I’d like to start a project that optimizes GPU power consumption by changing its frequency in an application transparent way, that is, without changing the app code, a host daemon process with admin privilege snooping the app performance.
Besides, another requirement is that the optimization is done during the process, i.e,. online optimization.
Is there a way, or some API, to immediately get performance (such as kernel execution time + memory transfer time) from outside the running application and in the middle of job execution?
Do you want to get the performance for that existing application (kernel execution time + memory transfer time) as written? That seems like a very indirect way to measure performance. Perhaps more accurate would be to know the current frequency + the used GPU model. Or are there certain reasons (e.g. one important kernel and each call of it signifies an important measurement unit, e.g. 1,000,000 work packages; or you want to display kernel execution time + memory transfer time + kernel name to the user).
Nope. I’d like to reduce power consumption as a cloud administrator being blind to each application code written. That’s why I need a very indirect way to measure performance.
