Hello
I installed omniverse laucher without issues… but after downloading CREATE And lauch it by clicking on the button in launcher … it doesn’t start at all … no splash screen no error message.
I tried to re-install nvidia drivers by following the linux troubleshooting doc … but no luck 😢… the same problem remains.
Operating system linux mint 20.3
Gpu Rtx 2070 super
Gpu Drivers version 510.54
Hello @hishamville! Welcome to the community! I know that Linux Mint is supported by Unbuntu (which is what we currently support), but I’m not sure if that is the issue or if it is something else. Could you attach your launcher log files? They might be able to shed some light on what the problem is.
Also, in case this helps, we created a special section of our documentation for troubleshooting Linux here: Linux Troubleshooting — Omniverse Kit documentation
hello @WendyGram, thanks for responding … I looked in the Omniverse folder for log files … and found two files in the Create folders
kit_20211219_194635.log (474.1 KB)
kit_20211219_194639.log (537.9 KB)
I failed to find the log files for the Launcher .
thanks
