Deepstream 6.2 on dGPU
Im trying to write a custom parser for a model, I have added required files. Im getting seg faults and im not able to understand why. can you please look into it ?
this model is face detector model that outputs bbox and landmarks as well.
this is the probe function that im using to get the bbox and landmark info
struct bbox_lmk
float x1;
float y1;
float x2;
float y2;
float s;
float lm_x1;
float lm_y1;
float lm_x2;
float lm_y2;
float lm_x3;
float lm_y3;
float lm_x4;
float lm_y4;
float lm_x5;
float lm_y5;
bool NvDsInferParseFaceDetector(
std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector<NvDsInferObjectDetectionInfo> &objectList ,
std::vector<bbox> &lmkList) ;
static GstPadProbeReturn
pgie_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
static guint use_device_mem = 0;
GstBuffer *buf = (GstBuffer *)info->data;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
int bboxLayerIndex = -1, confLayerIndex = -1, lmkLayerIndex = -1;
NvDsInferParseDetectionParams detectionParams;
detectionParams.numClassesConfigured = 1;
static NvDsInferNetworkInfo networkInfo{
PGIE_NET_WIDTH, PGIE_NET_HEIGHT, 3};
// NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
gst_buffer_get_nvds_batch_meta(GST_BUFFER(info->data));
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
for (NvDsMetaList *l_user = frame_meta->frame_user_meta_list;
l_user != NULL; l_user = l_user->next)
NvDsUserMeta *user_meta = (NvDsUserMeta *)l_user->data;
if (user_meta->base_meta.meta_type != NVDSINFER_TENSOR_OUTPUT_META)
continue;
/* convert to tensor metadata */
NvDsInferTensorMeta *meta =
(NvDsInferTensorMeta *)user_meta->user_meta_data;
for (unsigned int i = 0; i < meta->num_output_layers; i++)
NvDsInferLayerInfo *info = &meta->output_layers_info[i];
info->buffer = meta->out_buf_ptrs_host[i];
if (use_device_mem && meta->out_buf_ptrs_dev[i])
cudaMemcpy(meta->out_buf_ptrs_host[i], meta->out_buf_ptrs_dev[i],
info->inferDims.numElements * 4, cudaMemcpyDeviceToHost);
outputLayersInfo(meta->output_layers_info,
meta->output_layers_info + meta->num_output_layers);
std::vector<NvDsInferObjectDetectionInfo> objectList;
std::vector<bbox> lmkList;
NvDsInferParseFaceDetector(outputLayersInfo, networkInfo,
detectionParams, objectList , lmkList);
std::cout << "after parsing " << std::endl;
/* Seperate detection rectangles per class for grouping. */
std::vector<std::vector<
cv::Rect>>
objectListClasses(1);
std::cout << "before the for loop" << std::endl;
for (auto &obj : objectList)
objectListClasses[obj.classId].emplace_back(obj.left, obj.top,
obj.width, obj.height);
std::cout << "after the for loop" << std::endl;
for (uint32_t c = 0; c < objectListClasses.size(); ++c)
auto &objlist = objectListClasses[c];
if (objlist.empty())
continue;
/* Merge and cluster similar detection results */
cv::groupRectangles(objlist, 0.5, 0.1);
for (const auto &rect : objlist)
nvds_acquire_obj_meta_from_pool(batch_meta);
obj_meta->unique_component_id = meta->unique_id;
obj_meta->confidence = 0.0;
/* This is an untracked object. Set tracking_id to -1. */
obj_meta->object_id = UNTRACKED_OBJECT_ID;
obj_meta->class_id = 1;
std::cout << "middle 1 " << std::endl;
NvOSD_RectParams &rect_params = obj_meta->rect_params;
NvOSD_TextParams &text_params = obj_meta->text_params;
/* Assign bounding box coordinates. */
rect_params.left = rect.x * MUXER_OUTPUT_WIDTH / PGIE_NET_WIDTH;
rect_params.top = rect.y * MUXER_OUTPUT_HEIGHT / PGIE_NET_HEIGHT;
rect_params.width = rect.width * MUXER_OUTPUT_WIDTH / PGIE_NET_WIDTH;
rect_params.height =
rect.height * MUXER_OUTPUT_HEIGHT / PGIE_NET_HEIGHT;
/* Border of width 3. */
rect_params.border_width = 3;
rect_params.has_bg_color = 0;
rect_params.border_color = (NvOSD_ColorParams){
1, 0, 0, 1};
/* display_text requires heap allocated memory. */
text_params.display_text = g_strdup(pgie_classes_str[c]);
/* Display text above the left top corner of the object. */
text_params.x_offset = rect_params.left;
text_params.y_offset = rect_params.top - 10;
/* Set black background for the text. */
text_params.set_bg_clr = 1;
text_params.text_bg_clr = (NvOSD_ColorParams){
0, 0, 0, 1};
/* Font face, size and color. */
text_params.font_params.font_name = (gchar *)"Serif";
text_params.font_params.font_size = 11;
text_params.font_params.font_color = (NvOSD_ColorParams){
1, 1, 1, 1};
nvds_add_obj_meta_to_frame(frame_meta, obj_meta, NULL);
std::cout << "after adding obj meta to frame meta " << std::endl;
NvDsDisplayMeta *display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_CircleParams *circle_params = display_meta->circle_params;
std::cout << "getting circle params " << std::endl;
for (int j = 0; j < lmkList.size() ; j++)
for (int i = 0 ; i < 5 ; i++ ) //this may only work for one face in the image
circle_params[i].xc = lmkList[j].landmarks[i].xn * MUXER_OUTPUT_WIDTH / PGIE_NET_WIDTH ;
circle_params[i].yc = lmkList[j].landmarks[i].yn * MUXER_OUTPUT_HEIGHT / PGIE_NET_HEIGHT ;
circle_params[i].radius = 2;
circle_params[i].circle_color = (NvOSD_ColorParams){0.0, 1.0, 0.0, 1.0};
display_meta->num_circles++;
nvds_add_display_meta_to_frame(frame_meta,display_meta );
std::cout << "after adding metadata" << std::endl;
return GST_PAD_PROBE_OK;
oneMB.zip (3.4 MB)
custom parser is in the zip file that I have uploaded.
