Ubuntu 20 is not required to run TensorFlow and is not supported yet. I suggest to stick with Ubuntu 18 for now. To install TensorFlow you need to run the commands listed in Python 3.6+JetPack4.5 section of Official TensorFlow for Jetson Nano! except the last line (assuming you want want TensorFlow 2 and do not need old TensorFlow 1.15).
I get the 404 error for now.
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://developer.download.nvidia.com/compute/redist/jp/v45/google-pasta/
I read somewhere TensorFlow is required for Ubuntu 20, obviously I was misinformed. I tried to upgrade to Ubuntu 20, only to have my kit bricked up. Finished installing Ubuntu 20 but after resetting only black screen with cursor flashing. I had to reflash the microSD for the umpteen time and install Jetpack 4.5. This reeks.
I tried to install TensorFlow with Python 3.7 and Jetpack 4.51 but the following message appeared:
sudo apt-get install libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev liblapack-dev libblas-dev gfortran
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
zip is already the newest version (3.0-11build1).
zip set to manually installed.
zlib1g-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2).
zlib1g-dev set to manually installed.
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
kde-window-manager kwin-common kwin-data kwin-x11 libdebian-installer4
libkdecorations2-5v5 libkdecorations2private5v5 libkf5globalaccelprivate5
libkf5idletime5 libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5
libkf5plasma5 libkf5waylandserver5 libkscreenlocker5
libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11
libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5
libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5
libqt5multimediawidgets5 libqt5opengl5 libqt5sql5 libqt5test5
libxcb-composite0 libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5
python3-icu python3-pam python3-pyqt5 python3-pyqt5.qtsvg
python3-pyqt5.qtwebkit python3-sip qml-module-qtmultimedia rdate tasksel
tasksel-data
Use βsudo apt autoremoveβ to remove them.
The following additional packages will be installed:
gfortran-7 hdf5-helpers libaec-dev libaec0 libgfortran-7-dev libhdf5-100
libhdf5-cpp-100 libjpeg-turbo8-dev libsz2
Suggested packages:
gfortran-doc gfortran-7-doc libgfortran4-dbg libcoarrays-dev liblapack-doc
libhdf5-doc
The following NEW packages will be installed:
gfortran gfortran-7 hdf5-helpers hdf5-tools libaec-dev libaec0 libblas-dev
libgfortran-7-dev libhdf5-100 libhdf5-cpp-100 libhdf5-dev libhdf5-serial-dev
libjpeg-turbo8-dev libjpeg8-dev liblapack-dev libsz2
0 upgraded, 16 newly installed, 0 to remove and 1 not upgraded.
Need to get 13.4 MB of archives.
After this operation, 53.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Abort.
Tried to install line by line, ran into problem on
$ sudo pip3 install -U numpy==1.16.1 future==0.18.2 mock==3.0.5 h5py==2.10.0 keras_preprocessing==1.1.1 keras_applications==1.0.8 gast==0.2.2 futures protobuf pybind11
below is what happened:
WARNING: The directory β/home/pc1/.cache/pipβ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you may want sudoβs -H flag.
