mk_opc
June 13, 2017, 10:07pm
1
Hi there,
I am trying to get a little camera preview window running with some OpenCV code.
I naively tried the example here first: Reading and Writing Video — OpenCV 3.0.0-dev documentation
and the result was a failure of opening the capture with another error: HIGHGUI ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV
After some reading, it turned out that you have to write
VideoCapture cap("nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)640, height=(int)480, format=(string)I420, framerate=(fraction)30/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)I420 ! videoconvert ! video/x-raw, format=(string)BGR ! appsink");
instead of
VideoCapture cap(0);
However, this still does not succeed! There is no more HIGHGUI error, but the capture is not working.
Am I missing something? I tried compiling with g++ and cmake, both have the same result.
Please check if you have enabled gstreamer option when building.
More information can be found here:
[url]https://devtalk.nvidia.com/default/topic/1001696/[/url]
mk_opc
June 14, 2017, 5:58pm
3
How can I check this?
I’m not sure if I’m doing this right, when building the application I write
cmake -DCUDA_USE_STATIC_CUDA_RUNTIME=OFF -DWITH_GSTREAMER=ON ..
but it later says
CMake Warning:
Manually-specified variables were not used by the project:
WITH_GSTREAMER
Also, I tried the code from the link you posted, but it seems that I do not have “opencv2/videoio.hpp”, is that the problem?
Thanks for your help.
edit: I will try upgrading my OpenCV from 2.4.13 to 3.1.0 and see what happens …
Have you installed gstreamer dev packages ?
sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
You may check http://dev.t7.ai/jetson/opencv/ for other required or useful packages to be installed for building opencv.
Furthermore, which version of opencv are you building ? I would suggest 3.2.0, but 3.1.0 also works.
If this doesn’t work, post your configure command and its output.
mk_opc
June 14, 2017, 6:24pm
5
Yup I have all of those, and I can access the camera running gstreamer straight from command line.
I will do 3.2.0, but which brings up another question, why does it not come with the latest Jetpack (which I flashed)???
edit: is OpenCV4Tegra much faster than OpenCV ?
Opencv4tegra is a Nvidia closed source version, based on opencv-2.4.13 (.12 in older versions), built with many optimizations for tegra chips. AFAIK, it doesn’t support gstreamer.
So you just have to build your own opencv-3.2.0 library (this implies configure with cmake and build with make), I would advise to build it on a disk having at least 4GB free, and then install it on your TX1 with
sudo make install
that will install it into the location provided at configure time with CMAKE_INSTALL_PREFIX.
Be aware if you keep opencv4tegra, it is installed in /usr, and will therefore be found by gcc instead of opencv3 includes if you don’t provide opencv3 include path namely with -I. Same applies for opencv librairies path at link time with -L.
Check the previously mentioned example for the syntax if you’re not familiar with it.
[EDIT answer: for speed, you just have to benchmark. Building with linaro gcc5 gives also faster code (opencv4tegra is built with gcc4), opencv-3.2.0 uses nvidia carotene low level optimizations library. Depends on what you want to do. But if gstreamer pipeline is mandatory, IMHO you have no choice.]
mk_opc
June 14, 2017, 7:38pm
7
sudo make install
Thank you! I believe this is true, the OpenCV that comes with Jetpack simply doesn’t support gstreamer.
That’s kind of weird.
Thanks again for the tips.
Never believe me ! ;-) I also give sometimes weird advices…
Just let us know if it works or post error logs if not.
