• Hardware Platform (GPU)
• DeepStream Version 6.1.1
• TensorRT Version 8.4.3.1
• NVIDIA GPU Driver Version 525.125.06
• Issue Type(questions)
We are trying to control/limit the amount of decoded buffers on the GPU by the nvv4l2decoder
In the sample attached below, when we use a CPU decoder avdec_h264
the queue
buffers the decoded frames normally independent of the downstream elements. However, if we use nvv4l2decoder
the queue buffers at most 2 decoded frames.
Note that in both cases the queue
is set to have unlimited size.
How can we control the amount of buffers available for decoder nvv4l2decoder
Is it possible through bufferpool size adjustment?
gst-sample.zip (1.0 MB)