Collecting numpy==1.16.1
Downloading numpy-1.16.1.zip (5.1 MB)
|ββββββββββββββββββββββββββββββββ| 5.1 MB 2.6 MB/s
Collecting future==0.18.2
Downloading future-0.18.2.tar.gz (829 kB)
|ββββββββββββββββββββββββββββββββ| 829 kB 936 kB/s
Collecting mock==3.0.5
Downloading mock-3.0.5-py2.py3-none-any.whl (25 kB)
Collecting h5py==2.10.0
Downloading h5py-2.10.0.tar.gz (301 kB)
|ββββββββββββββββββββββββββββββββ| 301 kB 25.2 MB/s
Collecting keras_preprocessing==1.1.1
Downloading Keras_Preprocessing-1.1.1-py2.py3-none-any.whl (42 kB)
|ββββββββββββββββββββββββββββββββ| 42 kB 1.5 MB/s
Collecting keras_applications==1.0.8
Downloading Keras_Applications-1.0.8-py3-none-any.whl (50 kB)
|ββββββββββββββββββββββββββββββββ| 50 kB 12.8 MB/s
Collecting gast==0.2.2
Downloading gast-0.2.2.tar.gz (10 kB)
Collecting futures
Downloading futures-3.1.1-py3-none-any.whl (2.8 kB)
Requirement already satisfied: protobuf in /usr/lib/python3/dist-packages (3.0.0)
Collecting protobuf
Downloading protobuf-3.15.3-py2.py3-none-any.whl (173 kB)
|ββββββββββββββββββββββββββββββββ| 173 kB 24.6 MB/s
Collecting pybind11
Downloading pybind11-2.6.2-py2.py3-none-any.whl (191 kB)
|ββββββββββββββββββββββββββββββββ| 191 kB 6.6 MB/s
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from h5py==2.10.0) (1.11.0)
Building wheels for collected packages: future, gast, h5py, numpy
Building wheel for future (setup.py) β¦ done
Created wheel for future: filename=future-0.18.2-py3-none-any.whl size=493275 sha256=7ca2988dca02fa5293a5f4a83858f5ab80dcdc1cd70fc7eb8adf6dc4f12fb2be
Stored in directory: /tmp/pip-ephem-wheel-cache-qr4q66j2/wheels/56/b0/fe/4410d17b32f1f0c3cf54cdfb2bc04d7b4b8f4ae377e2229ba0
Building wheel for gast (setup.py) β¦ done
Created wheel for gast: filename=gast-0.2.2-py3-none-any.whl size=7635 sha256=f7d42a3179f1878aa5bb2880759b792a8932f4e40d93e0cbd9ab3e4acc951c2b
Stored in directory: /tmp/pip-ephem-wheel-cache-qr4q66j2/wheels/21/7f/02/420f32a803f7d0967b48dd823da3f558c5166991bfd204eef3
Building wheel for h5py (setup.py) β¦ error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-w4ps5d1t/h5py_d22431a05a3d40ab90ae4c0da9071e19/setup.pyββ'ββ; file=ββ'ββ/tmp/pip-install-w4ps5d1t/h5py_d22431a05a3d40ab90ae4c0da9071e19/setup.pyββ'ββ;f=getattr(tokenize, β"βββopenβββββ, open)(file);code=f.read().replace(βββ"β\r\nββ'ββ, β"β"β\nββ'ββ);f.close();exec(compile(code, file, β"βββexecβββ"β))β bdist_wheel -d /tmp/pip-wheel-buafs1eq
cwd: /tmp/pip-install-w4ps5d1t/h5py_d22431a05a3d40ab90ae4c0da9071e19/
Complete output (115 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.7
creating build/lib.linux-aarch64-3.7/h5py
copying h5py/ipy_completer.py β build/lib.linux-aarch64-3.7/h5py
copying h5py/version.py β build/lib.linux-aarch64-3.7/h5py
copying h5py/init.py β build/lib.linux-aarch64-3.7/h5py
copying h5py/h5py_warnings.py β build/lib.linux-aarch64-3.7/h5py
copying h5py/highlevel.py β build/lib.linux-aarch64-3.7/h5py
creating build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/datatype.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/compat.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/files.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/dims.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/init.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/group.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/selections.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/vds.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/filters.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/selections2.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/dataset.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/base.py β build/lib.linux-aarch64-3.7/h5py/_hl
copying h5py/_hl/attrs.py β build/lib.linux-aarch64-3.7/h5py/_hl
