Ollama support for Jetson Nano
I’m referring to this post Introducing Ollama Support for Jetson Devices
The topic is closed, so I can’t ask there. But the question is: Is Ollama support also meant to be available for old Jetson Nano? I suppose not, since I can’t make it run there… :)
Disregard. Will not work
Which Jetson do you use? Is it Jetson Nano or Orin Nano?
We do provide Ollama containers for users to test.
But it requires the environment with JetPack 5 or JetPack 6:
The 2020 Jetson Nano, not Orin. I don’t believe in will work
We don’t have a container for JetPack 4 environment.
But you can try to follow the steps in the below file to see if it can work:
If you are utilizing Ollama (which I suppose) I doubt this will work since Ollama only supports JP 5 or >=6
If you’re running on an NVIDIA JetPack system, Ollama can’t automatically discover the correct JetPack version. Pass the environment variable JETSON_JETPACK=5 or JETSON_JETPACK=6 to the container to select version 5 or 6.
also here
Basically Ollama works on 18.04/JP4. But just w/o GPU
We don’t have too many experiments on the Ollama with JetPack 4.
If the GPU function is preferred, you will need to follow the instructions and create a new one for JetPack 4.
Here is a related discussion for your reference:
