in our program we can switch between different precision modes (half, float, double), we noticed that the number of registers changes only slightly between half and float/double. We would expect that in half precision much less registers would be used. Why isn’t it the case? We compile on a DGX2 with the PGI 19.10 compiler.
half
ptxas info : Function properties for kernel1
0 bytes stack frame, 0 bytes spill stores, 0 bytes spill loads
ptxas info : Used 221 registers, 404 bytes cmem[0]
float
ptxas info : Used 253 registers, 408 bytes cmem[0]
double
ptxas info : Used 250 registers, 416 bytes cmem[0]
Thanks for your help.