creating build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_file_image.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5d_direct_chunk.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dataset_getitem.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dataset.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/init.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_threads.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_completions.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5pl.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_group.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dataset_swmr.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_file2.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5f.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_base.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_file.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5t.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_attribute_create.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dimension_scales.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_attrs.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_attrs_data.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dims_dimensionproxy.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_deprecation.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_filters.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_datatype.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_selections.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_slicing.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_dtype.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/common.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_h5p.py β build/lib.linux-aarch64-3.7/h5py/tests
copying h5py/tests/test_objects.py β build/lib.linux-aarch64-3.7/h5py/tests
creating build/lib.linux-aarch64-3.7/h5py/tests/test_vds
copying h5py/tests/test_vds/test_highlevel_vds.py β build/lib.linux-aarch64-3.7/h5py/tests/test_vds
copying h5py/tests/test_vds/test_virtual_source.py β build/lib.linux-aarch64-3.7/h5py/tests/test_vds
copying h5py/tests/test_vds/init.py β build/lib.linux-aarch64-3.7/h5py/tests/test_vds
copying h5py/tests/test_vds/test_lowlevel_vds.py β build/lib.linux-aarch64-3.7/h5py/tests/test_vds
running build_ext
File β/usr/lib/python3/dist-packages/numpy/core/init.pyβ, line 16, in
from . import multiarray
ImportError: cannot import name βmultiarrayβ from βnumpy.coreβ (/usr/lib/python3/dist-packages/numpy/core/init.py)
During handling of the above exception, another exception occurred:
File ββ, line 1, in
File β/tmp/pip-install-w4ps5d1t/h5py_d22431a05a3d40ab90ae4c0da9071e19/setup.pyβ, line 159, in
cmdclass = CMDCLASS,
File β/usr/local/lib/python3.7/dist-packages/setuptools/init.pyβ, line 163, in setup
return distutils.core.setup(**attrs)
File β/usr/lib/python3.7/distutils/core.pyβ, line 148, in setup
dist.run_commands()
File β/usr/lib/python3.7/distutils/dist.pyβ, line 966, in run_commands
self.run_command(cmd)
File β/usr/lib/python3.7/distutils/dist.pyβ, line 985, in run_command
cmd_obj.run()
File β/usr/lib/python3/dist-packages/wheel/bdist_wheel.pyβ, line 204, in run
self.run_command(βbuildβ)
File β/usr/lib/python3.7/distutils/cmd.pyβ, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File β/usr/lib/python3.7/distutils/command/build.pyβ, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File β/tmp/pip-install-w4ps5d1t/h5py_d22431a05a3d40ab90ae4c0da9071e19/setup_build.pyβ, line 162, in run
import numpy
File β/usr/lib/python3/dist-packages/numpy/init.pyβ, line 142, in
from . import add_newdocs
File β/usr/lib/python3/dist-packages/numpy/add_newdocs.pyβ, line 13, in
from numpy.lib import add_newdoc
File β/usr/lib/python3/dist-packages/numpy/lib/init.pyβ, line 8, in
from .type_check import *
File β/usr/lib/python3/dist-packages/numpy/lib/type_check.pyβ, line 11, in
import numpy.core.numeric as _nx
File β/usr/lib/python3/dist-packages/numpy/core/init.pyβ, line 26, in
raise ImportError(msg)
ImportError:
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If youβre working with a numpy git repo, try git clean -xdf
(removes all
files not under version control). Otherwise reinstall numpy.
Original error was: cannot import name βmultiarrayβ from βnumpy.coreβ (/usr/lib/python3/dist-packages/numpy/core/init.py)
ERROR: Failed building wheel for h5py
Running setup.py clean for h5py
Building wheel for numpy (setup.py) β¦ error
command: /usr/bin/python3 -u -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ; file=ββ'ββ/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ;f=getattr(tokenize, β"βββopenβββββ, open)(file);code=f.read().replace(βββ"β\r\nββ'ββ, β"β"β\nββ'ββ);f.close();exec(compile(code, file, β"βββexecβββ"β))β bdist_wheel -d /tmp/pip-wheel-jp2lxh2k
cwd: /tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/
Complete output (313 lines):
Running from numpy source directory.
