Hello, we develop Savant: a general-purpose high-level CV framework on DeepStream. Thus we test various functions and need them to work properly. The one function is conditional video encoding which is affected by the bug. Our developer implemented a workaround rearranging the frames properly on Jetson, but we believe it is beneficial to fix it in the core.
Related topics
| GStream: nvv4l2h264enc: B-Frames display ordering is not right | 10 | 3035 | November 11, 2019 | |
| PTS values altered by nvv4l2h64enc | 15 | 2046 | April 21, 2023 | |
| PTS getting changed while DTS is in order, causing jitter/stutter/jumpy video playback | 5 | 896 | February 20, 2024 | |
| Unexpected PTS Ordering in H.264 Video Stream with GStreamer Pipeline on Jetson Tx2-nx | 1 | 894 | July 10, 2023 | |
| Incorrect DTS during encoding via nvv encoder | 6 | 1115 | March 24, 2023 | |
| Nvv4l2h264enc framerate problem | 4 | 1786 | August 20, 2021 | |
| Incorrect timestamping during decoding vp9 video by nvv4l2decoder | 15 | 1497 | March 8, 2023 | |
| Filesink saving files with different bitrate and fps from the source? | 22 | 3481 | April 9, 2020 | |
| Occasionally nvv4l2h265enc drops the last frame | 11 | 1621 | April 25, 2024 | |
| The frame order is not in sequence | 3 | 243 | May 13, 2024 |
