"nvprof -m dram_read_bytes" has strange error?
My problem is the output number of “nvprof -m dram_read_bytes” has small error compared to theoretical value. And the error can be much larger when there is other --metrics option in the command.
My device: V100-SXM2 16GB
nvidia driver version: 410.104
cuda version: 10.0
nvprof version: Release version 10.0.130 (21)
nvcc version: release 10.0, V10.0.130
Following is my full codes, a simple add kernel of two 1 million int vector.
#include <cuda_runtime.h>
#include <iostream>
using std::cout;
using std::endl;
#define CUDA_CHECK(x) \
    { cudaError_t cuda_error = x; \
        if (cuda_error != cudaSuccess) \
            cout << "cudaError_t: " << cuda_error << " != 0 " \
                 << cudaGetErrorString(cuda_error) << endl; \
#define LEN 1000000
// kernel functions
template<typename Dtype>
__global__ void add_kernel(const int N, const Dtype* a, const Dtype* b, Dtype* c){
    for (int i = threadIdx.x; i < N; i += gridDim.x * blockDim.x){
        c[i] = a[i] + b[i];
int main(){
    // host memory malloc & initial
    int* host_a = new int[LEN];
    int* host_b = new int[LEN];
    int* host_c = new int[LEN];
    for (int i = 0; i < LEN; ++i){
        host_a[i] = i;
        host_b[i] = i * 100;
        host_c[i] = -1;
    // GPU device start
    int device_id = 0;
    CUDA_CHECK(cudaSetDevice(device_id));
    cout << "Using GPU " << device_id << "." << endl;
    // cudaMalloc & cudaMemcpy & cudaMemset
    int* dev_a;
    int* dev_b;
    int* dev_c;
    CUDA_CHECK(cudaMalloc((void**)&dev_a, LEN * sizeof(int)));
    CUDA_CHECK(cudaMalloc((void**)&dev_b, LEN * sizeof(int)));
    CUDA_CHECK(cudaMalloc((void**)&dev_c, LEN * sizeof(int)));
    CUDA_CHECK(cudaMemcpy(dev_a, host_a, LEN * sizeof(int), cudaMemcpyHostToDevice));
    CUDA_CHECK(cudaMemcpy(dev_b, host_b, LEN * sizeof(int), cudaMemcpyHostToDevice));
    CUDA_CHECK(cudaMemset(dev_c, 0, LEN * sizeof(int)));
    dim3 grid_dim(1, 1, 1);
    dim3 block_dim(128, 1, 1);
    add_kernel<int><<<grid_dim, block_dim>>>(LEN, dev_a, dev_b, dev_c);
    CUDA_CHECK(cudaMemcpy(host_c, dev_c, LEN * sizeof(int), cudaMemcpyDeviceToHost));
    // Free gpu memory & free cpu memory
    CUDA_CHECK(cudaFree(dev_a));
    CUDA_CHECK(cudaFree(dev_b));
    CUDA_CHECK(cudaFree(dev_c));
    delete[] host_a;
    delete[] host_b;
    delete[] host_c;
    return 0;
Build the code using:
nvcc add.cu
I profile ./a.out:
nvprof -m dram_read_bytes ./a.out
Using GPU 0.
==309850== Profiling application: ./a.out
==309850== Profiling result:
==309850== Metric result:
Invocations                               Metric Name                        Metric Description         Min         Max         Avg
Device "Tesla V100-SXM2-16GB (0)"
    Kernel: void add_kernel<int>(int, int const *, int const *, int*)
          1                           dram_read_bytes    Total bytes read from DRAM to L2 cache     7999936     7999936     7999936
This is the first problem: every time I execute “nvprof -m dram_read_bytes ./a.out”, the output number of dram_read_bytes changes around 8000000 with negligible error.(I tried dozens of times.)
Then, I profile ./a.out with other –metrics option chosen along with dram_read_bytes.
nvprof -m dram_read_bytes -m sysmem_read_bytes ./a.out
Using GPU 0.
          1                           dram_read_bytes    Total bytes read from DRAM to L2 cache     7407200     7407200     7407200
          1                         sysmem_read_bytes                  System Memory Read Bytes           0           0           0
Here is the second problem: the output number of dram_read_bytes become much smaller the theoretical value 8000000. (I tried dozens of times.)
Is this a bug or does anyone knows the reason about it?
We are able to reproduce the second problem. We will try and fix this in the next release.
Thanks for providing the details.
Ramesh