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
blis_info:
libraries blis not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
openblas_info:
libraries openblas not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/system_info.py:636: UserWarning:
Atlas (http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
self.calc_info()
blas_info:
C compiler: aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fdebug-prefix-map=/build/python3.7-rNwl2C/python3.7-3.7.10=. -fstack-protector-strong -Wformat -Werror=format-security -g -fdebug-prefix-map=/build/python3.7-rNwl2C/python3.7-3.7.10=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
creating /tmp/tmpbj4eqs58/tmp
creating /tmp/tmpbj4eqs58/tmp/tmpbj4eqs58
compile options: β-I/usr/local/include -I/usr/include -cβ
aarch64-linux-gnu-gcc: /tmp/tmpbj4eqs58/source.c
aarch64-linux-gnu-gcc -pthread /tmp/tmpbj4eqs58/tmp/tmpbj4eqs58/source.o -lcblas -o /tmp/tmpbj4eqs58/a.out
/usr/bin/ld: cannot find -lcblas
collect2: error: ld returned 1 exit status
aarch64-linux-gnu-gcc -pthread /tmp/tmpbj4eqs58/tmp/tmpbj4eqs58/source.o -lblas -o /tmp/tmpbj4eqs58/a.out
FOUND:
libraries = [βblasβ, βblasβ]
library_dirs = [β/usr/lib/aarch64-linux-gnuβ]
include_dirs = [β/usr/local/includeβ, β/usr/includeβ]
language = c
define_macros = [(βHAVE_CBLASβ, None)]
FOUND:
define_macros = [('NO_ATLAS_INFO', 1), ('HAVE_CBLAS', None)]
libraries = ['blas', 'blas']
library_dirs = ['/usr/lib/aarch64-linux-gnu']
include_dirs = ['/usr/local/include', '/usr/include']
language = c
/bin/sh: 1: svnversion: not found
non-existing path in βnumpy/distutilsβ: βsite.cfgβ
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in [β/usr/local/libβ, β/usr/libβ, β/usr/lib/aarch64-linux-gnuβ]
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
<class βnumpy.distutils.system_info.atlas_3_10_threads_infoβ>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class βnumpy.distutils.system_info.atlas_3_10_infoβ>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class βnumpy.distutils.system_info.atlas_threads_infoβ>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class βnumpy.distutils.system_info.atlas_infoβ>
NOT AVAILABLE
self.calc_info()
lapack_info:
FOUND:
libraries = [βlapackβ, βlapackβ]
language = f77
FOUND:
libraries = ['lapack', 'lapack', 'blas', 'blas']
language = c
/usr/lib/python3.7/distutils/dist.py:274: UserWarning: Unknown distribution option: βdefine_macrosβ
warnings.warn(msg)
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-aarch64-3.7
creating build/src.linux-aarch64-3.7/numpy
creating build/src.linux-aarch64-3.7/numpy/distutils
building library βnpymathβ sources
get_default_fcompiler: matching types: β[βgnu95β, βintelβ, βlaheyβ, βpgβ, βabsoftβ, βnagβ, βvastβ, βcompaqβ, βinteleβ, βintelemβ, βgnuβ, βg95β, βpathf95β, βnagforβ]β
customize Gnu95FCompiler
Found executable /usr/bin/gfortran
customize Gnu95FCompiler using config
compile options: β-Inumpy/core/src/common -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.7m -cβ
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
_configtest.c:1:5: warning: conflicting types for built-in function βexpβ [-Wbuiltin-declaration-mismatch]
int exp (void);
_configtest.o: In function main': /tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/_configtest.c:6: undefined reference to
expβ
failure.
int exp (void);
aarch64-linux-gnu-gcc -pthread _configtest.o -lm -o _configtest
success!
creating build/src.linux-aarch64-3.7/numpy/core
creating build/src.linux-aarch64-3.7/numpy/core/src
creating build/src.linux-aarch64-3.7/numpy/core/src/npymath
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_internal.h
adding βbuild/src.linux-aarch64-3.7/numpy/core/src/npymathβ to include_dirs.
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = [βbuild/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_internal.hβ]
building library βnpysortβ sources
creating build/src.linux-aarch64-3.7/numpy/core/src/common
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/common/npy_sort.h
adding βbuild/src.linux-aarch64-3.7/numpy/core/src/commonβ to include_dirs.
creating build/src.linux-aarch64-3.7/numpy/core/src/npysort
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npysort/quicksort.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npysort/mergesort.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npysort/heapsort.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/common/npy_partition.h
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npysort/selection.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/common/npy_binsearch.h
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npysort/binsearch.c
None - nothing done with h_files = [βbuild/src.linux-aarch64-3.7/numpy/core/src/common/npy_sort.hβ, βbuild/src.linux-aarch64-3.7/numpy/core/src/common/npy_partition.hβ, βbuild/src.linux-aarch64-3.7/numpy/core/src/common/npy_binsearch.hβ]
building extension βnumpy.core._dummyβ sources
Generating build/src.linux-aarch64-3.7/numpy/core/include/numpy/config.h
_configtest.c:1:10: fatal error: Python.h: No such file or directory
#include <Python.h>
compilation terminated.
failure.
