reserving SSDT table memory at [mem 0x394ef648-0x394ef97b]
[    0.009566] kernel: ACPI: Reserving SSDT table memory at [mem 0x394ef980-0x394f114a]
[    0.009568] kernel: ACPI: Reserving SSDT table memory at [mem 0x394f1150-0x394f7e34]
[    0.009569] kernel: ACPI: Reserving SSDT table memory at [mem 0x394f7e38-0x394faffe]
[    0.009570] kernel: ACPI: Reserving SSDT table memory at [mem 0x394fb000-0x394fcfa7]
[    0.009571] kernel: ACPI: Reserving HPET table memory at [mem 0x394fcfa8-0x394fcfdf]
[    0.009573] kernel: ACPI: Reserving SSDT table memory at [mem 0x394fcfe0-0x394fdf7d]
[    0.009574] kernel: ACPI: Reserving SSDT table memory at [mem 0x394fdf80-0x3950091b]
[    0.009575] kernel: ACPI: Reserving UEFI table memory at [mem 0x39500920-0x39500961]
[    0.009576] kernel: ACPI: Reserving LPIT table memory at [mem 0x39500968-0x395009c3]
[    0.009577] kernel: ACPI: Reserving SSDT table memory at [mem 0x395009c8-0x395031a5]
[    0.009579] kernel: ACPI: Reserving SSDT table memory at [mem 0x395031a8-0x395041a5]
[    0.009580] kernel: ACPI: Reserving DBGP table memory at [mem 0x395041a8-0x395041db]
[    0.009581] kernel: ACPI: Reserving DBG2 table memory at [mem 0x395041e0-0x39504233]
[    0.009582] kernel: ACPI: Reserving DMAR table memory at [mem 0x39504238-0x395042df]
[    0.009584] kernel: ACPI: Reserving BGRT table memory at [mem 0x395042e0-0x39504317]
[    0.009585] kernel: ACPI: Reserving WSMT table memory at [mem 0x39504318-0x3950433f]
[    0.009896] kernel: No NUMA configuration found
[    0.009898] kernel: Faking a node at [mem 0x0000000000000000-0x00000004be7fffff]
[    0.009906] kernel: NODE_DATA(0) allocated [mem 0x4be7d6000-0x4be7fffff]
[    0.010145] kernel: Zone ranges:
[    0.010146] kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.010148] kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.010150] kernel:   Normal   [mem 0x0000000100000000-0x00000004be7fffff]
[    0.010152] kernel:   Device   empty
[    0.010153] kernel: Movable zone start for each node
[    0.010156] kernel: Early memory node ranges
[    0.010157] kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.010159] kernel:   node   0: [mem 0x0000000000100000-0x0000000031d7ffff]
[    0.010160] kernel:   node   0: [mem 0x0000000031d82000-0x0000000038f6dfff]
[    0.010161] kernel:   node   0: [mem 0x0000000039eff000-0x0000000039efffff]
[    0.010162] kernel:   node   0: [mem 0x0000000100000000-0x00000004be7fffff]
[    0.010165] kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000004be7fffff]
[    0.010169] kernel: On node 0, zone DMA: 1 pages in unavailable ranges
[    0.010188] kernel: On node 0, zone DMA: 97 pages in unavailable ranges
[    0.011289] kernel: On node 0, zone DMA32: 2 pages in unavailable ranges
[    0.011334] kernel: On node 0, zone DMA32: 3985 pages in unavailable ranges
[    0.038930] kernel: On node 0, zone Normal: 24832 pages in unavailable ranges
[    0.039001] kernel: On node 0, zone Normal: 6144 pages in unavailable ranges
[    0.039026] kernel: Reserving Intel graphics memory at [mem 0x3b800000-0x3f7fffff]
[    0.039377] kernel: ACPI: PM-Timer IO Port: 0x1808
[    0.039385] kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.039387] kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.039388] kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.039389] kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.039390] kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.039391] kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.039392] kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.039393] kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.039394] kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.039395] kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.039396] kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.039397] kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.039434] kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.039437] kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.039439] kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.039442] kernel: ACPI: Using ACPI (MADT) for SMP configuration information
[    0.039444] kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.039450] kernel: e820: update [mem 0x35b53000-0x35b97fff] usable ==> reserved
[    0.039463] kernel: TSC deadline timer available
[    0.039464] kernel: smpboot: Allowing 12 CPUs, 0 hotplug CPUs
[    0.039481] kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.039483] kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.039485] kernel: PM: hibernation: Registered nosave memory: [mem 0x22b1c000-0x22b1cfff]
[    0.039487] kernel: PM: hibernation: Registered nosave memory: [mem 0x22b2a000-0x22b2afff]
[    0.039489] kernel: PM: hibernation: Registered nosave memory: [mem 0x31d80000-0x31d80fff]
[    0.039490] kernel: PM: hibernation: Registered nosave memory: [mem 0x31d81000-0x31d81fff]
[    0.039492] kernel: PM: hibernation: Registered nosave memory: [mem 0x35b53000-0x35b97fff]
[    0.039494] kernel: PM: hibernation: Registered nosave memory: [mem 0x37821000-0x37821fff]
[    0.039496] kernel: PM: hibernation: Registered nosave memory: [mem 0x37829000-0x37829fff]
[    0.039498] kernel: PM: hibernation: Registered nosave memory: [mem 0x38f6e000-0x393dafff]
[    0.039499] kernel: PM: hibernation: Registered nosave memory: [mem 0x393db000-0x39457fff]
[    0.039500] kernel: PM: hibernation: Registered nosave memory: [mem 0x39458000-0x3957afff]
[    0.039501] kernel: PM: hibernation: Registered nosave memory: [mem 0x3957b000-0x39efefff]
[    0.039503] kernel: PM: hibernation: Registered nosave memory: [mem 0x39f00000-0x3f7fffff]
[    0.039504] kernel: PM: hibernation: Registered nosave memory: [mem 0x3f800000-0xdfffffff]
[    0.039505] kernel: PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.039506] kernel: PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.039507] kernel: PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.039508] kernel: PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.039509] kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.039510] kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.039511] kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.039512] kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.039513] kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.039515] kernel: [mem 0x3f800000-0xdfffffff] available for PCI devices
[    0.039517] kernel: Booting paravirtualized kernel on bare hardware
[    0.039519] kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.039526] kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:12 nr_cpu_ids:12 nr_node_ids:1
[    0.039854] kernel: percpu: Embedded 60 pages/cpu s208896 r8192 d28672 u262144
[    0.039862] kernel: pcpu-alloc: s208896 r8192 d28672 u262144 alloc=1*2097152
[    0.039864] kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 -- -- -- --
[    0.039898] kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4094095
[    0.039900] kernel: Policy zone: Normal
[    0.039901] kernel: Kernel command line: BOOT_IMAGE=/vmlinuz-5.15.0-67-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro intel_iommu=off pci=realloc=off
[    0.039950] kernel: DMAR: IOMMU disabled
[    0.039968] kernel: Unknown kernel command line parameters "BOOT_IMAGE=/vmlinuz-5.15.0-67-generic", will be passed to user space.
[    0.040844] kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.041286] kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.041399] kernel: mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.089343] kernel: Memory: 15985016K/16636972K available (16393K kernel code, 4374K rwdata, 10796K rodata, 3236K init, 6572K bss, 651696K reserved, 0K cma-reserved)
[    0.089466] kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[    0.089479] kernel: Kernel/User page tables isolation: enabled
[    0.089494] kernel: ftrace: allocating 50060 entries in 196 pages
[    0.112411] kernel: ftrace: allocated 196 pages with 3 groups
[    0.112514] kernel: rcu: Hierarchical RCU implementation.
[    0.112515] kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=12.
[    0.112517] kernel:         Rude variant of Tasks RCU enabled.
[    0.112518] kernel:         Tracing variant of Tasks RCU enabled.
