(1) Login at https://developer.nvidia.com/user/login
(2) Click green link “CUDA/GPU Computing Registered Developer Program”
(3) Under heading “Reporting An Issue” click green link “The Submit a Bug Form”
hi, I have nvidia gtx 1650 graphic card and the same issue with my computer right now and I was trying to find a solution about it but there is not much of a solution on internet. The only same question was yours but could not understand how you solved it. Could you please explain it to me? How can I check if CUDA/GPU Computing Resgistered Developer Program is approved?
this is my nvidia-smi output
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| 0 ERR! On | 00000000:01:00.0 Off | N/A |
| N/A 50C P8 1W / N/A | 781MiB / 3914MiB | 6% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1065 G /usr/lib/xorg/Xorg 72MiB |
| 0 1171 G /usr/bin/gnome-shell 50MiB |
| 0 1965 G /usr/lib/xorg/Xorg 348MiB |
| 0 2200 G /usr/bin/gnome-shell 303MiB |
| 0 8209 G /usr/bin/nvidia-settings 2MiB |
Hi,my 1050ti have the same ERR!
Fri Feb 11 11:10:46 2022
| NVIDIA-SMI 456.43 Driver Version: 456.43 CUDA Version: 11.1 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 ERR! WDDM | 00000000:01:00.0 N/A | N/A |
| 38% 23C P8 N/A / N/A | 389MiB / 2048MiB | N/A Default |
| Processes: |
| ID ID Usage |
| No running processes found |
How to fix it?
It was many years ago and I don’t remember if the problem with the name of the video card was solved, but I remember the main problem that I solved then. I had two video cards, and when parallelizing on both, after 20-60 minutes I got a crash, although the program worked correctly for days on the single video card. The problem was that the nouveau built-in open-source driver in Linux conflicted with NVIDIA’s proprietary drivers. Perhaps the problem of the incorrect name of the video card was also related with this.
