My current setup is as follows:
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.0
• TensorRT Version: 8.2.3
• NVIDIA GPU Driver: 470.103.01
• Issue Type: question
Is it possible to configure nvinfer
to load a dynamic engine with multiple optimization profiles without the onnx model? or I must provide an onnx and let nvinfer
generate a new engine with a single optimization profile as mentioned here?
I am looking for way to reduce the down time of having to switch models together with the generation time needed by each new engine creation. On the Fly model update might do the trick but will it regenerate the engine as it did initially or I will need to regenerate the engine myself?
Best Regards,