[    0.112519] kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.112520] kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[    0.116271] kernel: NR_IRQS: 524544, nr_irqs: 2152, preallocated irqs: 16
[    0.116729] kernel: Console: colour dummy device 80x25
[    0.117014] kernel: printk: console [tty0] enabled
[    0.117034] kernel: ACPI: Core revision 20210730
[    0.117381] kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.117475] kernel: APIC: Switch to symmetric I/O mode setup
[    0.117478] kernel: DMAR: Host address width 39
[    0.117480] kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.117486] kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.117490] kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.117494] kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.117497] kernel: DMAR: RMRR base: 0x00000039378000 end: 0x00000039397fff
[    0.117500] kernel: DMAR: RMRR base: 0x0000003b000000 end: 0x0000003f7fffff
[    0.117503] kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.117505] kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.117507] kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.119732] kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.119736] kernel: x2apic enabled
[    0.119760] kernel: Switched APIC routing to cluster x2apic.
[    0.125319] kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.141377] kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e2036ff8d5, max_idle_ns: 440795275316 ns
[    0.141385] kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6399.96 BogoMIPS (lpj=12799920)
[    0.141390] kernel: pid_max: default: 32768 minimum: 301
[    0.143434] kernel: LSM: Security Framework initializing
[    0.143445] kernel: landlock: Up and running.
[    0.143447] kernel: Yama: becoming mindful.
[    0.143468] kernel: AppArmor: AppArmor initialized
[    0.143521] kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.143553] kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.143776] kernel: x86/cpu: SGX disabled by BIOS.
[    0.143782] kernel: CPU0: Thermal monitoring enabled (TM1)
[    0.143840] kernel: process: using mwait in idle threads
[    0.143843] kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.143845] kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.143851] kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.143854] kernel: Spectre V2 : Mitigation: IBRS
[    0.143856] kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.143858] kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.143860] kernel: RETBleed: Mitigation: IBRS
[    0.143863] kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.143866] kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.143874] kernel: MDS: Mitigation: Clear CPU buffers
[    0.143876] kernel: TAA: Mitigation: TSX disabled
[    0.143878] kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.143883] kernel: SRBDS: Mitigation: Microcode
[    0.169468] kernel: Freeing SMP alternatives memory: 40K
[    0.169770] kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1376
[    0.169791] kernel: smpboot: CPU0: Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[    0.169918] kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.169931] kernel: ... version:                4
[    0.169933] kernel: ... bit width:              48
[    0.169935] kernel: ... generic registers:      4
[    0.169937] kernel: ... value mask:             0000ffffffffffff
[    0.169939] kernel: ... max period:             00007fffffffffff
[    0.169941] kernel: ... fixed-purpose events:   3
[    0.169943] kernel: ... event mask:             000000070000000f
[    0.170037] kernel: rcu: Hierarchical SRCU implementation.
[    0.171021] kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.171107] kernel: smp: Bringing up secondary CPUs ...
[    0.171188] kernel: x86: Booting SMP configuration:
[    0.171191] kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.182127] kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.182127] kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.182127] kernel:   #7  #8  #9 #10 #11
[    0.185809] kernel: smp: Brought up 1 node, 12 CPUs
[    0.185809] kernel: smpboot: Max logical packages: 1
[    0.185809] kernel: smpboot: Total of 12 processors activated (76799.52 BogoMIPS)
[    0.189905] kernel: devtmpfs: initialized
[    0.189905] kernel: x86/mm: Memory block size: 128MB
[    0.190609] kernel: ACPI: PM: Registering ACPI NVS region [mem 0x31d80000-0x31d80fff] (4096 bytes)
[    0.190609] kernel: ACPI: PM: Registering ACPI NVS region [mem 0x39458000-0x3957afff] (1191936 bytes)
[    0.190609] kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.190609] kernel: futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.190609] kernel: pinctrl core: initialized pinctrl subsystem
[    0.190609] kernel: PM: RTC time: 01:54:10, date: 2024-04-15
[    0.190609] kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.190609] kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.190609] kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.190609] kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.190609] kernel: audit: initializing netlink subsys (disabled)
[    0.190609] kernel: audit: type=2000 audit(1713146050.072:1): state=initialized audit_enabled=0 res=1
[    0.190609] kernel: thermal_sys: Registered thermal governor 'fair_share'
[    0.190609] kernel: thermal_sys: Registered thermal governor 'bang_bang'
[    0.190609] kernel: thermal_sys: Registered thermal governor 'step_wise'
[    0.190609] kernel: thermal_sys: Registered thermal governor 'user_space'
[    0.190609] kernel: thermal_sys: Registered thermal governor 'power_allocator'
[    0.190609] kernel: EISA bus registered
[    0.190609] kernel: cpuidle: using governor ladder
[    0.190609] kernel: cpuidle: using governor menu
[    0.190609] kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.190609] kernel: ACPI: bus type PCI registered
[    0.190609] kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.190609] kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.190609] kernel: PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.190609] kernel: PCI: Using configuration type 1 for base access
[    0.194415] kernel: Kprobes globally optimized
[    0.194421] kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.194421] kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.194421] kernel: fbcon: Taking over console
[    0.194421] kernel: ACPI: Added _OSI(Module Device)
[    0.194421] kernel: ACPI: Added _OSI(Processor Device)
[    0.194421] kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.194421] kernel: ACPI: Added _OSI(Processor Aggregator Device)
[    0.194421] kernel: ACPI: Added _OSI(Linux-Dell-Video)
[    0.194421] kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.194421] kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.298623] kernel: ACPI: 10 ACPI AML tables successfully acquired and loaded
[    3.499884] kernel: ACPI: Dynamic OEM Table Load:
[    3.499893] kernel: ACPI: SSDT 0xFFFF965A81A43800 000708 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    3.502032] kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    3.504984] kernel: ACPI: Dynamic OEM Table Load:
[    3.504992] kernel: ACPI: SSDT 0xFFFF965A81A32000 000386 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    3.507564] kernel: ACPI: Dynamic OEM Table Load:
[    3.507574] kernel: ACPI: SSDT 0xFFFF965A80180000 000EF1 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    3.510672] kernel: ACPI: Dynamic OEM Table Load:
[    3.510679] kernel: ACPI: SSDT 0xFFFF965A81A31800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    3.512591] kernel: ACPI: Dynamic OEM Table Load:
[    3.512599] kernel: ACPI: SSDT 0xFFFF965A81A37C00 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    3.523362] kernel: ACPI: Interpreter enabled
[    3.523408] kernel: ACPI: PM: (supports S0 S3 S4 S5)
[    3.523410] kernel: ACPI: Using IOAPIC for interrupt routing
[    3.523457] kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    3.523461] kernel: PCI: Using E820 reservations for host bridge windows
[    3.525855] kernel: ACPI: Enabled 5 GPEs in block 00 to 7F
[    3.544369] kernel: ACPI: PM: Power Resource [USBC]
[    3.548777] kernel: ACPI: PM: Power Resource [V0PR]
[    3.549069] kernel: ACPI: PM: Power Resource [V1PR]
[    3.549357] kernel: ACPI: PM: Power Resource [V2PR]
[    3.559905] kernel: ACPI: PM: Power Resource [WRST]
[    3.563354] kernel: ACPI: PM: Power Resource [FN00]
[    3.563465] kernel: ACPI: PM: Power Resource [FN01]
[    3.563571] kernel: ACPI: PM: Power Resource [FN02]
[    3.563676] kernel: ACPI: PM: Power Resource [FN03]
[    3.563781] kernel: ACPI: PM: Power Resource [FN04]
[    3.564671] kernel: ACPI: PM: Power Resource [PIN]
[    3.565479] kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    3.565489] kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    3.565781] kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    3.566061] kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    3.566065] kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    3.567206] kernel: PCI host bridge to bus 0000:00
