Environment: (ISO file: jetson-nano-4gb-jp441-sd-card-image.zip)
I got error as below:
ken@AI:~$ sudo apt-get install libhdf5-serial-dev
[sudo] password for ken:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libhdf5-serial-dev : Depends: libhdf5-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
ken@AI:~$ sudo apt-get install libhdf5-dev
libhdf5-dev : Depends: libjpeg-dev
ken@AI:~$ sudo apt-get install libjpeg-dev
libjpeg-dev : Depends: libjpeg8-dev but it is not going to be installed
ken@AI:~$ sudo apt-get install libjpeg8-dev
libjpeg8-dev : Depends: libjpeg-turbo8-dev (>= 1.1.90+svn722-1ubuntu6) but it is not going to be installed
ken@AI:~$ sudo apt-get install libjpeg-turbo8-dev
libjpeg-turbo8-dev : Depends: libjpeg-turbo8 (= 1.5.2-0ubuntu5) but 1.5.2-0ubuntu5.18.04.4 is to be installed
libjpeg-turbo8 is already the newest version (1.5.2-0ubuntu5.18.04.4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anyone know how to resolve the problem?
Thanks for help!
