Omniverse-Create : Error capturing high resolution images
Dear Community,
We’ve been trying to generate some high resolution images with Omniverse-Create, but we get the following error:
o OK at 2560 - 16/9
o NOK at 10000 - 4/3
After the error, “Create” just closes by itself.
Is that a known limitation? (anywhere documented?),
or a bug, or whatever parameter missing?
Hello @admin.it1! Oh no! This issue is causing your Application to crash? Can you zip and attach your full logs found here: C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs I will have the dev team dig into this issue!
Hi Wendy,
Thank you for taking care ;)
Note that the same exception occurs whatever the model we try to capture or the laptop we use (all DELL Gaming), just depending on the resolution (estimated any width >6500).
Here are further details (screenshot sequence) and the requested logs.
Omni-logs.zip (5.2 MB)