[    3.567212] kernel: pci_bus 0000:00: root bus resource [bus 00-fe]
[    3.567215] kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    3.567218] kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    3.567222] kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
[    3.567225] kernel: pci_bus 0000:00: root bus resource [mem 0x3f800000-0xdfffffff window]
[    3.567228] kernel: pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    3.567232] kernel: pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    3.567424] kernel: pci 0000:00:00.0: [8086:3ec2] type 00 class 0x060000
[    3.567833] kernel: pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[    3.567875] kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    3.568670] kernel: pci 0000:00:02.0: [8086:3e92] type 00 class 0x030000
[    3.568681] kernel: pci 0000:00:02.0: reg 0x10: [mem 0x6000000000-0x6000ffffff 64bit]
[    3.568688] kernel: pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[    3.568694] kernel: pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    3.568711] kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
[    3.568716] kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    3.569167] kernel: pci 0000:00:12.0: [8086:a379] type 00 class 0x118000
[    3.569202] kernel: pci 0000:00:12.0: reg 0x10: [mem 0x6001118000-0x6001118fff 64bit]
[    3.569711] kernel: pci 0000:00:14.0: [8086:a36d] type 00 class 0x0c0330
[    3.569738] kernel: pci 0000:00:14.0: reg 0x10: [mem 0x6001100000-0x600110ffff 64bit]
[    3.569838] kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
[    3.570462] kernel: pci 0000:00:14.2: [8086:a36f] type 00 class 0x050000
[    3.570490] kernel: pci 0000:00:14.2: reg 0x10: [mem 0x6001114000-0x6001115fff 64bit]
[    3.570507] kernel: pci 0000:00:14.2: reg 0x18: [mem 0x6001117000-0x6001117fff 64bit]
[    3.570938] kernel: pci 0000:00:16.0: [8086:a360] type 00 class 0x078000
[    3.570969] kernel: pci 0000:00:16.0: reg 0x10: [mem 0x6001116000-0x6001116fff 64bit]
[    3.571073] kernel: pci 0000:00:16.0: PME# supported from D3hot
[    3.571903] kernel: pci 0000:00:17.0: [8086:a352] type 00 class 0x010601
[    3.571927] kernel: pci 0000:00:17.0: reg 0x10: [mem 0x3fa00000-0x3fa01fff]
[    3.571939] kernel: pci 0000:00:17.0: reg 0x14: [mem 0x3fa03000-0x3fa030ff]
[    3.571952] kernel: pci 0000:00:17.0: reg 0x18: [io  0x4070-0x4077]
[    3.571964] kernel: pci 0000:00:17.0: reg 0x1c: [io  0x4060-0x4063]
[    3.571977] kernel: pci 0000:00:17.0: reg 0x20: [io  0x4040-0x405f]
[    3.571989] kernel: pci 0000:00:17.0: reg 0x24: [mem 0x3fa02000-0x3fa027ff]
[    3.572051] kernel: pci 0000:00:17.0: PME# supported from D3hot
[    3.572944] kernel: pci 0000:00:1d.0: [8086:a330] type 01 class 0x060400
[    3.573075] kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    3.573109] kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    3.574161] kernel: pci 0000:00:1d.3: [8086:a333] type 01 class 0x060400
[    3.574291] kernel: pci 0000:00:1d.3: PME# supported from D0 D3hot D3cold
[    3.574326] kernel: pci 0000:00:1d.3: PTM enabled (root), 4ns granularity
[    3.575391] kernel: pci 0000:00:1f.0: [8086:a308] type 00 class 0x060100
[    3.576142] kernel: pci 0000:00:1f.3: [8086:a348] type 00 class 0x040300
[    3.576199] kernel: pci 0000:00:1f.3: reg 0x10: [mem 0x6001110000-0x6001113fff 64bit]
[    3.576265] kernel: pci 0000:00:1f.3: reg 0x20: [mem 0x6001000000-0x60010fffff 64bit]
[    3.576397] kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    3.577666] kernel: pci 0000:00:1f.4: [8086:a323] type 00 class 0x0c0500
[    3.577724] kernel: pci 0000:00:1f.4: reg 0x10: [mem 0x00000000-0x000000ff 64bit]
[    3.577780] kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    3.578236] kernel: pci 0000:00:1f.5: [8086:a324] type 00 class 0x0c8000
[    3.578261] kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    3.578514] kernel: pci 0000:01:00.0: [10de:1db4] type 00 class 0x030200
[    3.578524] kernel: pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[    3.578532] kernel: pci 0000:01:00.0: reg 0x14: [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.578540] kernel: pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x01ffffff 64bit pref]
[    3.578563] kernel: pci 0000:01:00.0: Enabling HDA controller
[    3.578676] kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
[    3.578844] kernel: pci 0000:02:00.0: [8086:f1a6] type 00 class 0x010802
[    3.578884] kernel: pci 0000:02:00.0: reg 0x10: [mem 0x3f900000-0x3f903fff 64bit]
[    3.579137] kernel: pci 0000:02:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0000:00:1d.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    3.579224] kernel: pci 0000:00:1d.0: PCI bridge to [bus 02]
[    3.579232] kernel: pci 0000:00:1d.0:   bridge window [mem 0x3f900000-0x3f9fffff]
[    3.579412] kernel: pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[    3.579443] kernel: pci 0000:03:00.0: reg 0x10: [io  0x3000-0x30ff]
[    3.579480] kernel: pci 0000:03:00.0: reg 0x18: [mem 0x3f804000-0x3f804fff 64bit]
[    3.579505] kernel: pci 0000:03:00.0: reg 0x20: [mem 0x3f800000-0x3f803fff 64bit]
[    3.579644] kernel: pci 0000:03:00.0: supports D1 D2
[    3.579646] kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    3.579811] kernel: pci 0000:00:1d.3: PCI bridge to [bus 03]
[    3.579817] kernel: pci 0000:00:1d.3:   bridge window [io  0x3000-0x3fff]
[    3.579822] kernel: pci 0000:00:1d.3:   bridge window [mem 0x3f800000-0x3f8fffff]
[    3.582235] kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    3.582285] kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    3.582334] kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    3.582383] kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    3.582431] kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    3.582479] kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    3.582528] kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    3.582576] kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    3.590609] kernel: iommu: Default domain type: Translated
[    3.590609] kernel: iommu: DMA domain TLB invalidation policy: lazy mode
[    3.590609] kernel: SCSI subsystem initialized
[    3.590609] kernel: libata version 3.00 loaded.
[    3.590609] kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    3.590609] kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    3.590609] kernel: pci 0000:00:02.0: vgaarb: bridge control possible
[    3.590609] kernel: vgaarb: loaded
[    3.590609] kernel: ACPI: bus type USB registered
[    3.590609] kernel: usbcore: registered new interface driver usbfs
[    3.590609] kernel: usbcore: registered new interface driver hub
[    3.590609] kernel: usbcore: registered new device driver usb
[    3.590609] kernel: pps_core: LinuxPPS API ver. 1 registered
[    3.590609] kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.590609] kernel: PTP clock support registered
[    3.590609] kernel: EDAC MC: Ver: 3.0.0
[    3.590609] kernel: Registered efivars operations
[    3.590609] kernel: NetLabel: Initializing
[    3.590609] kernel: NetLabel:  domain hash size = 128
[    3.590609] kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    3.590609] kernel: NetLabel:  unlabeled traffic allowed by default
[    3.590609] kernel: PCI: Using ACPI for IRQ routing
[    3.677010] kernel: PCI: pci_cache_line_size set to 64 bytes
[    3.677089] kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    3.677090] kernel: e820: reserve RAM buffer [mem 0x22b1c018-0x23ffffff]
[    3.677092] kernel: e820: reserve RAM buffer [mem 0x31d80000-0x33ffffff]
[    3.677093] kernel: e820: reserve RAM buffer [mem 0x35b53000-0x37ffffff]
[    3.677094] kernel: e820: reserve RAM buffer [mem 0x37821000-0x37ffffff]
[    3.677095] kernel: e820: reserve RAM buffer [mem 0x37829000-0x37ffffff]
[    3.677096] kernel: e820: reserve RAM buffer [mem 0x38f6e000-0x3bffffff]
[    3.677097] kernel: e820: reserve RAM buffer [mem 0x39f00000-0x3bffffff]
[    3.677098] kernel: e820: reserve RAM buffer [mem 0x4be800000-0x4bfffffff]
[    3.678239] kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    3.678249] kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    3.680328] kernel: clocksource: Switched to clocksource tsc-early
[    3.686706] kernel: VFS: Disk quotas dquot_6.6.0
[    3.686731] kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.686830] kernel: AppArmor: AppArmor Filesystem Enabled
[    3.686862] kernel: pnp: PnP ACPI init
[    3.687230] kernel: system 00:00: [io  0x0a00-0x0a2f] has been reserved
[    3.687236] kernel: system 00:00: [io  0x0a30-0x0a3f] has been reserved
[    3.687240] kernel: system 00:00: [io  0x0a40-0x0a4f] has been reserved
[    3.688174] kernel: pnp 00:01: [dma 0 disabled]
[    3.689193] kernel: pnp 00:02: [dma 0 disabled]
[    3.689358] kernel: system 00:03: [io  0x0680-0x069f] has been reserved
