If you have tested all interpolation-method and still don’t meet the requirement, it may be an limitation of hardware converter. Maybe you can consider to use software converter if it brings enough performance. In using software converter, the CPU loading is high and please execute sudo jetson_clocks to fix CPUs at max clocks.
I’ve already tried and it doesn’t seem to change anything.
The big issue seems that anti-alising is missing. I cannot use OpenCV in order to apply anti-aliasing cause Jetson nano CPU is too low powerful to manage a 1080p 25FPS scaled to 720p 25FPS.
I’ve also compiled OpenCV 4.4.0 and tried to use OpenCV Cuda resize but performance are not comparable with hardware acceleration.
