I use AGX Orin and run ollama as Ollama on Jetson | Jetson AI Lab .
Run the below command and find the GPU cannot run like “unable to locate gpu dependency libraries”. I use L4T 39.2 and nvidia-smi shows “NVIDIA-SMI 595.78 Driver Version: 595.78 CUDA Version: 13.2”.
root@steven:/home/steven# docker run --runtime nvidia -it --rm
–network host
-e NVIDIA_DRIVER_CAPABILITIES=compute,utility,video
-v ~/ollama:/ollama
-v ~/ollama-logs:/data/logs
-e OLLAMA_MODELS=/ollama
dustynv/ollama:r36.2.0
Starting ollama server
Couldn’t find ‘/root/.ollama/id_ed25519’. Generating new private key.
Your new public key is:
ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIGEL50aKhgy8EvzMEVRCqBPcM2P19u2h5F8wdOSqMOFA
/06/06 09:37:48 routes.go:1125: INFO server config env=“map[CUDA_VISIBLE_DEVICES: GPU_DEVICE_ORDINAL: HIP_VISIBLE_DEVICES: HSA_OVERRIDE_GFX_VERSION: OLLAMA_DEBUG:false OLLAMA_FLASH_ATTENTION:false OLLAMA_HOST:http://0.0.0.0:11434 OLLAMA_INTEL_GPU:false OLLAMA_KEEP_ALIVE:5m0s OLLAMA_LLM_LIBRARY: OLLAMA_MAX_LOADED_MODELS:0 OLLAMA_MAX_QUEUE:512 OLLAMA_MODELS:/ollama OLLAMA_NOHISTORY:false OLLAMA_NOPRUNE:false OLLAMA_NUM_PARALLEL:0 OLLAMA_ORIGINS:[http://localhost https://localhost http://localhost:* https://localhost:* http://127.0.0.1 https://127.0.0.1 http://127.0.0.1:* https://127.0.0.1:* http://0.0.0.0 https://0.0.0.0 http://0.0.0.0:* https://0.0.0.0:* app://* file://* tauri://*] OLLAMA_RUNNERS_DIR: OLLAMA_SCHED_SPREAD:false OLLAMA_TMPDIR: ROCR_VISIBLE_DEVICES:]”
time=2026-06-06T09:37:48.608Z level=INFO source=images.go:753 msg=“total blobs: 0”
time=2026-06-06T09:37:48.608Z level=INFO source=images.go:760 msg=“total unused blobs removed: 0”
time=2026-06-06T09:37:48.609Z level=INFO source=routes.go:1172 msg=“Listening on [::]:11434 (version 5f7b4a5)”
time=2026-06-06T09:37:48.613Z level=INFO source=payload.go:30 msg=“extracting embedded files” dir=/tmp/ollama3720657019/runners
time=2026-06-06T09:37:49.889Z level=INFO source=payload.go:44 msg=“Dynamic LLM libraries [cpu cuda_v12]”
time=2026-06-06T09:37:49.889Z level=INFO source=gpu.go:200 msg=“looking for compatible GPUs”
time=2026-06-06T09:37:49.890Z level=WARN source=gpu.go:669 msg=“unable to locate gpu dependency libraries”
time=2026-06-06T09:37:49.898Z level=INFO source=gpu.go:568 msg=“unable to load cuda driver library” library=/usr/local/cuda/compat/libcuda.so.1.1 error=“cuda driver library init failure: 801”
time=2026-06-06T09:37:49.898Z level=WARN source=gpu.go:669 msg=“unable to locate gpu dependency libraries”
time=2026-06-06T09:37:49.910Z level=INFO source=gpu.go:347 msg=“no compatible GPUs were discovered”
time=2026-06-06T09:37:49.910Z level=INFO source=types.go:107 msg=“inference compute” id=0 library=cpu variant=“no vector extensions” compute=“” driver=0.0 name=“” total=“61.3 GiB” available=“56.8 GiB”
OLLAMA_MODELS /ollama
OLLAMA_LOGS /data/logs/ollama.log
ollama server is now started, and you can run commands here like ‘ollama run llama3’
groups: cannot find name for group ID 982
groups: cannot find name for group ID 993
root@steven:/#