[    3.689363] kernel: system 00:03: [io  0x164e-0x164f] has been reserved
[    3.689505] kernel: system 00:05: [io  0x1854-0x1857] has been reserved
[    3.689751] kernel: pnp 00:06: disabling [mem 0xfed10000-0xfed17fff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689757] kernel: pnp 00:06: disabling [mem 0xfed18000-0xfed18fff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689762] kernel: pnp 00:06: disabling [mem 0xfed19000-0xfed19fff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689767] kernel: pnp 00:06: disabling [mem 0xe0000000-0xefffffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689771] kernel: pnp 00:06: disabling [mem 0xfed20000-0xfed3ffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689775] kernel: pnp 00:06: disabling [mem 0xfed90000-0xfed93fff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689780] kernel: pnp 00:06: disabling [mem 0xfed45000-0xfed8ffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.689784] kernel: pnp 00:06: disabling [mem 0xfee00000-0xfeefffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690051] kernel: pnp 00:07: disabling [mem 0xfd000000-0xfd69ffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690057] kernel: pnp 00:07: disabling [mem 0xfd6c0000-0xfd6cffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690061] kernel: pnp 00:07: disabling [mem 0xfd6f0000-0xfdffffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690066] kernel: pnp 00:07: disabling [mem 0xfe000000-0xfe01ffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690071] kernel: pnp 00:07: disabling [mem 0xfe200000-0xfe7fffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690075] kernel: pnp 00:07: disabling [mem 0xff000000-0xffffffff] because it overlaps 0000:01:00.0 BAR 1 [mem 0x00000000-0x3ffffffff 64bit pref]
[    3.690097] kernel: system 00:07: [io  0x1800-0x18fe] could not be reserved
[    3.690456] kernel: system 00:08: [io  0x2000-0x20fe] has been reserved
[    3.692895] kernel: pnp: PnP ACPI: found 10 devices
[    3.698479] kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    3.698535] kernel: NET: Registered PF_INET protocol family
[    3.698661] kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    3.700199] kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    3.700233] kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    3.700301] kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    3.700443] kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    3.700501] kernel: TCP: Hash tables configured (established 131072 bind 65536)
[    3.700571] kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    3.700621] kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    3.700658] kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    3.700717] kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
[    3.700724] kernel: NET: Registered PF_XDP protocol family
[    3.700735] kernel: clipped [mem size 0x00000000 64bit pref] to [mem size 0xfffffffffffa0000 64bit pref] for e820 entry [mem 0x0009f000-0x000fffff]
[    3.700743] kernel: pci 0000:00:01.0: BAR 15: assigned [mem 0x4200000000-0x47ffffffff 64bit pref]
[    3.700748] kernel: clipped [mem size 0x00050000] to [mem size 0xffffffffffff0000] for e820 entry [mem 0x0009f000-0x000fffff]
[    3.700753] kernel: pci 0000:00:01.0: BAR 14: assigned [mem 0x40000000-0x40ffffff]
[    3.700757] kernel: clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[    3.700762] kernel: pci 0000:00:1f.4: BAR 0: assigned [mem 0x4010000000-0x40100000ff 64bit]
[    3.700797] kernel: pci 0000:01:00.0: BAR 1: assigned [mem 0x4400000000-0x47ffffffff 64bit pref]
[    3.700805] kernel: pci 0000:01:00.0: BAR 3: assigned [mem 0x4200000000-0x4201ffffff 64bit pref]
[    3.700812] kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x40000000-0x40ffffff]
[    3.700816] kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
[    3.700820] kernel: pci 0000:00:01.0:   bridge window [mem 0x40000000-0x40ffffff]
[    3.700824] kernel: pci 0000:00:01.0:   bridge window [mem 0x4200000000-0x47ffffffff 64bit pref]
[    3.700830] kernel: pci 0000:00:1d.0: PCI bridge to [bus 02]
[    3.700840] kernel: pci 0000:00:1d.0:   bridge window [mem 0x3f900000-0x3f9fffff]
[    3.700850] kernel: pci 0000:00:1d.3: PCI bridge to [bus 03]
[    3.700854] kernel: pci 0000:00:1d.3:   bridge window [io  0x3000-0x3fff]
[    3.700861] kernel: pci 0000:00:1d.3:   bridge window [mem 0x3f800000-0x3f8fffff]
[    3.700872] kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    3.700875] kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    3.700878] kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000effff window]
[    3.700881] kernel: pci_bus 0000:00: resource 7 [mem 0x3f800000-0xdfffffff window]
[    3.700884] kernel: pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[    3.700887] kernel: pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[    3.700890] kernel: pci_bus 0000:01: resource 1 [mem 0x40000000-0x40ffffff]
[    3.700893] kernel: pci_bus 0000:01: resource 2 [mem 0x4200000000-0x47ffffffff 64bit pref]
[    3.700897] kernel: pci_bus 0000:02: resource 1 [mem 0x3f900000-0x3f9fffff]
[    3.700900] kernel: pci_bus 0000:03: resource 0 [io  0x3000-0x3fff]
[    3.700903] kernel: pci_bus 0000:03: resource 1 [mem 0x3f800000-0x3f8fffff]
[    3.701198] kernel: PCI: CLS 64 bytes, default 64
[    3.701226] kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    3.701228] kernel: software IO TLB: mapped [mem 0x000000002c2f8000-0x00000000302f8000] (64MB)
[    3.701252] kernel: Trying to unpack rootfs image as initramfs...
[    3.701926] kernel: Initialise system trusted keyrings
[    3.701935] kernel: Key type blacklist registered
[    3.701961] kernel: workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    3.703253] kernel: zbud: loaded
[    3.703528] kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.703674] kernel: fuse: init (API version 7.34)
[    3.703822] kernel: integrity: Platform Keyring initialized
[    3.710715] kernel: Key type asymmetric registered
[    3.710719] kernel: Asymmetric key parser 'x509' registered
[    3.710736] kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    3.710768] kernel: io scheduler mq-deadline registered
[    3.714301] kernel: pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[    3.714344] kernel: pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
[    3.714347] kernel: pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    3.714650] kernel: pcieport 0000:00:1d.3: AER: enabled with IRQ 124
[    3.714690] kernel: pcieport 0000:00:1d.3: DPC: enabled with IRQ 124
[    3.714693] kernel: pcieport 0000:00:1d.3: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    3.714802] kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.715770] kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    3.715792] kernel: ACPI: button: Sleep Button [SLPB]
[    3.715821] kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    3.715838] kernel: ACPI: button: Power Button [PWRB]
[    3.715867] kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    3.715897] kernel: ACPI: button: Power Button [PWRF]
[    3.716055] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716064] kernel:
[    3.716066] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716068] kernel:
[    3.716070] kernel: No Arguments are initialized for method [_CPC]
[    3.716072] kernel:
[    3.716074] kernel: ACPI Error: Aborting method \_SB.PR01._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716121] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716128] kernel:
[    3.716130] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716132] kernel:
[    3.716134] kernel: No Arguments are initialized for method [_CPC]
[    3.716136] kernel:
[    3.716137] kernel: ACPI Error: Aborting method \_SB.PR02._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716182] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716189] kernel:
[    3.716190] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716192] kernel:
[    3.716194] kernel: No Arguments are initialized for method [_CPC]
[    3.716196] kernel:
[    3.716198] kernel: ACPI Error: Aborting method \_SB.PR03._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716240] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716246] kernel:
[    3.716248] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716250] kernel:
[    3.716251] kernel: No Arguments are initialized for method [_CPC]
[    3.716253] kernel:
[    3.716255] kernel: ACPI Error: Aborting method \_SB.PR04._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716298] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716305] kernel:
[    3.716307] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716309] kernel:
[    3.716310] kernel: No Arguments are initialized for method [_CPC]
[    3.716312] kernel:
[    3.716314] kernel: ACPI Error: Aborting method \_SB.PR05._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716358] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716364] kernel:
