Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”): Software Version
DRIVE OS Linux 5.2.0
[yes] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
Host Machine Version
[yes] native Ubuntu 18.04
other
Hi, I am trying to compile/install opencv on drive OS 5.2.0.
I have followed this link OpenCV compilation - #4 by SteveNV , and tried to install from target, sudo dpkg -i /var/cuda-repo-10-2-local-10.2.19/cuda-toolkit-10-2_10.2.19-1_arm64.deb is not available on target as well in host. Please let me know how to get this.
NCG will be available with the upcoming release.
But unfortunately OpenCV is not officially supported nor is it optimized on the Drive platform.
Please see one recent post below:
Installed opencv on target now without cuda, however I need to add opencv support on our tensorrt example.
till now I have build tensorrt examples on Host and run it on target. is it possible to compile tensort samples on target itself?
I am facing issue while cross compile tensorrt sample with openGL.
I have copied OpenGL related libs from Drive Agx to my Host machine for cross complile.
OpenCV also I need to remove GTK while compile.
Trying to create a application where we do pre and post processing using opencv and CNN using TensorRT and rendering output using OpenGL.
