The workaround for the suspend issue does not work for me. When I wake up, the screen remains black. I switched to wayland using Ubuntu 25.14. Going back to X11 is also not an option, because WebGL does not work anymore then.
Do you you sudo to start nvidia-smi? I have experienced the issue only when used with sudo.
Regarding suspend, it has never worked with Wayland (on Nvidia cards) AFAIK and now with the latest drivers it appears to be broken even in X11 sessions.
instead of using the legacy way of enabling persistence mode nvidia-smi -pm 1 (which is failing) also checked status of nvidia-persistenced systemd service
# systemctl status nvidia-persistenced
● nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-persistenced.service; static)
Active: active (running) since Sat 2025-07-19 19:45:33 PDT; 2h 1min ago
Invocation: 16411c7efda044778730b76ed5e2eac4
Process: 1905 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, status=0/SUCCESS)
Main PID: 1939 (nvidia-persiste)
Tasks: 1 (limit: 36516)
Memory: 360K (peak: 1.6M)
CPU: 102ms
CGroup: /system.slice/nvidia-persistenced.service
└─1939 /usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose
Jul 19 19:45:33 rnv systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: Verbose syslog connection opened
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: Now running with user ID 120 and group ID 123
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: Started (1939)
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: device 0000:01:00.0 - registered
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: device 0000:05:00.0 - registered
Jul 19 19:45:33 rnv nvidia-persistenced[1939]: Local RPC services initialized
Jul 19 19:45:33 rnv systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
which is slightly confusing as the daemon is by default configured to run with --no-persistence-mode, so edited that part out and restarted the service which apparently reports no issues and reports “persistence mode enabled”.
# systemctl edit nvidia-persistenced.service --full
Successfully installed edited file '/etc/systemd/system/nvidia-persistenced.service'.
# systemctl daemon-reload
# systemctl restart nvidia-persistenced
Loaded: loaded (/etc/systemd/system/nvidia-persistenced.service; static)
Active: active (running) since Sat 2025-07-19 21:48:52 PDT; 5s ago
Invocation: 76aca0176b22464381e8f94685c7d60b
Process: 11763 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --verbose (code=exited, status=0/SUCCESS)
Main PID: 11765 (nvidia-persiste)
Memory: 600K (peak: 1.7M)
CPU: 10ms
└─11765 /usr/bin/nvidia-persistenced --user nvidia-persistenced --verbose
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: Now running with user ID 120 and group ID 123
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: Started (11765)
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:01:00.0 - registered
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:01:00.0 - persistence mode enabled.
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:01:00.0 - NUMA memory onlined.
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:05:00.0 - registered
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:05:00.0 - persistence mode enabled.
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: device 0000:05:00.0 - NUMA memory onlined.
Jul 19 21:48:52 rnv nvidia-persistenced[11765]: Local RPC services initialized
Jul 19 21:48:52 rnv systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
Yet, nvidia-smi still reports the persistence mode to be off.
# nvidia-smi
Sat Jul 19 21:49:09 2025
| NVIDIA-SMI 570.158.01 Driver Version: 570.158.01 CUDA Version: 12.8 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5070 Off | 00000000:01:00.0 Off | N/A |
| 0% 32C P8 8W / 250W | 235MiB / 12227MiB | 0% Default |
| | | N/A |
| 1 NVIDIA GeForce RTX 4070 Off | 00000000:05:00.0 Off | N/A |
| 0% 27C P8 1W / 200W | 16MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2411 G /usr/bin/gnome-shell 176MiB |
| 0 N/A N/A 2506 G /usr/bin/Xwayland 3MiB |
| 1 N/A N/A 2411 G /usr/bin/gnome-shell 2MiB |
Unsure, of the discrepancy, and which reporting to trust. nvidia-smi or nvidia-persistenced.
