[nvshmem4py] nvshmem.core.get_peer_tensor with reuse got error
nvshmem4py got some bugs here:
for
t = nvshmem.core.tensor(shape, dtype)
t_p = nvshmem.core.get_peer_tensor(t, pe)
nvshmem.core.free_tensor(t)
nvshmem.core.free_tensor(t_p). # free peer_tensor or not, you got error anyway.
# then allocate and get peer again
t = nvshmem.core.tensor(another_shape, dtype)
it’s because the NvshememResource.get_peer_buffer logic:
line 184 only checks if buffer is recorded in the _mem_references, but not check the buffer size: if the size is different from the cache and the buffer’s size is wrong:
if i did not call nvshmem.core.free_tensor(t_p), then the shape is wrong.
if I called nvshmem.core.free_tensor(t_p), then buffer.mr is None
here is the python re-produce code
import torch.distributed as dist
import torch
import triton
import triton.language as tl
import nvshmem.core
import os
from cuda.core.experimental import Device, system
import nvshmem.core.utils
from torch.profiler import record_function
class PyTorchStreamWrapper:
    def __init__(self, pt_stream):
        self.pt_stream = pt_stream
        self.handle = pt_stream.cuda_stream
    def __cuda_stream__(self):
        stream_id = self.pt_stream.cuda_stream
        return (0, stream_id)  # Return format required by CUDA Python
def torchrun_uid_init():
    Initialize NVSHMEM using UniqueID with `torchrun` as the launcher
    # Set Torch device
    local_rank = int(os.environ["LOCAL_RANK"])
    torch.cuda.set_device(local_rank)
    device = torch.device("cuda", local_rank)
    # nvshmem4py requires a cuda.core Device at init time
    global dev
    dev = Device(device.index)
    dev.set_current()
    global stream
    # Get PyTorch's current stream
    pt_stream = torch.cuda.current_stream()
    stream = PyTorchStreamWrapper(pt_stream)
    # Initialize torch.distributed process group
    world_size = torch.cuda.device_count()
    dist.init_process_group(
        backend="cpu:gloo,cuda:nccl", rank=local_rank, world_size=world_size, device_id=device
    # Extract rank, nranks from process group
    num_ranks = dist.get_world_size()
    rank_id = dist.get_rank()
    # Create an empty uniqueid for all ranks
    uniqueid = nvshmem.core.get_unique_id(empty=True)
    if rank_id == 0:
        # Rank 0 gets a real uniqueid
        uniqueid = nvshmem.core.get_unique_id()
        broadcast_objects = [uniqueid]
    else:
        broadcast_objects = [None]
    # We use torch.distributed.broadcast_object_list to send the UID to all ranks
    dist.broadcast_object_list(broadcast_objects, src=0)
    dist.barrier()
    nvshmem.core.init(
        device=dev,
        uid=broadcast_objects[0],
        rank=rank_id,
        nranks=num_ranks,
        initializer_method="uid",
def test_get_peer_memory():
    import random
    for _ in range(10):
        M = random.randint(16, 1024)
        shape = (M, 1024)
        t = nvshmem.core.tensor(shape, dtype=torch.float16)
        rank = int(os.getenv("RANK"))
        if rank == 0:
            t_peer = nvshmem.core.get_peer_tensor(t, 1)
        # comment this if or not, you got error anyway.
        if rank == 0:
            nvshmem.core.free_tensor(t_peer)
if __name__ == "__main__":
    torchrun_uid_init()
    nvshmem.core.utils._configure_logging(level="DEBUG")
    nvshmem.core.finalize()
    dist.destroy_process_group()
Hi, thank you for the report.
A peer tensor should never have a different size than its parent tensor, and it should never share a pointer with another tensor. Also, from NVSHMEM4Py’s perspective, close() on a peer tensor is a no-op. It seems what’s happening here is that the parent buffer gets freed when you free the parent tensor. Then, you free the child tensor which is a no-op but we should actually delete the internal tracking resources associated with it to avoid this happening on the next iteration.
I was able to solve this internally by adding del self._mem_references[ptr] in the free path for peer_buffers. This results in them always getting recreated correctly instead of using stale references to the old Buffers. I will open an internal tracking bug and get back to you with steps to fix.
In the mean time, I will think about the best workaround
Creating/free a peer tensor is cheap. I guess no need to keep track of peer tensors. user should make sure they don’t use peer tensor when the nvshmem.core.tensor is freed
That would be one solution. Another one would be to delete all references to peer tensors when a parent tensor is freed.