[    3.716366] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716368] kernel:
[    3.716369] kernel: No Arguments are initialized for method [_CPC]
[    3.716371] kernel:
[    3.716373] kernel: ACPI Error: Aborting method \_SB.PR06._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716419] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716425] kernel:
[    3.716427] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716429] kernel:
[    3.716431] kernel: No Arguments are initialized for method [_CPC]
[    3.716433] kernel:
[    3.716434] kernel: ACPI Error: Aborting method \_SB.PR07._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716478] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716485] kernel:
[    3.716486] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716489] kernel:
[    3.716490] kernel: No Arguments are initialized for method [_CPC]
[    3.716492] kernel:
[    3.716494] kernel: ACPI Error: Aborting method \_SB.PR08._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716539] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716545] kernel:
[    3.716547] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716549] kernel:
[    3.716550] kernel: No Arguments are initialized for method [_CPC]
[    3.716552] kernel:
[    3.716554] kernel: ACPI Error: Aborting method \_SB.PR09._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716597] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716604] kernel:
[    3.716605] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716607] kernel:
[    3.716609] kernel: No Arguments are initialized for method [_CPC]
[    3.716611] kernel:
[    3.716613] kernel: ACPI Error: Aborting method \_SB.PR10._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.716656] kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PR00._CPC], AE_NOT_FOUND (20210730/psargs-330)
[    3.716662] kernel:
[    3.716663] kernel: No Local Variables are initialized for Method [_CPC]
[    3.716666] kernel:
[    3.716667] kernel: No Arguments are initialized for method [_CPC]
[    3.716669] kernel:
[    3.716671] kernel: ACPI Error: Aborting method \_SB.PR11._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[    3.717066] kernel: ACPI: \_TZ_.TZ10: Invalid passive threshold
[    3.717443] kernel: thermal LNXTHERM:00: registered as thermal_zone0
[    3.717446] kernel: ACPI: thermal: Thermal Zone [TZ10] (17 C)
[    3.717940] kernel: thermal LNXTHERM:01: registered as thermal_zone1
[    3.717943] kernel: ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    3.718109] kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.739843] kernel: 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    3.743481] kernel: Linux agpgart interface v0.103
[    3.746055] kernel: loop: module loaded
[    3.746285] kernel: tun: Universal TUN/TAP device driver, 1.6
[    3.746338] kernel: PPP generic driver version 2.4.2
[    3.746438] kernel: VFIO - User Level meta-driver version: 0.3
[    3.746556] kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.746563] kernel: ehci-pci: EHCI PCI platform driver
[    3.746571] kernel: ehci-platform: EHCI generic platform driver
[    3.746579] kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.746583] kernel: ohci-pci: OHCI PCI platform driver
[    3.746590] kernel: ohci-platform: OHCI generic platform driver
[    3.746597] kernel: uhci_hcd: USB Universal Host Controller Interface driver
[    3.746653] kernel: i8042: PNP: No PS/2 controller found.
[    3.746739] kernel: mousedev: PS/2 mouse device common for all mice
[    3.746892] kernel: rtc_cmos 00:04: RTC can wake from S4
[    3.747882] kernel: rtc_cmos 00:04: registered as rtc0
[    3.748141] kernel: rtc_cmos 00:04: setting system clock to 2024-04-15T01:54:14 UTC (1713146054)
[    3.748159] kernel: rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    3.748170] kernel: i2c_dev: i2c /dev entries driver
[    3.749815] kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    3.749855] kernel: device-mapper: uevent: version 1.0.3
[    3.749929] kernel: device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    3.749951] kernel: platform eisa.0: Probing EISA bus 0
[    3.749955] kernel: platform eisa.0: EISA: Cannot allocate resource for mainboard
[    3.749958] kernel: platform eisa.0: Cannot allocate resource for EISA slot 1
[    3.749961] kernel: platform eisa.0: Cannot allocate resource for EISA slot 2
[    3.749963] kernel: platform eisa.0: Cannot allocate resource for EISA slot 3
[    3.749966] kernel: platform eisa.0: Cannot allocate resource for EISA slot 4
[    3.749968] kernel: platform eisa.0: Cannot allocate resource for EISA slot 5
[    3.749971] kernel: platform eisa.0: Cannot allocate resource for EISA slot 6
[    3.749974] kernel: platform eisa.0: Cannot allocate resource for EISA slot 7
[    3.749976] kernel: platform eisa.0: Cannot allocate resource for EISA slot 8
[    3.749979] kernel: platform eisa.0: EISA: Detected 0 cards
[    3.749984] kernel: intel_pstate: Intel P-state driver initializing
[    3.750616] kernel: intel_pstate: Disabling energy efficiency optimization
[    3.750618] kernel: intel_pstate: HWP enabled
[    3.750938] kernel: ledtrig-cpu: registered to indicate activity on CPUs
[    3.750968] kernel: efifb: probing for efifb
[    3.750997] kernel: efifb: framebuffer at 0x4000000000, using 3072k, total 3072k
[    3.751000] kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
[    3.751002] kernel: efifb: scrolling: redraw
[    3.751003] kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.751105] kernel: Console: switching to colour frame buffer device 128x48
[    3.751901] kernel: fb0: EFI VGA frame buffer device
[    3.751914] kernel: EFI Variables Facility v0.08 2004-May-17
[    3.773634] kernel: intel_pmc_core INT33A1:00:  initialized
[    3.773728] kernel: drop_monitor: Initializing network drop monitor service
[    3.773858] kernel: NET: Registered PF_INET6 protocol family
[    3.953788] kernel: Freeing initrd memory: 198664K
[    3.958510] kernel: Segment Routing with IPv6
[    3.958542] kernel: In-situ OAM (IOAM) with IPv6
[    3.958571] kernel: NET: Registered PF_PACKET protocol family
[    3.958685] kernel: Key type dns_resolver registered
[    3.959665] kernel: microcode: sig=0x906ea, pf=0x2, revision=0xf4
[    3.959984] kernel: microcode: Microcode Update Driver: v2.2.
[    3.959988] kernel: IPI shorthand broadcast: enabled
[    3.960012] kernel: sched_clock: Marking stable (3959261879, 706916)->(3967341315, -7372520)
[    3.960264] kernel: registered taskstats version 1
[    3.960765] kernel: Loading compiled-in X.509 certificates
[    3.961304] kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 845ee4b048e292d9ddac4d210e2ae66761afcaf6'
[    3.961700] kernel: Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[    3.962050] kernel: Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[    3.962068] kernel: blacklist: Loading compiled-in revocation X.509 certificates
[    3.962090] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[    3.962116] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[    3.962143] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[    3.962489] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[    3.962832] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[    3.963180] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[    3.963520] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[    3.963859] kernel: Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[    3.964730] kernel: zswap: loaded using pool lzo/zbud
[    3.965431] kernel: Key type .fscrypt registered
[    3.965787] kernel: Key type fscrypt-provisioning registered
[    3.968484] kernel: Key type encrypted registered
[    3.968849] kernel: AppArmor: AppArmor sha1 policy hashing enabled
[    3.970180] kernel: integrity: Loading X.509 certificate: UEFI:MokListRT (MOKvar table)
[    3.970929] kernel: integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[    3.971723] kernel: ima: No TPM chip found, activating TPM-bypass!
[    3.972123] kernel: Loading compiled-in module X.509 certificates
[    3.972860] kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 845ee4b048e292d9ddac4d210e2ae66761afcaf6'
[    3.973274] kernel: ima: Allocated hash algorithm: sha1
[    3.973744] kernel: ima: No architecture policies found
[    3.974157] kernel: evm: Initialising EVM extended attributes:
[    3.974554] kernel: evm: security.selinux
[    3.974939] kernel: evm: security.SMACK64
[    3.975319] kernel: evm: security.SMACK64EXEC
[    3.975696] kernel: evm: security.SMACK64TRANSMUTE
[    3.976072] kernel: evm: security.SMACK64MMAP
[    3.976437] kernel: evm: security.apparmor
[    3.976799] kernel: evm: security.ima
[    3.977155] kernel: evm: security.capability
[    3.977557] kernel: evm: HMAC attrs: 0x1
[    3.978232] kernel: PM:   Magic number: 4:109:913
[    3.978630] kernel: container PRP00001:00: hash matches
[    3.978992] kernel: acpi PRP00001:00: hash matches
[    3.979524] kernel: RAS: Correctable Errors collector initialized.
