I have been noticing this error after my machine is up for a few moments.
sudo nvidia-smi
Unable to determine the device handle for GPU0000:08:00.0: Unknown Error
This is after plex was using the driver just fine a few minutes prior.
joshu@server:~$ sudo nvidia-smi
Mon Jan 23 11:46:40 2023
| NVIDIA-SMI 525.60.13 Driver Version: 525.60.13 CUDA Version: 12.0 |
| | | MIG M. |
| 0 Tesla P4 On | 00000000:08:00.0 Off | 0 |
| N/A 87C P0 30W / 75W | 367MiB / 7680MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 6354 C …diaserver/Plex Transcoder 167MiB |
| 0 N/A N/A 7214 C …diaserver/Plex Transcoder 197MiB |
Here is a bug report. Note I think that the gpu is falling off the bus.
nvidia-bug-report.log.gz (152.5 KB)
dmesg is showing this:
[ 505.050774] NVRM: GPU at PCI:0000:08:00: GPU-06c5ac54-038b-1629-7e67-9c7f9a55c914
[ 505.050787] NVRM: GPU Board Serial Number: 0422818015279
[ 505.050791] NVRM: Xid (PCI:0000:08:00): 79, pid=‘’, name=, GPU has fallen off the bus.
[ 505.050796] NVRM: GPU 0000:08:00.0: GPU has fallen off the bus.
[ 505.050799] NVRM: GPU 0000:08:00.0: GPU serial number is 0422818015279.
[ 505.050814] NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
Then when I run nvidia-smi I get this:
joshu@server:~$ sudo nvidia-smi -pm 1
I wonder if its cooling. Per this post
Here are the last couple temps it reported before it ‘fell off the bus’
Mon Jan 23 11:46:39 2023
| | | MIG M. |
| | | N/A |
| Processes: |
| ID ID Usage |
| | | MIG M. |
| | | N/A |
| Processes: |
| ID ID Usage |
