Could you go to kernel/nvidia/drivers/pci/dwc/pcie-tegra.c and directly hardcoded the init_speed variable to 1 and see if that works?
I find that CONFIG_ARCH_TEGRA_19x_SOC
is not enabled and it cannot be enabled through menuconfig.
It seems that we use kernel-5.10/drivers/pci/controller/pci-tegra.c
instead of kernel/nvidia/drivers/pci/dwc/pcie-tegra.c
Hi WayneWWW! If the above is failed to work. I wonder that how to use setpci
command to operate registers and upgrade the pcie from gen1 to gen3.
Sorry for late reply.
We’ve tried writing some testing code. With rebooting thousands time, the problem not shows up again. But I have no time to clean up the code and share the changes here till middle of the May. Here is what I’ve found: The start of the problem is at tegra_pcie_dw_host_init
at drivers/pci/controller/dwc/pcie-tegra194.c
. In this function there is tegra_pcie_prepare_host
, and it will finally call the dw_pcie_link_set_max_speed
which is located at drivers/pci/controller/dwc/pcie-designware.c
. This function set the link speed to be equal to link capacity, which does not meet the requirement of the AQC113C controller.
What I’ve done is by handle the 14160000.pcie
separately:
- force the link speed to be gen-1 in the
, while keeping the link capacity to be the origin value. - change the link speed to be gen-3 after
integra_pcie_dw_host_init
. The "change link speed“ function is modified fromapply_speed_change
which is in the same file.
Here is my rough patch for anyone met the same problem.
To skip a lot useless retries, please add the max-link-speed = <0x3>;
in pcie@14160000
node.
0001-pcie-fixed-14160000-AQC113C-failed-to-link-up.patch.txt (10.5 KB)
