申请提升 NVIDIA NIM API 速率限制(40 RPM 至 200 RPM)
尊敬的 NVIDIA 支持团队:
您好!
我是一名个人开发者,目前正基于 NVIDIA NIM 平台进行多智能体(Multi-Agent)自动化工作流的个人学习与开发。
申请详情如下:
  • 账户邮箱:[jiaqing77cn@gmail.com]
  • API Key ID(后4位):[sway]
  • 当前限额:40 RPM
  • 申请限额:200 RPM
  • 主要使用模型:[deepseek-ai/deepseek-v4-flash、deepseek-ai/deepseek-v4-pro、moonshotai/kimi-k2.6、z-ai/glm-5.2、z-ai/glm-5.2、 minimaxai/minimax-m2.7等]
申请理由:
我的开发系统在执行单次复杂任务时(例如:软件环境搭建、浏览器自动化、任务拆解与多 Agent 协同),会涉及多轮推理、工具调用、结果校验与自我纠错。一个完整的任务流程通常需要发起 20 -50次API 请求。在当前 40 RPM 的限制下,经常触发 429 错误,导致任务中断,严重阻碍开发调试效率。
使用场景说明:
我的使用仅限于本地开发环境,用于验证技术方案与学习交流,属于纯粹的个人学习项目,非任何商业化生产环境。请求频率完全由单次任务的复杂度驱动,而非大规模并发,预计不会对平台服务造成异常压力。
鉴于以上实际开发需求,恳请支持团队审阅并批准我的速率提升请求,以便我能更顺畅地完成学习与测试工作。如果需要提供任何额外的使用详情或验证信息,请随时告知。
感谢您的支持与审阅!
此致
敬礼
Hey @jiaqing77cn I don’t know if this helps, but a moderator previously replied with this to someone asking for the same thing as you:“Many of you are using free tier API access to NVIDIA NIMs. This usually involves a rate limit that is dependent on model, use-case and the amount of current overall traffic using the same access. There is no official way to circumvent this rate limit or to receive a rate limit increase on that same tier. And specifically here on the forums we do not have any influence on those rate limits. To make full use of a NIM blueprint you will need to deploy it. For more details on NVIDIA NIM refer to…”
Basically, this means that if you are using the free-tier API, you have absolutely no right to request an RPM increase in free-tier. The only way to legitimately request higher RPM limits is:
Not through the forum. Moderators have said it over and over again: the forum is not the place to request RPM increases, as there are other channels and processes for that.
You need to pay and deploy a model through NVIDIA NIM / NVIDIA Build if you require higher usage limits and production-level access.
First, go to the model you prefer, for example DeepSeek V4 Flash. In that section you’ll see three options: Experience / Model Card / Deploy.
Click on Deploy and you’ll see several options such as Partner Endpoints or Self-hosted Deployments.
From there, you choose the option you want, and it will show you the pricing and deployment costs.
You can start with DeepSeek Flash since it’s the cheapest one, so you can learn how the process works first. And if you need help, you can always contact a moderator privately and ask for guidance. There’s no problem with sending a direct message saying you want to pay and deploy properly.
I am not saying this to be toxic, rude, or disrespectful. My goal is simply to help you understand and follow NVIDIA’s rules and the guidance that has already been provided by moderators multiple times.
IF YOU ARE ALREADY PAYING FOR NVIDIA SERVICES AND DEPLOYED MODELS, THEN YOU SHOULD CONTACT NVIDIA DIRECTLY THROUGH THE APPROPRIATE SUPPORT CHANNELS, SUCH AS EMAIL OR PRIVATE COMMUNICATION WITH THE RELEVANT SUPPORT TEAM, RATHER THAN MAKING RPM INCREASE REQUESTS ON THE FORUM.