File ββ, line 1, in
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyβ, line 415, in
setup_package()
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyβ, line 407, in setup_package
setup(**metadata)
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/core.pyβ, line 171, in setup
return old_setup(**new_attr)
dist.run_commands()
cmd_obj.run()
cmd_obj.run()
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build.pyβ, line 47, in run
old_build.run(self)
cmd_obj.run()
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.pyβ, line 148, in run
self.build_sources()
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.pyβ, line 165, in build_sources
self.build_extension_sources(ext)
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.pyβ, line 322, in build_extension_sources
sources = self.generate_sources(sources, ext)
File β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.pyβ, line 375, in generate_sources
source = func(extension, build_dir)
File βnumpy/core/setup.pyβ, line 423, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File βnumpy/core/setup.pyβ, line 47, in check_types
out = check_types(*a, **kw)
File βnumpy/core/setup.pyβ, line 281, in check_types
βinstall {0}-dev|{0}-devel.β.format(python))
SystemError: Cannot compile βPython.hβ. Perhaps you need to install python-dev|python-devel.
ERROR: Failed building wheel for numpy
Running setup.py clean for numpy
command: /usr/bin/python3 -u -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ; file=ββ'ββ/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ;f=getattr(tokenize, β"βββopenβββββ, open)(file);code=f.read().replace(βββ"β\r\nββ'ββ, β"β"β\nββ'ββ);f.close();exec(compile(code, file, β"βββexecβββ"β))β clean --all
Complete output (10 lines):
setup.py clean
is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add --force
to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for numpy
Successfully built future gast
Failed to build h5py numpy
Installing collected packages: numpy, h5py, pybind11, protobuf, mock, keras-preprocessing, keras-applications, gast, futures, future
Attempting uninstall: numpy
Found existing installation: numpy 1.13.3
Uninstalling numpy-1.13.3:
Successfully uninstalled numpy-1.13.3
Running setup.py install for numpy β¦ error
command: /usr/bin/python3 -u -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ; file=ββ'ββ/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ;f=getattr(tokenize, β"βββopenβββββ, open)(file);code=f.read().replace(βββ"β\r\nββ'ββ, β"β"β\nββ'ββ);f.close();exec(compile(code, file, β"βββexecβββ"β))β install --record /tmp/pip-record-jeoc_pok/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.7/numpy
Complete output (306 lines):
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
blas_opt_info:
blas_mkl_info:
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
self.calc_info()
blas_info:
creating /tmp/tmpy02xfm3w/tmp
creating /tmp/tmpy02xfm3w/tmp/tmpy02xfm3w
compile options: '-I/usr/local/include -I/usr/include -c'
aarch64-linux-gnu-gcc: /tmp/tmpy02xfm3w/source.c
aarch64-linux-gnu-gcc -pthread /tmp/tmpy02xfm3w/tmp/tmpy02xfm3w/source.o -lcblas -o /tmp/tmpy02xfm3w/a.out
aarch64-linux-gnu-gcc -pthread /tmp/tmpy02xfm3w/tmp/tmpy02xfm3w/source.o -lblas -o /tmp/tmpy02xfm3w/a.out
FOUND:
language = c
define_macros = [('HAVE_CBLAS', None)]
FOUND:
language = c
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
NOT AVAILABLE
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
self.calc_info()
lapack_info:
FOUND:
libraries = ['lapack', 'lapack']
language = f77
FOUND:
language = c
/usr/lib/python3.7/distutils/dist.py:274: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
running install
running build
running config_cc
running config_fc
running build_src
build_src
building library "npymath" sources
get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
compile options: '-Inumpy/core/src/common -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -I/usr/include/python3.7m -c'
success!
int exp (void);
_configtest.o: In function `main':
/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/_configtest.c:6: undefined reference to `exp'
failure.
int exp (void);
success!
adding 'build/src.linux-aarch64-3.7/numpy/core/src/npymath' to include_dirs.
None - nothing done with h_files = ['build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_internal.h']
building library "npysort" sources
adding 'build/src.linux-aarch64-3.7/numpy/core/src/common' to include_dirs.
None - nothing done with h_files = ['build/src.linux-aarch64-3.7/numpy/core/src/common/npy_sort.h', 'build/src.linux-aarch64-3.7/numpy/core/src/common/npy_partition.h', 'build/src.linux-aarch64-3.7/numpy/core/src/common/npy_binsearch.h']
building extension "numpy.core._dummy" sources
#include <Python.h>
failure.
