OpenCV remap tables to vx_remap
Looking for help creating OpenVX remap tables (vx_remap) from the output of cv::initUndistortRectifyMap. I am currently doing this as follows:
cv::Size size(cameras->frameWidth, cameras->frameHeight);
cv::initUndistortRectifyMap(cameras->getCameraMatrix(),
			    cameras->getDistCoeffs(),
			    R, P,
			    size,
			    CV_32FC1,
			    remapX, remapY);
			    R, P,
			    size,
			    CV_32FC1,
			    remapX, remapY);
int sfw = size.width, sfh = size.height;
int dfw = size.width, dfh = size.height;
remapTable  = vxCreateRemap(context, sfw, sfh, dfw, dfh);
vx_status status;
for(int y = 0; y < dfh; y++) {
  for(int x = 0; x < dfw; x++) {
    status = vxSetRemapPoint(remapTable,
			     x, y,
			     (vx_float32)remapX.at<float>(y, x),
			     (vx_float32)remapY.at<float>(y, x));
			     x, y,
When I subsequently try to rectify images using cv::remap(), all is fine. However, when I try to rectify using vxuRemap() with the remapTable I built above, the images are not correct (i.e, there are striped lines, mirroring, distortion, etc.). So I’m obviously not converting the remap tables correctly. Any help here would be appreciated.
Did you try inverting x & y like this ? :
			     x, y,
			     (vx_float32)remapX.at<float>(x, y),
			     (vx_float32)remapY.at<float>(x, y));
In the OpenCV documentation I see:
C++: template<typename T> T& Mat::at(int i, int j)
Parameters:
    i – Index along the dimension 0
    j – Index along the dimension 1
@tlepley. Thanks, it turns out it was something completely unrelated. The remap is working fine.
