NVRM: RmInitAdapter failed! - Proxmox GPU Passthrough
Hello!
I’ve been looking through the internet in trying to solve my issue but haven’t been able to stitch together the right solution.
tl;dr I have Proxmox running with a Quadro P400 on a riser and I’m trying to pass the GPU into a VM.
I have followed these steps to pass through the PCIe device to the VM → PCI(e) Passthrough - Proxmox VE .
In Proxmox, lspci gets me:
02:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P400] (rev a1)
02:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
In VM, lspci gets me:
01:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P400] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
In VM, dmesg | grep NVRM gets me:
[   2.258005] NVRM: loading NVIDIA UNIX x86_64 Kernel Module    470.82.01    Wed Oct 27 21:21:55 UTC 2021
[   7.969112] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x22:0x56:667)
[   7.969407] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Output of nvidia-smi:
No devices were found
The bug report can be found here: nvidia-bug-report.log.gz (89.1 KB)
Thank you in advance for your help!
Add me to the list…
I have exactly the same problem with the same GPU on Proxmox.
Did you came to a solution?
Add this to your VM’s config file:
cpu: host,hidden=1
It worked! Thank you so much!
