I just read an old paper from “Gregory Diamos” on Ocelot. The paper is titled “The design and implementation of Ocelot’s Dynamic Binary Translator from PTX to multi-core x86”.
Section III A, talks about how to extract PTX binary information. As I tried to verify the information, I realize the the way the binary is registered and stored in CUDA 2.3 (thats what I have on my linux box) is quite different from what the paper claims.
For example, there is only a single constructor that registers all kernels (as opposed to a constructor per kernel), the extern variable “fatBinary” no more exists and so on.
So, I assume that NVIDIA has chagned their internal binary representation and their APIs a bit in some CUDA version.
So, my questions to Greg (and to other knowledgeable ones) are:
0. Is my assumption right? I hope I am talking sense here… If no, dont read the next 2 questions.
Is Ocelot particular to any CUDA version? OR Does it have compatibility issues with CUDA versions?
Is Ocelot being updated, everytime NVIDIA decides to change their binary layout?
So when I wrote that part of the paper I was trying to write in generic terms rather than by referring to every variable by name. So by a fat binary, I meant a
typedef struct __cudaFatCudaBinaryRec {
unsigned long magic;
unsigned long version;
unsigned long gpuInfoVersion;
char* key;
char* ident;
char* usageMode;
__cudaFatPtxEntry *ptx;
__cudaFatCubinEntry *cubin;
__cudaFatDebugEntry *debug;
void* debugInfo;
unsigned int flags;
__cudaFatSymbol *exported;
__cudaFatSymbol *imported;
struct __cudaFatCudaBinaryRec *dependends;
unsigned int characteristic;
__cudaFatElfEntry *elf;
} __cudaFatCudaBinary;
This has actually remained more or less constant from one cuda version to the next. Each fat binary is registered once via a global constructor, and then a series of __cudaRegisterFunction calls are made, one for each kernel, also by global constructors.
NVIDIA adds and removes API functions on pretty much every CUDA version, so even though the binary format is fairly standard, a version of Ocelot is typically tied to a version of CUDA.
It would be if the binary format ever changed significantly enough to cause a bug.
char* key;
char* ident;
char* usageMode;
void* debugInfo;
unsigned int flags;
Vow! Thanks for answering! Its the same that I am seeing here… but how could one get the “PTX” corresponding to each kernel name from this info?
This was the most difficult part for me…I see an array of binary numbers out there… but which one corresponds to which kernel? How did you figure that out? btw, Great work!
There isn’t a whole lot of documentation on the PTX parser. It is composed of a FLEX description of how to convert text into tokens and then a BISON parser that converts from tokens into PTXStatements. This parser makes callbacks into a PTXParser class that actually creates the statements when a pattern is matched. This is done in order to make the BISON source file more readable.
If you’re interested in another version of a PTX grammar, I wrote one as well, in Antlr. It is LL as opposed to LR. See [url=“Google Code Archive - Long-term storage for Google Code Project Hosting.”]Google Code Archive - Long-term storage for Google Code Project Hosting.. This grammar generates an AST as well, but I haven’t completed the documentation of that. The “PTX: Parallel Thread Execution ISA Version 2.2” doc has no grammar, and the descriptions of the instructions are not that great (plus errors). So I had also to just derive the grammar from compiler output and hand-written tests that pushed the syntax, then tested them using ptxas and a cuda driver program. Antlrworks can be used to view the parse and AST of a PTX source file. --Ken D.
So PTX ISA manual was your start… Hmm… Very interesting!! And, really awesome , gutsy work!
Hmm… The PTX binary is just an assembled version of the PTX… So… the manual must have been helpful!
btw, Did you ever use “decuda” to understand anything?
I think “decuda” comes after the PTX stage… So must not have been a great help! Can you confirm?
Thanks for writing back,
Ken,
Thanks for sharing! Its going to be useful! Many Thanks!
btw, I think that is applicable to the “PTX” assembly language in “text” format, right?
I may need to do some conversion before using it… I will check out. THanks!
Ken,
As I was reading through your “cuda-waste” project, I was just wondering if you ever tried compiling “Ocelot” under cygwin. I would guess it must be a minor thing.
Anyway, Good luck on your project!
And if I can take the liberty, Can I ask you to consider a better name for your project (than cuda-waste).