[    3.980665] kernel: Freeing unused decrypted memory: 2036K
[    3.981418] kernel: Freeing unused kernel image (initmem) memory: 3236K
[    4.025469] kernel: Write protecting the kernel read-only data: 30720k
[    4.026948] kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
[    4.028095] kernel: Freeing unused kernel image (rodata/data gap) memory: 1492K
[    4.085485] kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.085853] kernel: x86/mm: Checking user space page tables
[    4.118413] kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    4.118765] kernel: Run /init as init process
[    4.119104] kernel:   with arguments:
[    4.119105] kernel:     /init
[    4.119106] kernel:   with environment:
[    4.119106] kernel:     HOME=/
[    4.119107] kernel:     TERM=linux
[    4.119107] kernel:     BOOT_IMAGE=/vmlinuz-5.15.0-67-generic
[    4.197935] kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    4.200106] kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    4.201859] kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.201955] kernel: mlx_compat: loading out-of-tree module taints kernel.
[    4.202502] kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    4.203671] kernel: mlx_compat: module verification failed: signature and/or required key missing - tainting kernel
[    4.204635] kernel: Compat-mlnx-ofed backport release: 7ed2e5b
[    4.204731] kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000000009810
[    4.205442] kernel: Backport based on https://:@git-nbu.nvidia.com/r/a/mlnx_ofed/mlnx-ofa_kernel-4.0.git 7ed2e5b
[    4.206171] kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.206845] kernel: compat.git: https://:@git-nbu.nvidia.com/r/a/mlnx_ofed/mlnx-ofa_kernel-4.0.git
[    4.207264] kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    4.208747] kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    4.209414] kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    4.209437] kernel: i801_smbus 0000:00:1f.4: enabling device (0001 -> 0003)
[    4.209641] kernel: ahci 0000:00:17.0: version 3.0
[    4.209904] kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.210861] kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    4.210872] kernel: usb usb1: Product: xHCI Host Controller
[    4.211588] kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    4.212318] kernel: usb usb1: Manufacturer: Linux 5.15.0-67-generic xhci-hcd
[    4.213781] kernel: usb usb1: SerialNumber: 0000:00:14.0
[    4.214678] kernel: hub 1-0:1.0: USB hub found
[    4.215422] kernel: hub 1-0:1.0: 16 ports detected
[    4.216744] kernel: cryptd: max_cpu_qlen set to 1000
[    4.218549] kernel: i2c i2c-0: 1/4 memory slots populated (from DMI)
[    4.219454] kernel: nvme nvme0: pci function 0000:02:00.0
[    4.219524] kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    4.219774] kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
[    4.220643] kernel: ahci 0000:00:17.0: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[    4.220767] kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.221417] kernel: ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[    4.223796] kernel: usb usb2: Product: xHCI Host Controller
[    4.224609] kernel: usb usb2: Manufacturer: Linux 5.15.0-67-generic xhci-hcd
[    4.225340] kernel: usb usb2: SerialNumber: 0000:00:14.0
[    4.227615] kernel: AVX2 version of gcm_enc/dec engaged.
[    4.228179] kernel: AES CTR mode by8 optimization enabled
[    4.229829] kernel: hub 2-0:1.0: USB hub found
[    4.229990] kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h, e0:d5:5e:b1:d6:75, XID 541, IRQ 128
[    4.230489] kernel: hub 2-0:1.0: 6 ports detected
[    4.231142] kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    4.231792] kernel: nvme nvme0: 12/0/0 default/read/poll queues
[    4.276919] kernel: r8169 0000:03:00.0 enp3s0: renamed from eth0
[    4.290200] kernel: scsi host0: ahci
[    4.290932] kernel: scsi host1: ahci
[    4.291534] kernel: scsi host2: ahci
[    4.292112] kernel: scsi host3: ahci
[    4.292692] kernel: scsi host4: ahci
[    4.293206] kernel: scsi host5: ahci
[    4.293690] kernel: ata1: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02100 irq 126
[    4.294134] kernel: ata2: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02180 irq 126
[    4.294561] kernel: ata3: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02200 irq 126
[    4.294991] kernel: ata4: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02280 irq 126
[    4.295406] kernel: ata5: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02300 irq 126
[    4.295812] kernel: ata6: SATA max UDMA/133 abar m2048@0x3fa02000 port 0x3fa02380 irq 126
[    4.553435] kernel: usb 1-5: new low-speed USB device number 2 using xhci_hcd
[    4.608382] kernel: ata3: SATA link down (SStatus 4 SControl 300)
[    4.608765] kernel: ata1: SATA link down (SStatus 4 SControl 300)
[    4.612629] kernel: ata5: SATA link down (SStatus 4 SControl 300)
[    4.612999] kernel: ata2: SATA link down (SStatus 4 SControl 300)
[    4.613361] kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.613744] kernel: ata4: SATA link down (SStatus 4 SControl 300)
[    4.614697] kernel: ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    4.614701] kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    4.615041] kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    4.615931] kernel: ata6.00: ATA-9: WDC WD10EJRX-89N74Y0, 01.01A01, max UDMA/133
[    4.616723] kernel: ata6.00: ATA Identify Device Log not supported
[    4.617050] kernel: ata6.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.618408] kernel: ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    4.618411] kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    4.618744] kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    4.620085] kernel: ata6.00: ATA Identify Device Log not supported
[    4.620421] kernel: ata6.00: configured for UDMA/133
[    4.620843] kernel: scsi 5:0:0:0: Direct-Access     ATA      WDC WD10EJRX-89N 1A01 PQ: 0 ANSI: 5
[    4.621321] kernel: sd 5:0:0:0: Attached scsi generic sg0 type 0
[    4.621372] kernel: sd 5:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    4.622132] kernel: sd 5:0:0:0: [sda] 4096-byte physical blocks
[    4.622508] kernel: sd 5:0:0:0: [sda] Write Protect is off
[    4.622842] kernel: sd 5:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.622921] kernel: sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.645213] kernel: nvidia: module license 'NVIDIA' taints kernel.
[    4.645594] kernel: Disabling lock debugging due to kernel taint
[    4.673291] kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[    4.673647] kernel:
[    4.674631] kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0002)
[    4.680237] kernel: Console: switching to colour dummy device 80x25
[    4.680276] kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
[    4.710784] kernel: usb 1-5: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.02
[    4.710789] kernel: usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.710791] kernel: usb 1-5: Product: USB Keyboard
[    4.710793] kernel: usb 1-5: Manufacturer: Logitech
[    4.732284] kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    4.732560] kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    4.735631] kernel:  sda: sda1 sda2 sda3
[    4.790997] kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  530.30.02  Wed Feb 22 04:11:39 UTC 2023
[    4.791148] kernel: tsc: Refined TSC clocksource calibration: 3192.029 MHz
[    4.791154] kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2e02e08a0e6, max_idle_ns: 440795358329 ns
[    4.791170] kernel: clocksource: Switched to clocksource tsc
[    4.841387] kernel: usb 1-6: new low-speed USB device number 3 using xhci_hcd
[    4.861427] kernel: sd 5:0:0:0: [sda] Attached SCSI disk
[    4.887081] kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  530.30.02  Wed Feb 22 03:45:40 UTC 2023
[    4.888769] kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    4.888773] kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[    4.995792] kernel: usb 1-6: New USB device found, idVendor=15d9, idProduct=0a41, bcdDevice= 1.00
[    4.995797] kernel: usb 1-6: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.995800] kernel: usb 1-6: Product: USB Mouse
[    4.999582] kernel: hid: raw HID events driver (C) Jiri Kosina
[    5.003867] kernel: i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
[    5.008767] kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    5.009077] kernel: usbcore: registered new interface driver usbhid
[    5.009080] kernel: usbhid: USB HID core driver
[    5.010703] kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    5.011051] kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[    5.041927] kernel: input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:046D:C31C.0001/input/input4
[    5.058431] kernel: fbcon: i915drmfb (fb0) is primary device
[    5.093150] kernel: Console: switching to colour frame buffer device 180x56
[    5.101649] kernel: hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:14.0-5/input0
[    5.101770] kernel: input: Logitech USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:046D:C31C.0002/input/input5
[    5.111752] kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    5.161681] kernel: input: Logitech USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:046D:C31C.0002/input/input6
[    5.162268] kernel: hid-generic 0003:046D:C31C.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:14.0-5/input1
[    5.162597] kernel: input: USB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:15D9:0A41.0003/input/input7
[    5.163068] kernel: hid-generic 0003:15D9:0A41.0003: input,hidraw2: USB HID v1.10 Mouse [USB Mouse] on usb-0000:00:14.0-6/input0
[    5.781384] kernel: raid6: avx2x4   gen() 48328 MB/s
[    5.849383] kernel: raid6: avx2x4   xor() 14911 MB/s
[    5.917384] kernel: raid6: avx2x2   gen() 44860 MB/s
[    5.985384] kernel: raid6: avx2x2   xor() 29893 MB/s
[    6.053384] kernel: raid6: avx2x1   gen() 32763 MB/s
[    6.121384] kernel: raid6: avx2x1   xor() 18082 MB/s
[    6.189384] kernel: raid6: sse2x4   gen() 20608 MB/s
[    6.257384] kernel: raid6: sse2x4   xor() 11676 MB/s
[    6.325384] kernel: raid6: sse2x2   gen() 20883 MB/s
[    6.393384] kernel: raid6: sse2x2   xor() 12812 MB/s
[    6.461384] kernel: raid6: sse2x1   gen() 17683 MB/s
[    6.529384] kernel: raid6: sse2x1   xor()  9095 MB/s
[    6.529420] kernel: raid6: using algorithm avx2x4 gen() 48328 MB/s
[    6.529431] kernel: raid6: .... xor() 14911 MB/s, rmw enabled
[    6.529442] kernel: raid6: using avx2x2 recovery algorithm
[    6.530241] kernel: xor: automatically using best checksumming function   avx
[    6.531054] kernel: async_tx: api initialized (async)
[    6.662553] kernel: Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[    6.956699] kernel: EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    8.659785] systemd[1]: Inserted module 'autofs4'
[    8.917821] systemd[1]: systemd 245.4-4ubuntu3.20 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTIL
S +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    8.941616] systemd[1]: Detected architecture x86-64.
