OpenACC Reduction implies copy ?
I have a standard openacc reduction function likes
      s = 0.
!$ACC PARALLEL LOOP REDUCTION(+:s) PRESENT(x,y)
      do i=1,n
         s = s + x(i)*y(i)
      enddo
and the output of PGI_ACC_TIME for the function is
  vlxy_acc  NVIDIA  devicenum=0
    time(us): 111,062
    2209: compute region reached 13594 times
        2209: kernel launched 13594 times
            grid: [1029]  block: [128]
            elapsed time(us): total=223,901 max=50 min=15 avg=16
        2209: reduction kernel launched 13594 times
            grid: [2]  block: [256]
            elapsed time(us): total=165,437 max=44 min=11 avg=12
    2209: data region reached 54376 times
        2209: data copyin transfers: 13594
             device time(us): total=41,611 max=21 min=3 avg=3
        2216: data copyout transfers: 13594
             device time(us): total=69,451 max=36 min=4 avg=5
So there are some data copyin and copyout for the scale “s”, which is not intended since “s” is only used on devices. I just read the OpenACC docs at
https://www.openacc.org/blog/whats-new-openacc-27
"… the reduction clause implies copy(s) on the compute construct, "
Is there any method to eliminate the implicit “copy” ?
Thanks. /JG
Hi JG,
Yes. Put “s” in a data region and it wont be implicitly copied back to the host after the reduction.
Something like:
      s = 0.
!$ACC DATA COPYIN(s)
      do i=1,n
         s = s + x(i)*y(i)
      enddo
! s wont be copied back since it's in a data region
! Another compute region that use "s"
      do i=1,n
          x(i) = x(i)/s
      enddo
!$ACC END DATA
Hope this helps,
Mat
