NVIDIA TensorRT not compatible with CUDA 11.1
My environment
CUDA 11.1.0
Cudnn 8.0.4.30
TensorRT 7.2.0.14
RTX 3080
Tensorflow 2.3.1 built from source in the mentioned env.
The latest version of TensorRT 7.2 supports only CUDA 11.0. It does not work properly with CUDA 11.1.
Optimizing yolov4 with TRT yield this error :
2020-10-15 14:46:29.374511: W tensorflow/stream_executor/platform/default/dso_loader.cc:59]
Could not load dynamic library 'libnvinfer.so.7'; dlerror: /usr/local/cuda-11.1/lib64/libnvrtc.so.11.0:
version `libnvrtc.so.11.0' not found (required by /usr/local/TensorRT-7.2.0.14/lib/libnvinfer.so.7);
LD_LIBRARY_PATH: :/usr/local/cuda-11.1/lib64:/usr/local/cuda-11.1/include:/usr/local/TensorRT-7.2.0.14:/usr/local/TensorRT-7.2.0.14/include:/usr/local/TensorRT-7.2.0.14/lib
2020-10-15 14:46:29.374533: F tensorflow/compiler/tf2tensorrt/stub/nvinfer_stub.cc:49] getInferLibVersion symbol not found.
I already tried older CUDA version up to 11.0.3 but in all cases the driver doesn’t recognize the device.
Is there any solution to make TRT work with CUDA 11.1 or any date for a compatible TRT version?
TRT 7.2.0 supports only CUDA 11.0. Please refer to below link for your reference:
Please stay tuned for announcements for TRT support on CUDA 11.1.
Thanks for the reply. Do you have a projected date for the release? I
Sorry, I don’t have that information right now. Will update you as soon as I hear anything about it.