[    9.037323] systemd[1]: Set hostname to <v100>.
[   13.793558] systemd[1]: Created slice Virtual Machine and Container Slice.
[   13.805323] systemd[1]: Created slice system-modprobe.slice.
[   13.812920] systemd[1]: Created slice system-postfix.slice.
[   13.818096] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   13.822315] systemd[1]: Created slice User and Session Slice.
[   13.825454] systemd[1]: Started ntp-systemd-netif.path.
[   13.828387] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.831113] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   13.833583] systemd[1]: Reached target User and Group Name Lookups.
[   13.835799] systemd[1]: Reached target Slices.
[   13.837961] systemd[1]: Reached target Mounting snaps.
[   13.839987] systemd[1]: Reached target System Time Set.
[   13.842029] systemd[1]: Reached target Libvirt guests shutdown.
[   13.843987] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   13.845979] systemd[1]: Listening on LVM2 poll daemon socket.
[   13.847897] systemd[1]: Listening on multipathd control socket.
[   13.862306] systemd[1]: Listening on RPCbind Server Activation Socket.
[   13.864096] systemd[1]: Listening on Syslog Socket.
[   13.865923] systemd[1]: Listening on fsck to fsckd communication Socket.
[   13.867633] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   13.869493] systemd[1]: Listening on Journal Audit Socket.
[   13.871199] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.872888] systemd[1]: Listening on Journal Socket.
[   13.874662] systemd[1]: Listening on Network Service Netlink Socket.
[   13.876332] systemd[1]: Listening on udev Control Socket.
[   13.877922] systemd[1]: Listening on udev Kernel Socket.
[   13.880028] systemd[1]: Mounting Huge Pages File System...
[   13.882260] systemd[1]: Mounting POSIX Message Queue File System...
[   13.884382] systemd[1]: Mounting NFSD configuration filesystem...
[   13.886630] systemd[1]: Mounting RPC Pipe File System...
[   13.888873] systemd[1]: Mounting Kernel Debug File System...
[   13.891166] systemd[1]: Mounting Kernel Trace File System...
[   13.893701] systemd[1]: Starting Journal Service...
[   13.895716] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   13.896984] systemd[1]: Starting Set the console keyboard layout...
[   13.899528] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   13.901829] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   13.904119] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   13.905837] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   13.907115] systemd[1]: Starting Load Kernel Module efi_pstore...
[   13.909466] systemd[1]: Starting Load Kernel Module pstore_blk...
[   13.911759] systemd[1]: Starting Load Kernel Module pstore_zone...
[   13.914081] systemd[1]: Starting Load Kernel Module ramoops...
[   13.915803] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[   13.999231] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   14.002642] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   14.010677] systemd[1]: Starting Load Kernel Modules...
[   14.023046] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.035945] systemd[1]: Starting udev Coldplug all Devices...
[   14.043337] systemd[1]: Starting Uncomplicated firewall...
[   14.049121] systemd[1]: Mounted Huge Pages File System.
[   14.052403] systemd[1]: Mounted POSIX Message Queue File System.
[   14.055172] systemd[1]: Mounted Kernel Debug File System.
[   14.057883] systemd[1]: Mounted Kernel Trace File System.
[   14.060735] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   14.063573] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   14.181471] kernel: EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
[   14.197133] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.215571] kernel: pstore: Using crash dump compression: deflate
[   14.215588] kernel: pstore: Registered efi as persistent store backend
[   14.223733] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[   14.225978] systemd[1]: Finished Load Kernel Module efi_pstore.
[   14.231034] systemd[1]: Finished Uncomplicated firewall.
[   14.235519] systemd[1]: Activating swap /swap.img...
[   14.282230] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   14.283614] systemd[1]: Starting Load/Save Random Seed...
[   14.286104] systemd[1]: Starting Create System Users...
[   14.288049] systemd[1]: Started Journal Service.
[   14.435601] kernel: knem 1.1.4.90mlnx3: initialized
[   14.556902] kernel: RPC: Registered named UNIX socket transport module.
[   14.558287] kernel: RPC: Registered udp transport module.
[   14.559529] kernel: RPC: Registered tcp transport module.
[   14.560750] kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
[   14.830552] kernel: nvidia_fs: Initializing nvfs driver module
[   14.833501] kernel: nvidia_fs: registered correctly with major number 508
[   14.837704] kernel: nvidia-fs:warning: error retrieving numa node for device 0000:01:00.0
[   14.837719] kernel: nvidia-fs:warning: error retrieving numa node for device 0000:03:00.0
[   14.840609] kernel: nvidia-fs:warning: error retrieving numa node for device 0000:01:00.0
[   14.843462] kernel: nvidia-fs:warning: error retrieving numa node for device 0000:02:00.0
[   14.851542] kernel: Adding 4194300k swap on /swap.img.  Priority:-2 extents:5 across:4489212k FS
[   15.293903] kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   19.757887] kernel: parport_pc 00:01: reported by Plug and Play ACPI
[   19.757951] kernel: parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE,EPP]
[   19.783921] kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[   19.787143] kernel: nvidia-uvm: Loaded the UVM driver, major device number 506.