File "<string>", line 1, in <module>
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.py", line 415, in <module>
setup_package()
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.py", line 407, in setup_package
setup(**metadata)
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/core.py", line 171, in setup
File "/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py", line 163, in setup
File "/usr/lib/python3.7/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.7/distutils/dist.py", line 966, in run_commands
File "/usr/lib/python3.7/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/install.py", line 62, in run
r = self.setuptools_run()
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/install.py", line 36, in setuptools_run
return distutils_install.run(self)
File "/usr/lib/python3.7/distutils/command/install.py", line 589, in run
self.run_command('build')
File "/usr/lib/python3.7/distutils/cmd.py", line 313, in run_command
cmd_obj.run()
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build.py", line 47, in run
old_build.run(self)
File "/usr/lib/python3.7/distutils/command/build.py", line 135, in run
cmd_obj.run()
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.py", line 148, in run
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.py", line 165, in build_sources
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.py", line 322, in build_extension_sources
File "/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/numpy/distutils/command/build_src.py", line 375, in generate_sources
File "numpy/core/setup.py", line 423, in generate_config_h
File "numpy/core/setup.py", line 47, in check_types
File "numpy/core/setup.py", line 281, in check_types
"install {0}-dev|{0}-devel.".format(python))
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
Rolling back uninstall of numpy
Moving to /usr/lib/python3/dist-packages/numpy
from /usr/lib/python3/dist-packages/~umpy
Moving to /usr/lib/python3/dist-packages/numpy-1.13.3.egg-info
from /usr/lib/python3/dist-packages/~umpy-1.13.3.egg-info
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c βimport sys, setuptools, tokenize; sys.argv[0] = β"β"β/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ; file=ββ'ββ/tmp/pip-install-w4ps5d1t/numpy_13677e0b227f4a058d848d00091749f5/setup.pyββ'ββ;f=getattr(tokenize, β"βββopenβββββ, open)(file);code=f.read().replace(βββ"β\r\nββ'ββ, β"β"β\nββ'ββ);f.close();exec(compile(code, file, β"βββexecβββ"β))β install --record /tmp/pip-record-jeoc_pok/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.7/numpy Check the logs for full command output.
Please help thanks.
Sounds like during upgrade process you accidentally replaced the kernel build by Nvidia for Jetson Nano with standard kernel build for Ubuntu (without Nvidia patches and drivers), so this is expected result. Upgrading a kernel to an unsupported version is generally not an easy job on an embedded system, including Jetson Nano. And even if you keep original kernel, upgrading to unsupported version of Ubuntu is not easy either and not without issues. Until Ubuntu 20 is officially supported, it is better to keep using Ubuntu 18, especially for those who do not have advanced knowledge about Jetson Nano and Linux in general.
I have Python 3.6.9, which is what I got by default, and I have no issues with installing and running TensorFlow with JetPack 4.5.1. I do not think Python 3.7 is officially supported yet so I suggest to try again with Python 3.6.
P.S. When you need to share long log files, it is better to use https://pastebin.com/ and link to it than copy and pasting inline with bad formatting which makes your log and the forum thread less readable.
So I guess I will have to flash again?..sighβ¦
So I reflashed and installed Jetpack 4.51 and Python 3.6. Following message came up.
Installing 3.6 if not installed and uninstalling Python 3.7 would be probably faster, but flashing works too to get the system back to the default state.
Quotes from your log file:
pc1@pc1-desktop:~$ $ sudo pip3 install --pre --extra-index-url Index of /compute/redist/jp/v45 tensorflow
bash: $: command not found
means you are supposed to run the command as non-root user. You are not supposed to actually type $
as a command. This is common notation so it is useful to know it. My guess why other commands did not have $
prefix but only the last two do have it, it is because you are supposed to choose only one instead of blindly trying copy and paste the whole code block without understanding what each line does. If unsure what version of tensorflow to install, install tensorflow 2.
pc1@pc1-desktop:~$ $ sudo pip3 install --pre --extra-index-url Index of /compute/redist/jp/v45 βtensorflow<2β
bash: 2β: No such file or directory
Using backticks in shell instead of quotes is like writing $(tensorflow<2)
instead of 'tensorflow<2'
or "tensorflow<2"
. Basically you are trying to redirect content of non-existing file β2β in current directory to command βtensorflowβ (which probably does not exist either but execution has stopped at the first error), and then use output of that with non-existent command $
. You are not supposed to type the dollar sign and you need to use '
or "
instead of backticks. But are you sure you even need old tensorflow 1.15? If you want tensorflow 2, then you do not need to install 1.15.
