–gpu all setting was set and running !nvidia-smi from the Jupyter Notebook cell showed 2 GPUs but when running the solve_problem() only 1 GPU was being used.
Multi-GPU use cases in cuOpt are a continuing area of research but cuOpt does not support this at present. Happily, though, many use cases including this one can scale to thousands of locations on a single GPU while still allowing sub-second solve times.