[   19.841917] kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[   19.841920] kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   19.841924] kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
[   19.841925] kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   19.902534] kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   19.991054] kernel: ppdev: user-space parallel port driver
[   20.047850] kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[   20.048344] kernel: ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[   20.060878] kernel: EDAC ie31200: No ECC support
[   20.668844] kernel: intel_tcc_cooling: Programmable TCC Offset detected
[   20.792908] kernel: intel_rapl_common: Found RAPL domain package
[   20.792916] kernel: intel_rapl_common: Found RAPL domain core
[   20.792920] kernel: intel_rapl_common: Found RAPL domain uncore
[   20.896909] kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   20.897628] kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   21.261749] kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[   21.261766] kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   21.261775] kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   21.261782] kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   21.261787] kernel: snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x0
[   21.261792] kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   21.261797] kernel: snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[   21.261803] kernel: snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[   21.261809] kernel: snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[   21.417887] kernel: input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[   21.418090] kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[   21.418328] kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[   21.418504] kernel: input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[   21.418676] kernel: input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[   21.418839] kernel: input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[   21.419007] kernel: input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   21.419175] kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   21.419340] kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[   21.419500] kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[   21.419657] kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[   21.419824] kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[   21.419985] kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[   22.977905] kernel: alua: device handler registered
[   22.981093] kernel: emc: device handler registered
[   22.984615] kernel: rdac: device handler registered
[   23.243427] kernel: loop0: detected capacity change from 0 to 113992
[   23.285728] kernel: loop1: detected capacity change from 0 to 130960
[   23.285861] kernel: loop2: detected capacity change from 0 to 80072
[   23.313879] kernel: loop3: detected capacity change from 0 to 113536
[   23.345807] kernel: loop4: detected capacity change from 0 to 144000
[   23.365770] kernel: loop5: detected capacity change from 0 to 188072
[   24.693489] kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   25.917980] kernel: audit: type=1400 audit(1713146076.667:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=857 comm="apparmor_parser"
[   25.920646] kernel: audit: type=1400 audit(1713146076.667:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=859 comm="apparmor_parser"
[   25.920648] kernel: audit: type=1400 audit(1713146076.667:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=859 co
[   25.932798] kernel: audit: type=1400 audit(1713146076.679:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=861 comm="apparmor_parser"
[   25.933336] kernel: audit: type=1400 audit(1713146076.679:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=856 comm="apparmor_parser"
[   25.933338] kernel: audit: type=1400 audit(1713146076.679:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=856 comm="apparmor_parser"
[   25.933837] kernel: audit: type=1400 audit(1713146076.683:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd" pid=860 comm="apparmor_parser"
[   25.933840] kernel: audit: type=1400 audit(1713146076.683:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd//qemu_bridge_helper" pid=860 comm="apparmor_parser"
[   25.936637] kernel: audit: type=1400 audit(1713146076.683:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=863 comm="apparmor_parser"
[   25.936641] kernel: audit: type=1400 audit(1713146076.683:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=863 comm="apparmor_parser"
[   34.353480] kernel: Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[   34.553582] kernel: r8169 0000:03:00.0 enp3s0: Link is Down
[   37.869768] kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
[   37.869793] kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[   39.972801] kernel: Process accounting resumed
[   45.831899] kernel: kauditd_printk_skb: 23 callbacks suppressed
[   45.831901] kernel: audit: type=1400 audit(1713146096.579:35): apparmor="DENIED" operation="open" profile="/usr/sbin/ntpd" name="/snap/bin/" pid=1167 comm="ntpd" requested_mask="r" denied_mask="r" fsuid=
0 ouid=0
[   46.829902] kernel: NFSD: Using UMH upcall client tracking operations.
[   46.829904] kernel: NFSD: starting 90-second grace period (net f0000000)
[   50.519526] kernel: IPMI message handler: version 39.2
[   50.699126] kernel: ipmi device interface
[   50.935625] kernel: ipmi_si: IPMI System Interface driver
[   50.935821] kernel: ipmi_si: Unable to find any System Interface(s)
[   51.640894] kernel: drbd: initialized. Version: 9.1.7 (api:2/proto:110-121)
[   51.640899] kernel: drbd: GIT-hash: bfd2450739e3e27cfd0a2eece2cde3d94ad993ae build by root@v100, 2024-04-11 09:48:18
[   51.640900] kernel: drbd: registered as block device major 147
What’s happened?If I missing some setting or other reasons?
Can anyone help me,thanks very much.
I add some debug info in nvme.ko. And I found that I use the same gpu memory(alloced by cudaMalloc)for cuFileRead and cuFileWrite ,and the debug info below:
[Fri Apr 19 15:00:50 2024] begin nvfs map data, req: 000000000678f2ff, sertor: 274432, len: 4096
[Fri Apr 19 15:00:50 2024] end nvfs map data, req: 000000000678f2ff, nvfs_io: 1
[Fri Apr 19 15:00:50 2024] bv_page: 000000000f902d1f, offset: 0, len: 4096
[Fri Apr 19 15:00:50 2024] page: 000000000f902d1f is page of GPU 1
[Fri Apr 19 15:00:50 2024] begin nvfs map data, req: 00000000368fefcd, sertor: 274440, len: 4096
[Fri Apr 19 15:00:50 2024] end nvfs map data, req: 00000000368fefcd, nvfs_io: 1
The req 000000000678f2ff is a read request,and the req 00000000368fefcd is a write request.
Since the gpu memory is same,so bv_page of the two request is same,is excepted.
But here are 2 question:
  1. why the read has correct data,but the write is wrong in file(all F).
  2. why the bv_page is belong GPU 1(through nvfs_ops->nvfs_gpu_index)?I have only one GPU on environment,and nvidia-smi show idx is 0;
Is there anyway to print the data of GPU page in kernel space?
I want to know what’s happened,the write req recive the wrong data?or the data map to nvme wrong.
This question is very troubling for me.
Can you paste the output of the following:
lsmod | grep nvidia
lsblk
mount -v | grep nvme
mount -v | grep /mnt/gds
The file-system you are running with
Additionally, can you run your test on a later version, say 12.3.
@ prashantp
Hi!
OS and kernel info:
root@v100:~# cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.3 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.3 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
root@v100:~# uname -a
Linux v100 5.15.0-67-generic #74~20.04.1-Ubuntu SMP Wed Feb 22 14:52:34 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
root@v100:~#
lsmod | grep nvidia:
root@v100:~# lsmod | grep nvidia
nvidia_uvm           1437696  0
nvidia_fs             262144  0
nvidia_drm             77824  2
nvidia_modeset       1273856  2 nvidia_drm
nvidia              55721984  109 nvidia_uvm,nvidia_modeset
drm_kms_helper        307200  2 nvidia_drm,i915
drm                   618496  10 drm_kms_helper,nvidia,nvidia_drm,i915,ttm
root@v100:~#
lsblk:
root@v100:~# lsblk
NAME                      MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0                       7:0    0  55.7M  1 loop /snap/core18/2812
loop1                       7:1    0    64M  1 loop /snap/core20/2264
loop2                       7:2    0  39.1M  1 loop /snap/snapd/21184
loop3                       7:3    0  91.9M  1 loop /snap/lxd/24061
loop4                       7:4    0  70.3M  1 loop /snap/lxd/21029
loop5                       7:5    0  55.4M  1 loop /snap/core18/2128
loop6                       7:6    0  38.8M  1 loop /snap/snapd/21465
sda                         8:0    0 931.5G  0 disk
├─sda1                      8:1    0   512M  0 part /boot/efi
├─sda2                      8:2    0     1G  0 part /boot
└─sda3                      8:3    0   930G  0 part
  └─ubuntu--vg-ubuntu--lv 253:0    0   200G  0 lvm  /
nvme0n1                   259:0    0 119.2G  0 disk /mnt/gds
root@v100:~#
mount -v | grep nvme:
root@v100:~# mount -v | grep nvme
/dev/nvme0n1 on /mnt/gds type ext4 (rw,relatime,data=ordered)
root@v100:~#
mount -v | grep /mnt/gds:
root@v100:~# mount -v | grep /mnt/gds
root@v100:~#
nvme info(M.2):
root@v100:~# nvme list
Node             SN                   Model                                    Namespace Usage                      Format           FW Rev
/dev/nvme0n1     PHHH849601SE128A     INTEL SSDPEKKW128G8                      1         128.04  GB / 128.04  GB    512   B +  0 B   004C
mainboard:
root@v100:~# sudo dmidecode | grep -A3 '^System Information'
System Information
        Manufacturer: Gigabyte Technology Co., Ltd.
        Product Name: B360 HD3
        Version: Default string
I also test on kernel:5.13.0-30 GDS version:11.8, but the same wrong occur.
When I install 12.3, it`s occur:
[Wed Apr 24 11:07:26 2024] nvidia_fs: module using GPL-only symbols uses symbols from proprietary module nvidia.
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_dma_unmap_pages (err -2)
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_get_pages (err -2)
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_put_pages (err -2)
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_dma_map_pages (err -2)
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_free_dma_mapping (err -2)
[Wed Apr 24 11:07:26 2024] nvidia_fs: Unknown symbol nvidia_p2p_free_page_table (err -2)
I found for Volta, it’s only can use the proprietary kernel modules. But since 12.2, it’s only support the open source kernel modules,so I use the 12.1.