Thanks for the advice Lissanro. Perhaps itβs best to explain what Iβm trying to do first. Iβm trying to use machine learning to run MetaTrader 5. Iβve gotten these kits since last December and trying to make it work ever since. Iβm no programmer nor Python OS environmental developer. I think either TensorFlow or Pytorch can do what Iβm trying to do, but Iβve been having terrible experience. Nvidia should have some automated installing package that could check on what component you have and download and install, but I havenβt see it, as it tout itself as leader in automation. So far Iβm trying to see what python does and copy and pasting all these commands, at same time trying to see how to run Tensorflow and to see what it does.
could you show me what command to run as a non-root user? every time I open terminal it comes pc1@pc1-desktop:$
Thank you.
Also, Iβm trying to network these kits together to run a parallel supercomputer. So far I have these kits connected to an 8 outlet POE but theyβre not really communicating to each other. I downloaded Putty and attempt to network them together, but they donβt really do what I wanted to do. Any help is appreciated.
I will add more kits/modules as time goes on, if it works. But I canβt even get it to work the way I wanted to. Terrible.
@hpc88323, please open a new topic about your networking issues, thanks.
The automated delivery mechanism is the Docker containers, they come with PyTorch/TensorFlow/ect pre-installed. https://elinux.org/Jetson_Zoo#Docker_Containers
To install TensorFlow directly, follow these instructions: https://docs.nvidia.com/deeplearning/frameworks/install-tf-jetson-platform/index.html#prereqs
Omit the leading $
from the commands if you are copy and pasting them.
Thanks for reply. I tried the docker pull command and this is what happened:
docker pull nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post http://%2Fvar%2Frun%2Fdocker.sock/v1.40/images/create?fromImage=nvcr.io%2Fnvidia%2Fl4t-tensorflow&tag=r32.5.0-tf2.3-py3: dial unix /var/run/docker.sock: connect: permission denied
I apologize, Iβm very novice to Ubuntu/Unix etc. I donβt know how to switch to root user and other user. If you could can you type the commands to switch and exactly what to download and install? I only know how to copy and paste and do minor command changes. Thank you.
Ok, done. Following apeared:
pc1@pc1-desktop:~$ sudo docker pull nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
[sudo] password for pc1:
r32.5.0-tf2.3-py3: Pulling from nvidia/l4t-tensorflow
5000a6c32c5a: Pulling fs layer
8e855b69096a: Pulling fs layer
8db8dbbd4bb9: Pulling fs layer
833dc3235950: Waiting
f79d264135a3: Pull complete
1c40f77bb35b: Pull complete
1990ecf0bfb7: Pull complete
c8ffbfd7f0aa: Pull complete
ba785779122a: Pull complete
024ce79b6790: Pull complete
9b09da3b5483: Pull complete
17f974a43cf9: Pull complete
211b56b73ff1: Pull complete
78aca4be1f3b: Pull complete
95f34310bbda: Pull complete
678c9d1557e9: Pull complete
ec17ad7cab01: Pull complete
08fb1eee5328: Pull complete
4d4b03e45e85: Pull complete
890acf9522e1: Pull complete
4285cec48fa4: Pull complete
b2134f7c52d6: Pull complete
fc89162c3e71: Pull complete
6207db6c0808: Pull complete
ff42b2cc8554: Pull complete
cac51dab2a29: Pull complete
358194fb67c2: Pull complete
Digest: sha256:e1a9adc3cc3502a0b162644b45cd17090f23a13ca51bb85a04fc803fefafe7a6
Status: Downloaded newer image for nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
Whatβs next? Thank you.
The directions to run the container are found here:
https://ngc.nvidia.com/catalog/containers/nvidia:l4t-tensorflow
sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
Did that, and below is what happened:
pc1@pc1-desktop:~$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-tensorflow:r32.5.0-tf2.3-py3
root@pc1-desktop:/#
Please show next thanks.
Your terminal is now running inside the container. Run python3
to start an interactive python interpreter and you will be able to import tensorflow
